Aktuálny čas je Uto 01. Dec 2026 0:00:57
 WinXP Manager 6.0.2
 Predmet príspevku: WinXP Manager 6.0.2
PoslaťNapísal: Štv 19. Feb 2009 20:47:14
The complete solution to optimize, tweak, clean up Windows XP
WinXP Manager is a tool for setting, optimizing, diagnosing and tweaking Windows XP. It bundles more than 30 different utilities in one and help your system faster and more stable, secure and personal! WinXP Manager helps you optimize, tweak, and clean up Windows XP. It will increase your system speed, improve system security, and meet all of your expectations.
You can tweak memory and CPU settings, customize IE settings, find and remove junk files, check and repair your registry, control startup programs, optimize your connection speed, validate your Favorites and much more. It also includes an Auto-Optimization option, that allows less experienced users to easily optimize certain settings, using a wizard. The interface is easy to use and all available options are categorized into sections. Includes basic documentation and an annoying nag screen that pops up every few minutes. It's compatible with Windows XP SP3 entirely!
Features and Benefits of WinXP Manager:
• Information - Get detailed system and all hardware information on your system; helps you to find out the missing Registration codes of Microsoft product; show all detailed information of running processes and threads on your machine; WinXP Manager offers optimization Wizard feature for the user without having any advanced knowledge.
• Optimizer - Tweak your system to improve windows startup and shutdown speed; monitor and free your Physical Memory; tweak your hardware to increase system speed and performance; disable some unnecessary services which start with windows; repairs Internet Explorer and certain other System Components to restore these functions.
• Cleaner - Find out which files or folders engross your disk space and shown with chart; Find and clean junk, unnecessary wallpaper and screen saver files to increase Hard Disk space; Duplicate Files Finder can scan your computer for files with the same size, name and modification time; Registry Cleaner can easily checks your registry and repair incorrectly linked registry entries, automatically remove invalid entries; Registry Defrag rebuilds and re-indexs your registry to reduce application response time and registry access time; smart uninstaller can uninstall and logoff installed programs neatly.
• Customization - Control what is started on Windows startup; edit context menus of mouse Right-Clicking; customize system desktop, menus, toolbar and notifications settings, change Windows logon background; change system icons; custom OEM information; automatically change your desktop wallpaper on background.
• Security - You can improve desktop, menus, control panel, windows logon securities, and enable numerous hidden performance options of system, disable system updates and error reports; hide and restrict to access drives, specify which applications are not allowed to be executed on your computer; encrypt/decrypt and shred files, camouflage folder to hide its content from Windows explorer, change the location of system folders; Privacy Protector can maintain your personal privacy by eliminating the tracks that you leave behind; create lots of randomization password once.
• Network - Optimize your Internet connection speed, manage all shares items, search for and find out opened ports on your system; Tweak your Internet Explorer easily; backup all data in Outlook Express; automatically check the invalid URLs in your favorites and parse domain name; Message Sender can easily send messages to others.
• Misc. Utilities - Show the collection of Windows utilities; control your computer when you're not at home; apply XP visual style to any Windows applications; appoint logging on time of any account users.
Kompletní øešení optimalizovat, štípnout, vyèistit windowsovský XP
WinXP Manager je nástroj pro nastavovací, optimalizace, diagnostický a štípající windowsovský XP. To balí víc než 30 jiné utility v jeden a pomáhají vašemu systému rychlejšímu a víc stabilnímu, bezpeènému a osobnímu! WinXP Manager pomáhá Vám optimalizovat, štípnout, a vyèistit windowsovský XP. To zvýší vaši systémovou rychlost, zlepšit ochranu systému, a setká se s vším vašich oèekávání.
Vy mùžete štípnout pamì a CPU nastavení, pøizpùsobíte IE nastavení, nález a odstraòovací odpadové soubory, šek a opravu váš registr, ovládat startovní programy, optimalizujte vaši rychlost spojení, potvrdit váš Favorites a mnohem víc. To také zahrnuje Auto - Optimization volbu, které dovoluje ménì zkušených uživatelù snadno optimalizovat jistá nastavení, používání mága. Rozhraní je snadno použitelné a veškeré dostupné volby jsou roztøídìné do sekcí. Zahrnuje základní dokumentaci a otravnou otravnou obrazovku která objevuje se každá nìkolik málo minut. To je sluèitelné s windowsovský XP SP3 zcela!
Rysy a výhod pro WinXP Manager:
• Informace - tropí si žerty detailní systém a všechno hardware informaci na vašem systému; pomáhá Vám abyste zjistili chybìjící registraèní kódy z Microsoft produkt; ukázat veškerou detailní informaci z bìžící procesy a niti na vašem stroji; WinXP Manager nabízí optimalizaènímu Wizard rys pro uživatele bez toho, mít nìjakou /každou /žádnou pokroèilou znalost.
• Optimizátor - štípnout váš systém k tomu, aby zlepšil okna startovní a pøerušení práci chvátat; monitorovat a uvolnìte váš Physical Memory; štípnout váš hardware zvýšit systémovou rychlost a výkonu; vyøadit nìjaké zbyteèné služby které zaèínat s okny; opravy Internet Explorer a jisté jiné prvky soustavy k tomu, aby obnovily tyto funkce.
• Èistírna - zjistí která soubory èi složky upoutat vaše místo na disku a ukázaná s grafem; Najdìte a èistý odpad, zbyteèné tapeta a obrazovkové soubory šetøièe k tomu, aby zvýšil místo na disku; Zdvojený Files Finder mùže skenovat váš poèítaè pro soubory se stejnou velikostí, jménem a èasem modifikace; Registraèní Cleaner mùže snadno šeky vaše registr a opravu nesprávnì spojené registraèní položky, automaticky odstranit neplatné zápisy; Registraèní Defrag znovu vystaví a znovu-indexuje váš registr k tomu, aby redukoval aplikaèní èas reakci a registraèní vybavovací èas; chytré odinstalování mùže odinstalovat a zrušení nainstalované programy úhlednì.
• Úprava - ovládat co je poèaté na windowsovském startu; editovat menu souvislost myši Right-kliknutí; pøizpùsobit systémový desktop, menu, lišta s nástroji a oznámení nastavení, zmìnit windowsovské navázání pozadí; zmìnit systém ikony; uživatelská OEM informace; automaticky mìòte vaši desktop tapetu na pozadí.
• Bezpeènost - vy mùžete zlepšit desktop, menu, ovládací panel, okna navázání cenné papíry, a umožnit èetné skryté výkonové volby systému, vyøadit systémové aktualizace a chybové zprávy; skrýt a omezte na zpøístupnit pohony, specifikujte které aplikace nejste považovaní za vykonaná na vašem poèítaèi; zakódovat/rozkódovat a roztrhané soubory, maskovací složka k tomu, aby skryla obsah z windowsovského prùzkumníka, zmìnit umístìní systémových složek; Soukromý Protector mùže udržovat vaše osobní soukromí vyluèujícími dráhami které vy zanecháte; vytvoøit mnoho pøíkazu pro vytvoøení náhodného èísla heslo jednou.
• Sí - optimalizuje vaši internetovou rychlost spojení, øiïte všechny akcie položky, pátrání po a zjistit svobodné pøístavy na vašem systému; Štípnìte váš Internet Explorer snadno; zálohování všechna data v Outlook Express; automaticky kontrolovat invalidní URLS ve vašich favoritech a rozebrat doménové jméno; Zpráva odesílatel mùže snadno zpravit jako ostatní.
• Misc. Utility - ukážou sbírku windowsovských utilit; ovládat váš poèítaè kdy nejsi doma; použít XP vizuální styl nìjakým /každým /žádným aplikacím pro Windows; stanovit zápis na èase nìjakých /každých /žádných uživatelù úètu.
 Predmet príspevku: Re: WinXP Manager 6.0.2
PoslaťNapísal: Uto 27. Okt 2009 19:47:10
