Aktuálny čas je Uto 03. Nov 2026 20:45:41
 Drive Snapshot 1.39.14227
 Predmet príspevku: Drive Snapshot 1.39.14227
PoslaťNapísal: Str 10. Jún 2009 19:18:07
Drive Snapshot creates an exact Disk Image of your system into a file, including the operating system, installed programs, your data and all security attributes - while windows is running and you continue to work. Drive Snapshot it allows you to backup your partition or your hard disk drive and it also can create a disk image of your system. If disaster strikes (a virus, trojan, or hard disk crash), a complete and exact restauration of your system will be possible in only few minutes. The image file can be mounted as a virtual drive, so you can easily restore (or use) single files or directories, using the Windows Explorer, or other program.
Here are some key features of "Drive Snapshot":
• Create Disk Image Backups, while running Windows
• There is no restart (to DOS) necessary. Never.
• Continue your work, while the Backup is in progress
• The new Snapshot technology ensures, that all data are consistent, and reflect the PC's data at the start of backup. There are no difficulties with opened files. Never.
• This enables a very fast and easy way to backup servers and other computers, that must run 24 hours a day.
• Easy Use and Restore of single Files or directories
• Drive Snapshot creates a virtual drive, containing all your drives data. You may use, compare, or restore these files directly from the Disk Image file.
• This works with any program of your choice, including (of course) the Windows Explorer
• Complete Restore of a disk in case of Disaster
• If a disk is restored to it's original state, it will be exactly the same as at the time of Backup - byte for byte.
• Restoring a system partition will require DOS; other drives can be restored using Windows
• Compatible to all Windows file systems (FAT16, FAT32, NTFS)
• Compatible to all Windows RAID Methods
• Very easy and comprehensive command line interface
• This makes automation of regular tasks a breeze.
OS: Windows NT 4.0 Service pack 3, Windows 2000, Windows XP, Windows 2003 Server, Windows PE, Vista.
Drive Snapshot vytvoří přesný obraz disku vašeho počítače do souboru, včetně operačního systému, nainstalovaných programů, data a všechny bezpečnostní atributy - zatímco Windows běží a bude i nadále pracovat. Drive Snapshot je vám umožní zálohovat váš oddíl nebo pevný disk a také můžete vytvořit obraz disku vašeho počítače. Pokud udeří katastrofa (virus, trojský kůň, nebo pevný disk crash), kompletní a přesnou obnovu svého systému bude možné pouze několik minut. Obrázek, může být připojen jako virtuální disk, takže můžete snadno obnovit (nebo užívání) jednotný soubory či adresáře, pomocí Průzkumníku Windows nebo jiný program.
Zde jsou některé klíčové rysy "Drive Snapshot":
• Vytvořte Disk Image zálohování, zatímco s operačním systémem Windows
• Neexistuje žádný restart (pro DOS) nezbytné. Nikdy.
• pokračovat v práci, zatímco zálohování probíhá
• Nová Snapshot technologie zajišťuje, že všechny údaje jsou shodné, a odrážejí PC údajů na začátku zálohu. Nejsou žádné problémy s otevřené soubory. Nikdy.
• To umožňuje velmi rychlý a snadný způsob pro zálohování serverů a dalších počítačů, které musí běžet 24 hodin denně.
• Snadné použití a obnovení jednotného soubory či adresáře
• Drive Snapshot vytváří virtuální disk, který obsahuje všechny vaše disky data. Můžete používat, porovnat, nebo obnovit tyto soubory přímo z disku soubor s obrázkem.
• Tento program pracuje s jakoukoli Vaší volby, včetně (samozřejmě) v Průzkumníku Windows
• Kompletní Obnovit z disku v případě katastrofy
• Pokud je disk obnovit do původního stavu je to, že bude úplně stejná jako v době zálohování - bajt pro bajt.
• Obnovení systému oblast bude vyžadovat DOS, ostatní disky lze obnovit pomocí Windows
• kompatibilní se všemi Windows souborové systémy (FAT16, FAT32, NTFS)
• kompatibilní se všemi Windows RAID metody
• Velmi jednoduché a komplexní rozhraní příkazové řádky
• To znamená, automatizace pravidelných úkoly by vítr.
OS: Windows NT 4.0 Service Pack 3, Microsoft Windows 2000, Windows XP, Windows 2003 Server, Windows PE, Vista.
 Predmet príspevku: Re: Drive Snapshot 1.39.14227
PoslaťNapísal: Uto 03. Nov 2009 15:25:45
