Aktuálny čas je Str 04. Nov 2026 6:28:46
 XP Tweaks Unlocked 1.1.0.0
 Predmet príspevku: XP Tweaks Unlocked 1.1.0.0
PoslaťNapísal: Pia 25. Sep 2009 9:55:13
XP Tweaks Unlocked is an excellent application that any Microsoft Windows user (whether beginner or advanced) will find useful when an improved Microsoft Windows experience is wanted. This software provides permanent, instant access to a wide range of Windows settings you can easily customize to help you save time and also work in a more suitable environment.Lay aside that tiresome search for a particular setting by going to Start Menu, Desktop, Internet Explorer, System Icon or System Security, because XP Tweaks Unlocked will now let you customize those countless settings all by yourself. This very complex program makes it easier than you would expect to give your Windows XP and Internet Explorer that fine-tuning you have been hoping for.With XP Tweaks Unlocked you get the best solution for tweaking and optimizing your Windows XP system at the same time saving CPU and RAM resources for those tasks you are unlikely to perform. The interface the program presents is simple allowing an easy navigation but still fancy enough to make the experience pleasant. You have the upper toolbar displaying multiple icons such as General, Services, IE, Windows Media Player, Usability; clicking on any of these icons will prompt the appearance of the sub-choices in the center pane.Get XP Tweaks Unlocked and take it for a spin to see what it can actually do for you!
Key features :-
· Start menu customization (both look and behavior)
· Tweaks hidden system performance settings
· Tweaks Desktop settings
· Changes paths to system folders
· Remote assistance
· Displays user and OEM information
· Fast shutdown
· Automatic Windows updates
· Error reporting
· Optimizes Internet connection speed
· Tweaks Internet Explorer
· Enables security policy editor
· Optimizes system cache
· Allows you to view and delete unwanted cookies.
XP Tweaks Unlocked je vynikající aplikace ty nějaké /každé /žádné Microsoft Windows uživatel (zda začátečník či pokročilý) shledávat užitečným kdy zlepšené Microsoft Windows zkušenost je sháněná. Tento software poskytuje stálý, instantní přístup k širokému okruhu windowsovských nastavení vy můžete snadno přizpůsobit pomoct vám ušetřit čas a také pracovat ve vhodnější prostředí.Ušetřete to únavné pátrání po specifickém nastavení chodící do startovní nabídky, desktopu, Internet Exploreru, Systémová ikona či ochrana systému, protože XP Tweaks Unlocked nyní nechá tě přizpůsobit ty nespočetná nastavení docela sám. Tento velice komplexní program dělá to snadnější než vy byste očekávali, že dát vašemu windowsovskému XP a Internet Exploreru kterému seřízení motoru vy jste doufali v.S XP Tweaks odemčený vy dostanete nejlepší řešení pro štípání a optimalizaci vašeho windowsovský XP zároveň ochranné výpisu dat CPU a RAM zdroje pro ty úkoly není pravděpodobné, že vy budete vykonávat. Rozhraní programové dárky jednoduchý dovolí snadnou navigaci přece však fantazie dost, aby přiměla zkušenost příjemnou. Vy máte horní lištu s nástroji zobrazování vícenásobných ikon jako generál, služby, IE, windowsovská mediální Player, použitelnost; kliknutí na každý z těchto ikon bude vybízet objevení se ponorky-voleb v centrální okenní tabuli.Dostaňte XP Tweaks Unlocked a vzít to pro rotaci k tomu, aby viděla co to může ve skutečnosti dělat pro vás!
Klíčové rysy :-
· startovní nabídková úprava (oba pohled a chování)
· Tweaks skrytá systémová výkonová nastavení
· Tweaks Desktop nastavení
· mění se cesty k systémovým složkám
· vzdálená pomoc
· zobrazuje uživatel a OEM informaci
· rychlé přerušení práce
· automatické Windows aktualizuje
· hlášení chyb
· optimalizuje internetovou rychlost spojení
· zmocněný bezpečnostní politický editor
· optimalizovat systémový cache
· dovoluje vám dívat se na a vymazat nechtěné koláčky.
:ahoj:
