Aktuálny čas je Uto 21. Apr 2026 0:41:07
 W@ndows 7 Ultimate Live Cd
 Predmet príspevku: W@ndows 7 Ultimate Live Cd
PoslaťNapísal: Pia 15. Jan 2010 8:40:33
Windows 7 Live CD - The operating system, loaded from removable media (CD, DVD, USB-drive, etc.), does not require installation to operate on the hard disk.
The same concept and supports refer to these operating systems.
Windows 7 Live CD allows you to quickly start working with a computer, avoiding the lengthy process of installing the operating system in a permanent memory of a computer - the hard drive.
Release Date: 2010
Platform: x86-32 | x86-64 | EM64T
Bit operating system: 32 bits
Language: English
License Status: Cracked
Format: .ISO (Bootable) PE
Running Live CD usually takes a few minutes at a time, as the first launch of the traditional operating system often requires several hours.
Featues:
- Recovering after failures:
Another application of Windows 7 Live CD - the restoration of data and / or efficiency core operating system after failure. It allows you to work with the computer when the primary operating
- Work on multiple computers:
Another advantage of Windows 7 Live CD is a convenience if you move. For example, you can get Windows 7 Live CD with you if you need some time to work on another computer. That way you can on any computer (with CD-ROM) easy access to familiar operating system, and not to be afraid of harming someone else's system and others' data while working.
- Diskless computers and computers with small drives:
Windows 7 Live CD can be used on computers with no hard drive (which is very rare) and on computers with hard disk drive very small amount (which is also rare).
Embedded tools:
- Standard applications:
+ WordPad
+ Calculator
+ Paint
+ Notebook
- Games:
+ PinBall
+ Frecell
+ Conect 4
-System tools:
+ Copy a disk (floppy)
+ A43 File Managment Utility (instead of wire)
+ Bart Stuff Test
+ Total Commander
+ System Restore
+ Remote Descktop Connection (Remote Desktop)
+ Drive Snapshot
+ Cpu-Z
+ On Screen Keyboard
+ Reg Editor
+ Task Manager (Task Manager)
+ Windows Help
+ Nu2Menu
+ Everest Advanced System Information
+ DiskPart
+ Check Disk
+ Matrix Screensaver
+ CMD (command line)
+ RUN (execute)
- System requirements:
+ Processor
+ Mouse / Keyboard
+ Display with at least 800x600 resolution and 32 bit colors
How to install:
1.Take the ISO file and burn it to a cd
2. Boot from cd and boom! Your done =o
Alebo ... !!!
Bez hesla volne dostupný materiál...!!!
Windows 7 Live CD - operační systém, nahrání z výměnných médií (CD, DVD, USB-disku apod.), není nutné instalovat pro provoz na pevném disku.
Stejná koncepce a podporuje odkazují na těchto operačních systémech.
Windows 7 Live CD vám umožní rychle začít pracovat s počítačem, aby se zabránilo zdlouhavým procesem instalace operačního systému v trvalé paměti počítače - pevný disk.
Datum vydání: 2010
Platforma: x86-32 | x86-64 | EM64T
Bitový operační systém: 32 bitů
Jazyk: angličtina
Licenční Status: Prasklý
Formát:. ISO (Bootable) PE
Spuštění Live CD obvykle trvá několik minut, v době, jako první zahájení tradičního operačního systému často vyžaduje několik hodin.
Featues:
- Obnovení po selhání:
Jinou aplikací Windows 7 Live CD - obnova dat a / nebo účinnosti jádra operačního systému po výpadku. To vám umožní pracovat s počítačem, když primární operační
- Práce na více počítačích:
Další výhodou Windows 7 Live CD je výhodné, pokud se pohybujete. Například, můžete získat Windows 7 Live CD s vámi, pokud budete potřebovat nějaký čas pracovat na jiném počítači. Tímto způsobem můžete na jakémkoliv počítači (s CD-ROM) snadný přístup na známé operační systém, a ne se bát poškození někoho jiného systému a další data 'při práci.
- Příjemnou možností je bezdisková počítače a počítače s malými pohony:
Windows 7 Live CD je možné použít na počítačích bez pevného disku (což je velmi vzácný) a na počítačích s pevným diskem velmi malé částky (který je také vzácná).
Embedded nástroje:
- Standardní aplikace:
+ WordPad
+ Kalkulačka
+ Paint
+ Notebook
- Hry:
+ Pinball
+ Frecell
+ 4 CONECT
-Systémové nástroje:
+ Kopírovat disk (disketa)
+ A43 souborů Management Utility (místo drátu)
+ Bart Stuff Test
+ Total Commander
+ Obnovení systému
+ Připojení ke vzdálené Descktop (Remote Desktop)
+ Drive Snímek
+ CPU-Z
+ Reg Editor
+ Správce úloh (Task Manager)
+ Windows Help
+ Nu2Menu
+ Everest Advanced System Informace
+ DiskPart
+ Check Disk
+ CMD (příkazový řádek)
+ RUN (execute)
- Systémové požadavky:
+ Procesor
+ Myš / klávesnice
+ Displej s rozlišením alespoň 800x600 a 32 bitové barvy
Jak nainstalovat:
1.take ISO soubor a vypálit na cd
2. Boot z CD a bum! Vaše done = o
