Aktuálny čas je Pon 26. Okt 2026 5:30:35
 Proxy Switcher 4.2.0 Build 5101
 Predmet príspevku: Proxy Switcher 4.2.0 Build 5101
PoslaťNapísal: Sob 25. Júl 2009 17:55:01
Very useful program for those, who regularly encounter problem, as to skachat' is free of charge much file with Rapidshare or wants to hide its real IP. You do want to deceive RapidShare, Megaupload, DepositFiles and others? - there is nothing simpler! Proxy Switcher Simply changes your host country "in flight"! Speaking in another language, changes your IP- address by proksi.Programma Proxy Switcher Pro it will scan, it protestiruyet and will find for you more than 100 high-speed proxy with the reflection of the flags of countries and time of response.Different internet connections do often require completely different proxy server settings and it's a real pain to change them manually. Proxy Switcher offers full featured connection management solution. This includes flexible proxy server list management, proxy server tester and anonymous surfing capabilities.
Proxy Switcher Features
• Change proxy settings on the fly
• Automatic proxy server switching for anonymous surfing
• Works with Internet Explorer, Firefox, Opera and others.
• Flexible proxy list management
• Proxy Server Anonimity testing testing
• Anonymous proxy server list download
Proxy Switcher Benefits:
*Hide your IP address from the web sites you visit.
*Penetrate bans and blocks on forums, classifields and download sites (rapidshare etc.).
*Automatic proxy server switching for improved anonymous surfing.
*Easy way to change proxy settings on the fly.
*For webmasters - check search engine results from different countries.
*Fully compatible with Internet Explorer, Firefox, Opera and others.
*Advanced proxy list scanning and management.
Czech...
Velmi užitečný program pro ty, kteří pravidelně setkávají s problémem, jak se skachat 'je zdarma mnoho souborů s Rapidshare nebo chtějí skrýt své skutečné IP. Ty si chceš podvést RapidShare, Megaupload, DepositFiles a ostatní? - Není nic jednoduššího! Proxy Switcher Jednoduše změny vaší hostitelské země "v letu"! Mluvení v jiném jazyce, změní vaše IP-adresu proksi.Programma Proxy Switcher Pro to bude testovat, je protestiruyet a najít pro vás více než 100 high-rychlost proxy s odrazem vlajek zemí a čas response.Different internet spojení se často vyžadují zcela jiný proxy server, nastavení a je to opravdový bolesti je měnit ručně. Proxy Switcher nabízí kompletní řešení pro řízení Nejlepší spojení. To zahrnuje flexibilní proxy server list management, proxy server tester a anonymní surfování schopností.
Proxy Switcher Vlastnosti
• Změna nastavení proxy za chodu
• Automatické přepínání proxy serveru pro anonymní surfování
• Práce s Internet Explorer, Firefox, Opera a další.
• Flexibilní proxy list management
• Proxy server Anonymita testování testování
• Anonymous proxy server list ke stažení
Proxy Switcher Výhody:
* Hide vaší IP adresy z webových stránek, které navštívíte.
* Proniknout zákazy a bloky na fóru, classifields a stahovat stránky (rapidshare atd.).
* Automatické přepínání proxy serveru pro lepší anonymní surfování.
* Snadný způsob, jak změnit nastavení proxy za chodu.
* Pro webmastery - zkontrolovat vyhledávač výsledky z různých zemí.
* Plně kompatibilní s aplikací Internet Explorer, Firefox, Opera a další.
* Advanced proxy list skenování a management.
Hungary...
Nagyon hasznos program azok számára, akik rendszeresen találkoznak a probléma, hogy skachat "ingyenes sok fájlt Rapidshare vagy akarja rejteni a valódi IP. Te akarsz félrevezetni RapidShare, Megaupload, DepositFiles és a többiek? - Semmi sem egyszerűbb! Proxy Switcher Egyszerűen változások a fogadó ország "repülés"! Beszél más nyelven, megváltozik az IP-címét proksi.Programma Proxy Switcher Pro fogja beolvasni, akkor protestiruyet, és megtalálja az Ön számára több mint 100 nagy sebességű proxyt a mérlegelés a zászlókat az országok és ideje response.Different internet kapcsolatokat nem gyakran teljesen eltérő proxykiszolgáló beállításait, és ez egy igazi fájdalom megváltoztatni őket. Proxy Switcher kínál teljes funkcionalitású kapcsolat megoldás. Ez magában foglalja a rugalmas proxyszerver lista kezelése, proxyszerver teszter és névtelen szörfözés képességeit.
Proxy Switcher Szolgáltatások
• Change proxybeállításokat a fly
• Automatikus váltás proxyszerver anonymous surfing
• az Internet Explorer, Firefox, Opera és a többiek.
• Rugalmas proxy lista kezelése
• Proxykiszolgáló névtelenség vizsgálat vizsgálati
• Névtelen proxyszerver lista letöltés
Proxy Switcher Előnyök:
* Hide az IP-címet a honlapokat látogat.
* Behatolás tilalmakat és blokkolja a fórumokon, és töltse le classifields helyszínek (rapidshare, stb.)
* Az automatikus proxy szerver átállás jobb névtelen szörfözés.
* Egyszerű módja változik proxybeállításokat a repülésre.
* A webmesterek - ellenőrzi keresőmotor eredményeit a különböző országokban.
* Teljesen kompatibilis az Internet Explorer, Firefox, Opera és a többiek.
* Részletes proxy lista szkennelés és kezelését.
