Aktuálny čas je Pia 23. Okt 2026 12:31:07
 Reg Organizer v4.21 Final
 Predmet príspevku: Reg Organizer v4.21 Final
PoslaťNapísal: Uto 08. Dec 2009 19:09:10
Reg Organizer® is an extensive and extremely powerful set of registry tools required for effective system registry management. This software lets you view, edit, and safely clean the registry. It allows you to preview the registry files you want to import (including the ability to preview files directly from Windows Explorer) and supports editing the contents of the registry files. It includes registry cleaner, which will safely compact, repair, and optimize the registry.
With Reg Organizer you can thoroughly search the registry to find all the keys related to a certain application - Reg Organizer does this job quicker and better than other similar programs. Other Reg Organizer features include the ability to find and replace the registry entries, automatic registry cleanup, Disk Cleanup tool, access to many undocumented Windows features. Plug-in expandability gives unlimited possibilities of third party enhancements.
* Registry editor for viewing and editing the system registry, manipulating the registry keys and values, exporting, importing, copying them, etc.
* The registry cleaner of Reg Organizer can detect many types of registry errors. These include searching the registry for invalid references to files, folders and DLLs; invalid uninstallation data; finding obsolete and invalid file extensions and other issues. Reg Organizer can repair many of these registry problems.
* Registry search feature can find all keys related to a certain application and delete them, if necessary. This feature can be useful if you manually delete some application that has no uninstall feature. In this case its keys can be left in the registry interfering with the normal operation of other programs. Reg Organizer provides the deepest search and can often find even those keys, that wouldn't be identified by other similar programs.
* Defragmenting and compressing the registry: Increase the performance of the registry and consequently the overall performance of your system.
* Ablilty to change many undocumented Windows settings (tweaks). In particular, it can accelerate the work of your system by sending the system a command to increase cache memory size or by unloading unused libraries, etc.
* Ability to get information about any selected registry key and monitor changes of the specific keys.
* Preview of the registry files (*.reg) before adding their contents to the system registry. The files can be viewed directly from Windows Explorer. Reg Organizer presents the file contents in the tree-like form, helping to visualize all keys that will be imported into the registry.
* Functional registry file editor, allowing you to edit keys and values, add and delete data containing in the .reg files.
* Provide quick access to all of the programs that are automatically started when you turn on or logon to your computer. Using Reg Organizer, you can inspect, edit, or disable such programs.
* Registry search and replace mode offers you a variety of options for searching the registry and replacing the records matching the specified criteria.
* Built-in software uninstaller. It can take snapshots before and after application installs and eradicate ALL system changes made by an app like it was never installed. Besides, this feature can be used for displaying changes made by the application to each of the system components.
* Disk Cleanup tool lets you automatically remove unnecessary files from the hard drive of your computer, and to search for and fix invalid shortcuts.
RegOrganizer v4.21 Final.rar (2,3 MB)
Reg Organizátor ® je rozsáhlý a velmi výkonný soubor registru nářadí potřebné pro efektivní řízení systémového registru. Tento software umožňuje zobrazit, upravit a bezpečně čisté registru. To vám umožní prohlédnout soubory registru, který chcete importovat (včetně možnosti náhledu souborů přímo z Windows Exploreru) a podporuje editaci obsahu souborů registru. Obsahuje čistič registru, který bude bezpečně kompaktní, opravy a optimalizovat registr.
S nařízením Pořadatel si můžete důkladně prohledat registru najít všechny klíče, vztahující se k určité aplikace - Reg Organizátor to práci rychleji a lépe než jiné podobné programy. Ostatní Reg Organizátor vlastnosti patří schopnost najít a nahradit položky registru, automatické čištění registru, Vyčištění disku, přístup k mnoha nelegální funkce systému Windows. Plug-in rozšíření dává neomezené možnosti rozšíření třetích stran.
* Registry editor pro prohlížení a editaci systémového registru, manipulační klíče registru a hodnoty, vývozu, dovozu, jejich kopírování, atd.
* Registru čistič Reg Organizátor může objevit mnoho typů registru chyb. Patří mezi ně hledání registru neplatné odkazy na soubory, složky a DLL; neplatná odinstalace dat, hledání zastaralých a neplatných přípon souborů a dalších otázkách. Reg Organizátor může opravit mnohé z těchto problémů registru.
* Vyhledávání Registry funkci lze najít všechny klíče spojené s určitou aplikací a odstranit, pokud je to nezbytné. Tato funkce může být užitečná, pokud jste ručně odstranit některé aplikace, které nelze odinstalovat. V tomto případě se jeho klíče mohou být ponechány v registru narušení normálního provozu jiných programů. Reg Pořadatel poskytuje nejhlubší vyhledávání a lze často najít i ty klíče, které by neměly být určeny jiné podobné programy.
* Defragmentace a komprese registru: Zvýšení výkonu registru a následně celkový výkon systému.
* Ablilty změnit nastavení mnoha nelegální Windows (tweaks). Zejména může urychlit práci systému zasláním systému příkaz ke zvýšení velikosti vyrovnávací paměti nebo vykládání nepoužívané knihovny, atd.
* Schopnost získat informace o všech vybraný klíč registru a sledování změn v konkrétních kláves.
* Náhled souborů registru (*. reg) před přidáním jejich obsah v systémovém registru. Soubory lze prohlížet přímo z Windows Exploreru. Reg Organizátor představuje obsah souboru ve stromu-jako forma, pomáhá vizualizovat všechny klávesy, které budou dováženy do registru.
* Funkční souboru registru editoru, což vám umožní upravit klíče a hodnoty, přidávat a odstraňovat data obsahující. Reg soubory.
* Zajistit rychlý přístup ke všem programům, které se automaticky spustí při zapnutí nebo přihlášení k počítači. Použití Reg Organizer můžete prohlédnout, upravit nebo zakázat takové programy.
* Registru vyhledávání a nahrazování mód nabízí celou řadu možností pro hledání a nahrazení rejstříku trestů odpovídá určitá kritéria.
* Built-in software uninstaller. To může trvat snímky před a po aplikaci nainstaluje a vymýtit všechny systémové změny, které aplikace, jako by nikdy nebyl nainstalován. Kromě toho je možné tuto funkci použít pro zobrazení změn provedených aplikace pro každou z komponent systému.
* Nástroj Vyčištění disku umožňuje automaticky odstraní nepotřebné soubory z pevného disku vašeho počítače, a hledat a opravit neplatné zkratky.
 Predmet príspevku: Re: Reg Organizer v4.21 Final
PoslaťNapísal: Uto 08. Dec 2009 23:11:46
