Aktuálny čas je Str 09. Sep 2026 19:58:23
 Dr.Dolittle Goin' Hollywood (2008)
 Predmet príspevku: Dr.Dolittle Goin' Hollywood (2008)
PoslaťNapísal: Pia 20. Mar 2009 17:43:20
Registrovaný: Sob 24. Jan 2009 12:19:53
Dr.Dolittle.Goin.Hollywood.2oo8.DVDRip.XviD.CZ-PODiUM
Czech Dabing
Dr Dolittle Goin' Hollywood
Komedie
2008, 90 min
Režie: Alex Zamm
Hrají: Kyla Pratt
Type. Movie
Length : 700 / 1h 23mn
Video #0 : XviD at 1125 Kbps
Aspect : 624 x 336 (1.857) at 25.000 fps
Audio #0 : MPEG-1 Audio layer 3 at 32 Kbps
Infos : 2 kanály, 48 KHz
DOWNLOAD:
Bez Hesla:
 Predmet príspevku: Re: Dr.Dolittle Goin' Hollywood (2008)
PoslaťNapísal: Ned 05. Apr 2009 20:55:05
Upoloader++
Upoloader++
Dr Dolittle Goin' Hollywood (2008) PODiUM
PoslaťNapísal: Sob 26. Dec 2009 10:17:50
Upoloader++
Upoloader++
Registrovaný: Sob 26. Dec 2009 9:57:45
Hotovosť: 165.00
Komedie
2008, 90 min
Režie: Alex Zamm
Hrají: Kyla Pratt
File size : 679 MiB
Duration : 1h 23mn
Overall bit rate : 1 143 Kbps
Writing application : Nandub v1.0rc3
Writing library : Nandub build 2079/release
Format : MPEG-4 Visual
Format profile : Streaming Video@L1
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, Matrix : Default (MPEG)
Muxing mode : Packed bitstream
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 1h 23mn
Bit rate : 1 057 Kbps
Width : 624 pixels
Height : 336 pixels
Display aspect ratio : 1.857
Frame rate : 25.000 fps
Resolution : 24 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.202
Writing library : XviD 1.1.2 (UTC 2006-11-01)
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Codec ID : 55
Codec ID/Hint : MP3
Duration : 1h 23mn
Bit rate mode : Constant
Bit rate : 32.0 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Resolution : 16 bits
Video delay : 480ms
Alignment : Split accross interleaves
Heslo: vlk 1
