Aktuálny čas je Štv 22. Okt 2026 7:31:55
 Wireless Hacking Live - FBI Version iso
 Predmet príspevku: Wireless Hacking Live - FBI Version iso
PoslaťNapísal: Štv 12. Nov 2009 10:00:49
This version is for all systems except systems with the Intel B/G wireless cards (IPW2200).- Live CD with all the tools you need to hack a WLAN / wireless Access point - Linux Live-CD - OS runs from CD - 635 mb - .iso
- also used by the FBI.
WEP Hacking - The Next Generation
WEP is an encryption scheme, based on the RC-4 cipher, that is available on all 802.11a, b and g wireless products. WEP uses a set of bits called a key to scramble information in the data frames as it leaves the access point or client adapter and the scrambled message is then decrypted by the receiver.
Both sides must have the same WEP key, which is usually a total of 64 or 128 bits long. A semi-random 24 bit number called an Initialization Vector (IV), is part of the key, so a 64 bit WEP key actually contains only 40 bits of strongencryption while a 128 bit key has 104. The IV is placed in encrypted frames header, and is transmitted in plain text.
Traditionally, cracking WEP keys has been a slow and boring process. An attacker would have to capture hundreds of thousands or millions of packets—a process that could take hours or even days, depending on the volume of traffic passing over the wireless network. After enough packets were captured, a WEP cracking program such as Aircrack would be used to find the WEP key.
Fast-forward to last summer, when the first of the latest generation of WEP cracking tools appeared. This current generation uses a combination of statistical techniques focused on unique IVs captured and brute-force dictionary attacks to break 128 bit WEP keys in minutes instead of hours. As Special Agent Bickers noted, It does'nt matter if you use 128 bit WEP keys, you are vulnerable!
An attacker would have to capture hundreds of thousands or millions of packets a process that could take hours or even days, depending on the volume of traffic passing over thewireless network.
Basic Directions:
1)Boot from cd
2)get the wep key
3)write it down
4)reboot into windows
5)connect using wep key.
Toto prosím nie je náš upload, ale napriek tomu Vám to dodávam, lebo sa to zdá byť velice zaujímavo kvalitný produkt od Belgičanov...
Bezdrátové Hacking Live - FBI Version iso
Tato verze je pro všechny systémy s výjimkou systémů s procesory Intel B / G bezdrátové karty (IPW2200) .- Live CD všechny nástroje potřebné k zaseknout WLAN / bezdrátový přístupový bod - Linux Live-CD - OS běží z CD - 635megabajt -. iso
- Používá se i FBI.
WEP šifrování je systém, založený na RC-4 šifra, která je k dispozici na všech 802.11a, b, g, a bezdrátové produkty. WEP používá sadu bitů tzv. klíč k zakódování informací v datových rámců, protože ponechává přístupového bodu nebo klienta adaptér a kódované zprávy je pak dešifrovat přijímačem.
Obě strany musí mít stejný WEP klíč, který je obvykle celkem 64 nebo 128 bitů. Polo-24 bitové náhodné číslo, zvané Inicializační vektor (IV), je součástí klíče, tak 64 bit WEP klíč skutečně obsahuje pouze 40 bitů strongencryption zatímco 128 má 104 bitový klíč. IV je umístěn v zašifrované rámy hlavičce, a je přenášen ve formátu prostého textu.
Tradičně, praskání klíče WEP byl pomalý a nudný proces. Útočník by mohl zachytit statisíce nebo miliony paketů-proces, který může trvat několik hodin nebo dokonce dní, v závislosti na objemu datových přenosů procházejících přes bezdrátovou síť. Po dost pakety byli zajati, WEP praskání program jako Aircrack by být použit k nalezení WEP klíč.
Fast-forward se loni v létě, kdy první z nejnovější generace WEP nástroje se objevily trhliny. Tato současná generace využívá kombinace statistických metod zaměřených na unikátní zachytil IVS a brute-force slovníkové útoky zlomit 128 bit WEP klíče v řádu minut místo hodin. Jako zvláštní agent Bickers poznamenat, does'nt Je jedno, jestli používáte 128 bit WEP klíče, ty jsou ohroženy!
Útočník by mohl zachytit statisíce nebo miliony paketů proces, který může trvat několik hodin nebo dokonce dní, v závislosti na objemu datových přenosů procházejících přes thewireless síti.
Základní Trasy:
1) Boot z cd
2) získat WEP klíč
3) zapište si ho
4) restartovat do windows
5) připojení pomocí WEP klíč.
Je to aj preto super-produkt, lebo to údajne beží priamo aj s CD, ktoré môžete brať zo sebou a použiť to kdekolvek trebárs aj s internetových kaviarní - tak, že mojí mylí virtuálný priatelia ako "Tomo - Dr.Thrax - Sisemen - Happyccol - Andy=Brahma" prajem Vám s mojho najúprimnejšieho cybersvetového srdca, aby sa aj z Vás staly pravý a neoblomný a nekompromisný - HACKERMANS..........#############################################################1.
