Aktuálny čas je Pia 23. Okt 2026 17:48:50
 NetScream 1.3.23.2009 Cracked
 Predmet príspevku: NetScream 1.3.23.2009 Cracked
PoslaťNapísal: Uto 24. Mar 2009 12:57:41
Boosts your modem, DSL, cable, ISDN or satellite internet speed by up to 200%
NetScream will modifiy your modem options, so those annoying disconnections and hang-ups will happen less often.
Enhance the speed of your internet connection with NetScream. One of the best modem enhancers on the market, it boosts download and upload speeds your modem is capable of.
Very easy to use, fully compliant with all versions of Microsoft Windows and compatible with all internet connection types. Download music, movies and play internet games faster.
Makes direct changes to system registry and system files to enhance internet download and upload speeds.
Automatically adjusts settings and changes made based on computer and modem specifications, complete fault tolerance system implemented.
NetScream is a tool for all that allows you to modify your modem settings to increase internet performance up to 200% or higher!!
No modifications to your hardware are made and all adjustments and settings are done in an easy to use interface that a child could use.
Most other modem enhancers promise that they work while you notice no difference at all in internet speed. On the contrary, this software has been intensely tried and tested and proven to actually work.
Whether you use a 14.4/28.8/33.6/56k modem, cable modem, or DSL modem, NetScream will boost your internet connection speed.
Notice also that NetScream will modify your modem settings to handle those annoying disconnections and hang-ups so they happen less often. You no longer have to put up with downloading a huge file and being disconnected in the middle of the transfer.
Here are some key features of "NetScream":
· Enhances both internet transfer speeds as well as local area network speeds.
· Easy and intuitive user interface which performs all setting changes immediately
· Microsoft Internet Explorer 4 or higher
· Intel Pentium 90 MHz or Compatible
· 8 Mb RAM (32 Mb recommended)
· 5 Mb hard disk space
· VGA or higher resolution monitor
· Mouse or other pointing device
Podporuje váš modem, DSL, kabel, ISDN či satelitní internetová chvátat na 200%
NetScream bude přizpůsobitelnost vaše modem volby, tak ti, kdo jsou otravná odpojení a úbočí-povýšenec se stanou méně často.
Zvyšte rychlost vašeho internetového spojení s NetScream. Jeden z nejlepších modemu zvětšovačů na trhu, to podporuje download a upload chvátá váš modem je schopný.
Velmi snadno použitelný, plně vyhovující se všemi verzemi Microsoft Windows a kompatibilní se všemi internetovými spojením druhy. Stáhněte hudbu, filmy a zábavné internetové hry rychleji.
Dělá přímé změny systémovým registru a systémovým souborům k tomu, aby zvětšily internetový download a upload chvátá.
Automaticky nastavuje nastavení a změny udělaly založený na počítačových a modemu specifikacích, kompletní systém odolnosti implementované.
NetScream je nástroj přesto dovoluje vám modifikovat vaše nastavení modemu zvýšit internetový výkon až do 200% či vyšší!!
Žádné modifikace vašemu hardwaru jsou udělané a všechny upravení a nastavení jsou udělané v snadno použitelném rozhraní které dítěti mohlo užívat.
Většiny jiných modemu zvětšovačů slibují že oni pracují zatímco vy všimnete si ne ve všech rozdílu mezi internetovou rychlostí. Naopak, tento software byl intenzivně osvědčený a testovaný a prokázaný ve skutečnosti pracovat.
Zda vy užíváte 14.4/28.8/33.6/56k modem, kabelový modem, či DSL modem, NetScream bude podporovat vaši internetovou rychlost spojení.
Všimněte si také NetScream bude modifikovat vaše nastavení modemu ovládat ti, kdo jste otravní odpojení a úbočí-povýšenci tak oni se stávají méně často. Vy musíte již ne déle snášeli stahování obrovského souboru a být odpojený uprostřed transferu.
Zde jsou nějaké klíčové rysy "NetScream":
· zvětšete obojí internetový transfer rychlost stejně jako lokální síť rychlost.
· snadné a intuitivní uživatelské rozhraní které vykonává veškeré nastavení mění ihned
· Microsoft Internet Explorer 4 či vyšší
· Intel Pentium 90 MHZ či kompatibilní
· 8 Mb RAM (32 Mb doporučil)
· 5 Mb místo na disku
· VGA či vyšší rozlišovací monitor
· myš či jiný směřující k zařízení
