Aktuálny čas je Pon 23. Nov 2026 17:02:25
 SLOW-PCfighter v1.0.93 Multilanguage
 Predmet príspevku: SLOW-PCfighter v1.0.93 Multilanguage
PoslaťNapísal: Ned 02. Aug 2009 20:17:21
Has your PC slowed down lately? Have you ever felt irritated and annoyed while sitting in front of your slow PC, impatiently staring at the screen? If you recognize any of this, don't panic! There are numerous reasons for slow PCs and any PC might get slower with time. It just means that your computer needs professional help! SLOW-PCfighter uses the most advanced technologies available to analyze PC errors and speed up a slow PC. SLOW-PCfighter seeks out and removes all unused entries in your registry from failed software, driver installations and faulty uninstallations and optimizes Windows startup.
* Extend the life of your PC
* SLOW-PCfighter is fast and easy to use
* SLOW-PCfighter helps to avoid system failure
* SLOW-PCfighter gets your system back in shape and running at maximum speed!
SLOW-PCfighter will speed up your PC by solving the following problems:
* Invalid paths
* Useless file extensions
* Obsolete software entries
* Invalid custom controls
* Invalid fonts
* Invalid file associations
* Non-existent shared dlls
* Non-existent startup programs
* Invalid add/remove programs
* Empty uninstall entries
* Empty registry keys
* Unused help files
* Etc. etc. etc. etc.
Get your PC Scanned now.
Repair errors
Enjoy faster PC
Fixing the errors and trying to speed up your PC manually can take a lot of your precious time and can be very risky too! If you somehow delete central files it can cause your system to crash!
Languages: English, German, French, Spanish, Italian, Dutch, Japanese, Czech, Swedish, Greek, Portuguese, Finnish, Polish, Thai, Bulgarian, Turkish, Chinese, Russian and Danish.
Má váš počítač zpomalil v poslední době? Už jste někdy pocit, podrážděné a rozmrzelí zatímco sedí v přední části vašeho pomalé PC, netrpělivě hledí na obrazovku? Pokud uzná jakoukoli toho, nepropadejte panice! Existuje mnoho důvodů pro pomalé počítače a jakéhokoli počítače může dostat pomalejším časem. To jen znamená, že váš počítač potřebuje odbornou pomoc! SLOW-PCfighter využívá nejvyspělejší technologie k PC analyzovat chyby a urychlit pomalý PC. SLOW-PCfighter vyhledává a odstraňuje všechny nevyužité vstupy do registru od selhal software, ovladače zařízení a vadné uninstallations a optimalizuje startu Windows.
Vlastnosti:
* Prodloužit životnost vašeho PC
* SLOW-PCfighter je rychlé a snadné použití
* SLOW-PCfighter pomáhá vyhnout selhání systému
* SLOW-PCfighter dostane váš systém zpět do tvaru a běží na maximální rychlost!
SLOW-PCfighter urychlí vaše PC při řešení těchto problémů:
* Neplatné stezky
* Useless souborů
* Zastaralé software položky
* Neplatné uživatelské kontroly
* Neplatné písma
* Neplatný soubor sdružení
* Neobchodovatelné-existent sdílených knihoven DLL
* Neobchodovatelné-existent spouštění programů
* Neplatné Přidat / Odebrat programy
* Vyprázdnit odinstalovat položky
* Vyprázdnit klíče registru
* Nepouľité souborech nápovědy
* Atd. atd. atd. atd.
Získejte PC Scanned nyní.
Opravy chyb
Užijte si rychlejší PC
Stanovení chyby a snaží urychlit svůj počítač manuálně může trvat hodně svůj drahocenný čas a může být velmi riskantní, příliš! Pokud jste nějak odstranit centrální souborů může způsobit váš systém ke zhroucení!
Jazyky: angličtina, němčina, francouzština, španělština, italština, holandština, japonština, čeština, švédština, řečtina, portugalština, finština, polština, thajština, bulharština, turečtina, čínština, ruština a dánština.
