Aktuálny čas je Štv 29. Okt 2026 20:54:35
 Xilisoft DVD Copy Express v1.1.29 build 0220 - NEW
 Predmet príspevku: Xilisoft DVD Copy Express v1.1.29 build 0220 - NEW
PoslaťNapísal: Str 11. Mar 2009 10:18:01
Xilisoft DVD Copy Express is a stable, fast, and easy-to-use DVD Copy application which will provide the best way to copy DVD and backup DVD movies with excellent copy quality. And compared with other similar software, It has more attractive functions and features:
Main Functions:
■ DVD Copying, DVD burning, Backup DVD, Clone DVD software.
■ Support copying DVD-5 to DVD-5, DVD-9 to DVD-9, DVD-9 to DVD-5.
■ Copy DVD-9 to DVD-5: Compress DVD-9 (Dual layer 8.5GB disc) movie and copy it to one regular DVD-5 (4.7GB) DVD-R/RW, DVD R/RW with excellent copy quality.
■ Built-in CSS decryption: Copy DVD Movie with CSS-decryption built-in, you can freely remove the CSS-encryption using integrative CSS decryption.
■ Remove Region Codes of movie DVDs: Create all region codes movie DVD Copys then feel free to enjoy your favorite DVD movies anywhere around the world.
■ Backup DVD to Hard Drive Disk: Copy DVD movie to ISO file or DVD folder;
■ Burn ISO File and DVD Folder to DVDs.
Xilisoft DVD Copy Express will provide you with a new experience in DVD coping with its fast speed, wonderful quality, and full functionality.
Here are some key features of "Xilisoft DVD Copy Express":
· Copy DVD in 1:1 ratio: Xilisoft DVD Copy Express can copy whole DVD disc perfectly including titles, menus, subtitles and audio tracks. Support DVD-9 to DVD-9, DVD-5 to DVD-5 in 1:1 ratio;
· Support Dual Layer DVD: The DVD copy program could losslessly copy whole DVD-9 movie to 8.5GB Dual Layer recordable media (DVD R/RW, DVD-R/RW) in 1:1 ratio;
· Customers could create Customized DVD Copy: The DVD Copy program also allow you to to select subtitles or audio tracks to create customized DVD copy and optionally remove DVD menus and copy the main movie separately to preserve any you want;
· Provide High Flexibility: Xilisoft DVD Copy Express supports both NTSC and PAL DVD movie copying. It works well with DVD -R/RW, DVD-RAM, most DVD players and burners, and Dual Layer 8.5GB disc;
· Clone DVD software: The DVD to DVD copy software is also clone DVD software because of copying whole DVD movie to DVD in 1:1 ratio;
· Provide Multi-language and featured skins for your choice.
· Processor: CPU: >750MHz Intel or AMD CPU
· Free Hard Disk Space: 100 MB or more
· Cache Space: 10 GB or more in the temporary folder
· Optical Drive: One DVD-ROM Burner at least
· Optical Medium: DVD-5, DVD-9, DVD-R(W), DVD R(W) and DVD-R DL, DVD R DL, DVD-RAM, ISO file and Hard Disk Drive
· Disk Formats: DVD-5(4.7G), DVD-9(8.5G)
Xilisoft DVD Copy Express je stáj, rychlý, a snadno použitelný DVD Copy aplikace která poskytne nejlepší způsob jak kopírovat DVD a záložní DVD filmy - vynikající kopírovací kvalitou. A ve srovnání s jiným podobným softvérem, to má atraktivnější funkce a rysy:
Hlavní funkce:
? DVD Copying, DVD hoření, záložní DVD, klon DVD software.
? Podporujte kopírování DVD-5 DVD-5, DVD-9 DVD-9, DVD-9 DVD-5.
? Kopírovací DVD-9 DVD-5: Stlačte DVD-9 (dvojitá vrstva 8.5GB disk) film a kopíruje to na jeden pravidelný DVD - 5 (4.7GB) DVD-R/RW, DVD R/RW s vynikající kopírovací kvalitou.
? Zabudované CSS rozluštění: Kopírovací DVD Movie s CSS-DECRYPTION zabudovaný, vy můžete volně odstranit CSS-ENCRYPTION používání integračního CSS rozluštění.
? Odstraňovací Region Codes z filmový DVDS: Vytvořte veškeré územní kódy filmové DVD Copys pak bez obav těšit se z vašich oblíbených DVD filmů kdekoli kolem světa.
? Záložní DVD tvrdému hnacímu disku: Kopírovací DVD film k ISO souboru či DVD složce;
? Vypalte ISO soubor a DVD složku k DVDS.
Xilisoft DVD Copy Express poskytnou vám novou zkušenost s DVD zvládáním s jeho rychlou rychlostí, báječná kvalita, a plná funkčnost.
Zde jsou nějaké klíčové rysy "Xilisoft DVD kopírovací expres":
· kopírujte DVD v 1:1 procento: Xilisoft DVD Copy Express mohou kopírovat celý DVD disk včetně výlučných vlastnických práv, menu, titulky a zvukové stopy. Podpůrný DVD-9 DVD-9, DVD-5 DVD-5 v 1:1 procento;
· podporujte dvojitou vrstvu DVD: DVD Kopírovací program mohl bezeztrátový kopírovat celý DVD-9 film k 8.5GB dvojitá vrstva písemná uznání břemene média (DVD R/RW, DVD-R/RW) v 1:1 procento;
· zákazníci mohli vytvořit zákaznicky přizpůsobené DVD Copy: DVD Copy program také vám dovolí vybrat titulky či zvukové stopy k tomu, aby vytvořily zákaznicky přizpůsobenou DVD kopii a volitelně odstranit DVD menu a kopírovat hlavní film odděleně uchovat nějaký /každý /žádný vás chcete;
· poskytujte vysokou flexibilitu: Xilisoft DVD Copy Express podporuje oba NTSC a PAL DVD film kopírování. To pracuje dobře s DVD -R/RW, DVD-RAM, největší DVD PŘEHRÁVAČE a hořáky, a Dual Layer 8.5GB disk;
· klon DVD software: DVD DVD kopírovat software je také klon DVD software kvůli kopírovacímu celému DVD filmu k DVD v 1:1 procento;
· poskytujte Multi - language a uváděné kůže pro vaši volbu.
· procesor: CPU: >750MHz Intel či AMD CPU
· volné místo na disku: 100 MB nebo více
· cache prostor: 10 GB nebo více v dočasné složce
· optický pohon: Jeden DVD-ROM hořák přinejmenším
· optický prostředek: DVD-5, DVD-9, DVD-R(W), DVD R(W) a DVD-R DL, DVD R DL, DVD-RAM, ISO soubor a harddisk
· disk formátuje: DVD-5(4.7G), DVD-9(8.5G)
