Aktuálny čas je Pia 30. Okt 2026 16:44:29
 Easy Net Switch v6.4.3
 Predmet príspevku: Easy Net Switch v6.4.3
PoslaťNapísal: Uto 26. Máj 2009 22:15:47
Connect your computer to the different networks easily!Easy Net Switch enables you to create and manage network location profiles. Network profile stores all the network and Internet settings that are needed. By switching net profiles, you can connect to a network easily and quickly.
Do you use your computer in different locations or networks? Easy Net Switch enables you to automatically select correct IP addresses, proxys, drive mappings, default printers and much more with a single click. It's not only an IP or Network configuration switcher, but also a handy tool that helps you to use your computer in multiple networks easily!
Easy Net Switch is a powerful and easy to use network configuration switch tool. It stores network and Internet configuration settings such as IP address, DNS, gateway, proxy, drive mappings, printers, SMTP and more into network location profiles. By switching between network profiles, you can quickly and easily connect to a network without having to manually reconfigure settings or restart the computer each time.
Advantages of Easy Net Switch:
*Lightweight, efficiency and stable
*Small file size and memory usage, never slow down your computer. Activate profiles "on the fly", and no reboot required!
*Flexiable and easy to use
*Change proxy frequently? Or only want to map the network drivers automaticlly? With Easy Net Switch, you can create the most flexiable net profiles for different purpose.
*Show IP address on the desktop wallpaper !
*With it's buildin DKInfo™ engine, Easy Net Switch can display current IP addresses info on the desktop wallpaper. It's the easiest way to monitor your computer's IP addresses info.
*Useful buildin network tools
*Tools with easy to use GUI can help you to diagnose your possiable network problems. Including Ping, Traceroute (Tracert), IPConfig and much more.
*Auto-capture current network settings
*By clicking a button, your current computer's configuration will be imported into a profile automatically. Your can share or apply it again at anytime.
*Intelligent profile export and import wizard
*Using the "best match" approach, one can easily backup, restore or share their network profile with others.
Spojte váš počítač k jiným sítím snadno!Snadný Net Switch umožní vám vytvořit a řídit síťové profily umístění. Síťový profil skladuje celá síť a internetová nastavení které jsou potřebná. přepínáním síťovými profily, vy můžete připojit k síti snadno a rychle.
Vy užíváte váš počítač v jiných lokalitách či sítích? Snadný Net Switch umožní vám automaticky vybrat správné IP adresy, zastupování, disková mapování, implicitní tiskárny a mnohem víc s jednotlivým kliknutím. To není jen IP či struktura sítě posunovací lokomotiva, ale také vhodný nástroj který pomáhá Vám použít váš počítač ve vícenásobných sítích snadno!
Snadný Net Switch je silný a snadno použitelný struktura sítě přepnou nástroj. To skladuje síť a internetová konfigurační nastavení jako IP adresa, DNS, průjezd, zastupování, disková mapování, tiskárny, SMTP a více do síťových profilů umístění. přepínáním mezi síťovými profily, vy můžete rychle a snadno připojíte k síti bez toho, muset ručně překonfigurovat nastavení či spustit znovu počítač vždy.
Výhody snadné sítě přepnou:
*lehká kategorie, efektivita a stáj
*malé velikost souboru a použití paměti, nikdy nezpomalí váš počítač. Aktivujte profily "za letu", a ne restartovat požadovaný!
*Flexiable a snadno použitelný
*měnit zastupování často? Či jen chtít mapovat síťové řidiče automatické? S Easy Ní Switch, vy můžete vytvořit většinu síťových profilů flexibility pro odlišný cíl.
*předváděcí IP adresa na desktopu tapetě !
* s tím je stavební DKINFO™ motor, snadný síťový vypínač může zobrazit aktuální IP adresy informaci na desktopu tapetě. To je nejsnadnější způsob jak monitorovat váš počítačové IP osloví informaci.
*užitečné stavební síťové nástroje
*nástroje se snadno použitelný GUI může pomoct vám diagnostikovat vaše možné síťové problémy. Včetně zasvištění, Traceroute (Tracert), IPCONFIG a mnohem víc.
*Auto - capture aktuální síťová nastavení
* kliknutím knoflíkem, vaše aktuální sestava počítače bude importovaný do profilu automaticky. Váš může sdílet či použít to znovu v kdykoliv.
*inteligentní export profilu a importního mága
*používání "nejlépe se hodí k" přístup, jeden může snadno zálohování, obnovit či sdílejte jejich síťový profil s ostatními.
:cert: :cert: :cert: :cert: :cert: :cert: :cert: :cert: :cert: :cert: :cert: :cert: :cert: :cert: :cert: :cert: :cert: :cert: :cert: :cert: :cert: :cert: :cert: :cert: :cert: :cert: :cert: :cert: :cert: :cert: :cert: :cert: :cert:
