Aktuálny čas je Str 28. Okt 2026 23:05:34
 Easy Hide IP v1.3..100% funkčný "key.gen"="NEZAVIRENÝ"
 Predmet príspevku: Easy Hide IP v1.3..100% funkčný "key.gen"="NEZAVIRENÝ"
PoslaťNapísal: Pon 06. Júl 2009 10:24:41
Hide your IP address with our anonymous surfing/browsing software. Protect your privacy and anonimity.
Easy-Hide-IP - Anonymizes all your internet connections and allows you to: Surf any Web Sites, Web-based Email services, Newsgroups, Blogs and Forums.
Key Features and Benefits provided by Easy-Hide-IP
» Easy-Hide-IP - Secures and Anonymizes all your internet connections and allows you to: Surf any Web Sites, Instant Messenger and Chat services, Web-based Email services, Newsgroups, Web Blogs and Forums. Your Identity is Secure, Protected, and Anonymized.
» Easy-Hide-IP protects your identity by replacing your real IP address with a different one. You will appear to access the internet from a different location, not your own. Your real location is never revealed.
» You can bypass virtually any form of censorship or internet traffic blocking imposed on you by your ISP, by your company, or by some other third parties. All your internet traffic is routed through remote servers. On your ISP's log file, only the IPs of the remote servers will be shown, not the sites you have visited.
» You do not need to worry about your ISP or some other Entities monitoring your internet activities, see what you are doing, which Newsgroups, Blogs or Forums you have visited and which messages you have posted.
Easy-Hide-IP runs on the following Microsoft Windows platforms
2000 Professional and Server
XP Home, Professional
Vista Home and Professional
Find out how Easy-Hide-IP Works
» We use servers located strategically around the world. You can easily connect to any of the worldwide servers anytime, anywhere. Each time you press the Hide IP Now button one of the servers will be selected for use. The location is selected randomly. Each time your press Get a new IP – the server is use will be changed with a new one. Read More
» Through the secure anonymous network, you can surf the web with total anonymity and security!
» Easy-Hide-IP is designed for sensitive browsing. Use it anytime you want to protect your privacy with full confidence. What Easy-Hide-IP won’t do for you is: enhance your download speed (while using Easy-Hide-IP your download speed might decrease) and will not allow you to access SSL (Secure Socket Layer) web sites so you will not be able to do online shopping.
Takéto a podobné softy tu už existujú, ale na rozdiel od iných tento balík sa líši iba v tom, že má vysoko kvalitný spolahlivý "key.generátor", ktorý sa ináč shána na nete len velmi tažko..
Skrytí vaší IP adresu s našimi anonymní surfování / prohlížení software. Chraňte si své soukromí a anonymity.
Easy-Hide-IP - Anonymizes všechny vaše připojení k internetu a umožňuje: Surf jakékoliv webové stránky, on-line služby E-mail, zpráv, blogů a fór.
Klíčové vlastnosti a výhody poskytované Easy-Hide-IP
»Easy-Hide-IP - Chrání a Anonymizes všechny vaše připojení k internetu a umožňuje: Surf jakékoliv webové stránky, Instant Messenger a Chat služeb, on-line služby E-mail, Newsgroups, Web Blogy a fóra. Vaše identita je bezpečné, chráněné, a anonymní.
»Easy-Hide-IP chrání vaši identitu a nahradit vaši skutečnou IP adresu za jinou. Ty se budou zobrazovat k přístupu na internet z jiného místa, nikoli vlastní. Vaše skutečné umístění není nikdy odhalil.
»Můžete obchvatu prakticky jakoukoli formu cenzury internetu nebo zablokování provozu uvalené na vás váš ISP, které vaše společnost, nebo jiným třetím stranám. Všechny vaše internetová komunikace je směrována prostřednictvím vzdálených serverů. Na váš ISP log souboru, pouze IPS vzdálené servery budou zobrazeny, ne o stránky, které jste navštívili.
"Nemusíte se starat o vašeho ISP nebo jiné subjekty sledování vašich internetových aktivit, vidět to, co děláte, který Newsgroups, Blogy Fórum nebo jste navštívili a zprávy, které jste odeslali.
Easy-Hide-IP běží na těchto platformách Microsoft Windows
2000 Professional a Server
Vista Home a Professional
Zjistěte, jak Easy-Hide-IP Díla
»Pouľíváme servery umístěny strategicky po celém světě. Můžete snadno připojit k žádné ze serverů po celém světě kdykoliv a kdekoliv. Pokaždé, když stiskněte tlačítko Hide IP Nyní jeden z serverů budou vybrány k použití. Na místě je vybrána náhodně. Pokaždé, když vaše tiskové Získejte nové IP - server je využití bude měnit s novou. Více
»Prostřednictvím zabezpečené sítě v anonymitě, můžete surfovat na webu s celkovou anonymitu a bezpečnost!
»Easy-Hide-IP je určen pro citlivé procházení. Použijte jej kdykoli chcete chránit své soukromí s plnou důvěrou. Co Easy-Hide-IP nebude to pro vás je: zvýšit vaše rychlost stahování (při použití Easy-Hide-IP vaše rychlost stahování je mohli snížit) a nebude Vám umožní přístup do SSL (Secure Socket Layer) webové stránky, takže bude nebude moci dělat on-line nakupování.
 Predmet príspevku: Re: Easy Hide IP v1.3..100% funkčný "key.gen"="NEZAVIRENÝ"
PoslaťNapísal: Sob 08. Aug 2009 15:43:21
Registrovaný: Sob 08. Aug 2009 8:24:01
V tom keygene je Trojan - skús a-squared free.
