Aktuálny čas je Str 28. Okt 2026 14:48:13
 MyProxy 9.2 - Výber je velký
 Predmet príspevku: MyProxy 9.2 - Výber je velký
PoslaťNapísal: Str 11. Mar 2009 10:45:46
High quality web accelerator with powerful ad blocker and cache will save your time, money and nerves. MyProxy allows you to optimize your Web connection. Browse the Internet without having to deal with ad banners ads. Keep track of the traffic amount and money you have spent for Internet.
The programs features include:
* Ad filtering capability
MyProxy is a filtering program which provides for Internet browsing without the clutter by blocking unwanted advertising
* DNS-caching
Will speed up your web browser every time you want to connect on Internet, by speeding up DNS lookups. MyProxy holds a local table of DNS-IP addresses and check that table before asking the DNS at your ISP. Therefore there is a local search without generating TCP/IP network traffic at all. DNS lookups occur whenever you use URL for finding an Internet resource
* Web page loading time optimization (data transfer volume reduction)
MyProxys built-in caching loads graphics faster, accelerating your access
* Proxy server support
With MyProxy you can share your Internet connection with other computers in the LAN
* Internet dialer
Integrated Internet dialer helps you to get a connection to Internet easier and make Internet access a more simple process. It can re-dial multiple lines until a connection will be established. After that it monitors carrier, if a connection is dropped or lost it reconnects automatically
* Keeps track of how much money you have spent for Internet
MyProxy keeps track of how much traffic and money you have spent every day and every month
* Password protecting
To prevent any undesirable use of your connectivity you can set the password for using the program
* Protect your online privacy
MyProxy intercepts advertisers requests and prevents tracking of your online habits
webový akcelerátor vysoké kvality se silným reklamním blokátorem a cache šetřit váš čas, peníze a nervy. MyProxy dovoluje vám optimalizovat vaše webové spojení. Brouzdejte Internetem bez toho, muset jednat s reklamními bannerovými reklamami. Sledujte množství dopravy a peněz, které vy jste utratili pro Internet.
Programy rysy zahrnují:
* reklama filtrující způsobilost
MyProxy je filtrující program který zabezpečuje Internet prohledávání bez změti blokováním nechtěné reklamy
* DNS-CACHING
Zrychlit váš internetový prohlížeč pokaždé když vy chcete spojit na Internetu, překročením rychlostmi nahoru DNS vyhledáváními. MyProxy drží místní tabulku DNS-IP adres a kontrolovat které stůl před dotazující se DNS ve váš ISP. Proto tam je místní hledání bez tvořící TCP/IP síťové dopravy vůbec. DNS vyhledávání se vyskytují kdykoli vy užíváte URL pro nález internetového zdroje
* webová stránkové doba nakládky optimalizace (datové přestupné hlasitost zmenšení)
MyProxys zabudovaná zásobárna nakládá grafiku rychlejší, urychlování vašeho přístupu
* serverová podpora zastupování
S MyProxy vy se můžete podělit o váš internetové spojení s jinými počítači v LAN
* internetový volič
Integrovaný internetový volič pomáhá Vám dostat spojení s Internetem snadnějším a udělat přístupu na Internet víc jednoduchého procesu. To může znovu-vytočit vícenásobné linky do spojení bude ustanoveného. Po tom to monitoruje přepravce, jestli spojení klesá či ztracený to opětovně se spojí automaticky
* sleduje kolik peněz, které vy jste utratili pro Internet
MyProxy sleduje kolik dopravy a peněz, které vy jste utratili každý den a každý měsíc
* heslo ochrana
Pro předejít nějakému /každému /žádnému nevhodnému použití vaší propojitelnosti, které vy můžete nastavit heslo pro použití programu
* ochrana vaše online soukromí
MyProxy zachycuje inzerenty žádá a předchází sledování vašich online zvyků
 Predmet príspevku: Re: MyProxy 9.2 - Výber je velký
PoslaťNapísal: Uto 03. Nov 2009 16:02:27
