Aktuálny čas je Pon 23. Nov 2026 21:55:01
 Zakletý v čase / The Time Travelers Wife (2009)
 Predmet príspevku: Zakletý v čase / The Time Travelers Wife (2009)
PoslaťNapísal: Pia 01. Jan 2010 10:53:40
Registrovaný: Sob 14. Nov 2009 18:57:53
Hotovosť: 1,170.00
The Time Travelers Wife 2009 DVDRip XviD-iMBT
A Chicago librarian suffers from a rare genetic disorder that sends him hurtling through time whenever he is under extreme duress; despite the fact that he vanishes at inordinately frequent and lengthy intervals, he attempts to build a stable future with the beautiful young heiress he loves. Eric Bana and Rachel McAdams star in this dramatic fantasy, which is directed by Robert Schwentke and based on the best-selling book by author Audrey Niffenegger.
Clare has been in love with Henry her entire life. She believes they are destined to be together, even though she never knows when they will be separated: Henry is a time traveler--cursed with a rare genetic anomaly that causes him to live his life on a shifting timeline, skipping back and forth through his lifespan with no control. Despite the fact that Henry's travels force them apart with no warning, Clare desperately tries to build a life with her one true love.
Ratings: IMDB: 7.2/10 6,763 votes
Genre: Drama | Romance | Sci-Fi
Directed by: Robert Schwentke
Starring: Michelle Nolden, Alex Ferris, Arliss Howard, Eric Bana, Katherine Trowell, Bart Bedford, Esther Jun
Language: English
First Cinematic Release: 14 August 2009 (USA)
Release Name: The.Time.Travelers.Wife.2009.DVDRip.XviD-iMBT
Video: XviD @ 770 Kbps - 640x272px (WxH) - AR: 2.35:1 - FPS:
Audio: MP3 @ 130Kbps (Variable) - 2 channels
Runtime: 1:47:25
Filename: the.time.travelers.wife.dvdrip.xvid-imbt
IMDB:
Hellshare Download:(1x700MB)
Rapidshare Download:(3x200MB 1x130MB)
 Predmet príspevku: Re: Zakletý v čase / The Time Travelers Wife (2009)
PoslaťNapísal: Sob 02. Jan 2010 15:46:05
Registrovaný: Sob 28. Feb 2009 18:08:02
Hotovosť: 80.00
The.Time.Travelers.Wife.TS.Subbed.XVID-IMAGiNE
CSFD:
Knihovník Henry (Eric Bana) trpí zvláštní genovou poruchou - chronickou dislokací v čase. Může nedobrovolně cestovat časem - ve stresujících situacích najednou prostě zmizí a objeví se úplně nahý v minulosti nebo budoucnosti, obvykle na místech nebo u osob, které jsou nebo byly v jeho životě důležité. Z jeho úhlu pohledu poprvé potkal svoji ženu Claire (Rachel McAdams), když mu bylo 28 a jí 20. Při jejich prvním setkání mu Claire tvrdí, že ho zná celý její život, ale on si nemůže vzpomenout, že by ji někdy předtím viděl. Až když mu je 40 a už je dávno s Claire ženatý, cestuje časem do Claiřina dětsví a setká se s ní, když jí bylo 6 let. Od té doby se pravidelně na svých toulkách časem vrací do Claiřina dětství, což má následky pro oba dva. Film kombinuje vášnivou milostnou romanci s prvky sci-fi.
DETAILS:
Format : MPEG-4 Visual
Format profile : AdvancedSimple@L5
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, Matrix : Custom
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 1h 38mn
Bit rate : 1 937 Kbps
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 1.500
Frame rate : 29.970 fps
Standard : NTSC
Resolution : 24 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.187
Stream size : 1.33 GiB (93%)
Writing library : XviD 1.2.1 (UTC 2008-12-04)
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Codec ID : 55
Codec ID/Hint : MP3
Duration : 1h 38mn
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Resolution : 16 bits
Stream size : 90.0 MiB (6%)
Alignment : Aligned on interleaves
Interleave, duration : 33 ms (1.00 video frame)
Interleave, preload duration : 417 ms
Obrázok Obrázok
Obrázok Obrázok
Citácia:
No Pass!!!
