Aktuálny čas je Str 21. Okt 2026 5:54:25
 Radmin 3.4 full version
 Predmet príspevku: Radmin 3.4 full version
PoslaťNapísal: Pon 19. Okt 2009 19:44:14
Radmin (Remote Administrator) is the world famous, award winning secure remote control software and remote access software which enables you to work on a remote computer in real time as if you were using its own keyboard and mouse. Radmin is fast and secure remote control and remote access software that enables you to work on a remote computer as if you were sitting right in front of it and access it from multiple places. Radmin includes full support for Windows Vista (32-bit and 64-bit), file transfer, multi-user text and voice chats, Windows security, Kerberos authentication, 256-bit AES encryption for all data streams, telnet access, multiple monitors support and unique DirectScreenTransfer™ technology. Radmin utilizes the ever-present TCP/IP protocol - the most widespread protocol used in LANs, WANs and the Internet. This means you can access your remote computer from anywhere in the world. Radmin is deployed on thousands of corporate PCs worldwide.
Among our clients are companies where Radmin is the standard application for network management.
Security is absolutely essential for any remote access software. We, at Famatech, are dedicated to providing you the highest security levels possible. Our cryptography engineers are very proud of pushing the technology and keeping Radmin the most secure remote access software available.
Security Highlights include:
• Advanced 256-Bit AES strong encryption of all data streams.
• Ability to use either Windows Security or Radmin Security.
• Windows security supports different permissions for specific users or user groups from a Primary Domain, Trusted Domains and the Active Directory. Supports automatic use of logged-in user credentials and Kerberos authentication.
• Radmin security supports different permissions for the users added to the Radmin Server access list. Radmin uses a new Diffie-Hellman based key exchange with 2048-bit key size for secure user authentication.
• IP Filter permits access to Radmin Server only from specified IP addresses and networks.
• DNS name and user name info added to the logfile.
• Smart protection from password guessing.
• Highest Speed of Work
• Highest Security Level
• Hardware remote control with Intel® AMT support New!
• Full compatibility with Windows 7 New!
• Multi-user Text and Voice Chat
• Multiple monitors support
• User-friendly interface
• Secure "Drag and Drop" file Transfer with "Delta Copy" feature
• Low System Requirements
• Multiple Connections Support
• Free Technical Support
Other Features:
• Compatibility with Windows Vista and Windows XP multiple user sessions.
• Radmin Viewer is compatible with Wine (remote control from Linux machines).
• Fully supports the display of animated and alpha-blended remote computer cursors.
• Mouse wheel support.
• Special keystroke handling and optional Full keyboard control.
• Supports high resolution modes (there is no limit to the maximum display resolution).
• Remote screens can be displayed inside a window or full screen with smooth scaling and the original aspect ratio.
• Multiple monitors support.
• Two-way clipboard transfer with Unicode support.
• Unlimited phonebook for Radmin connections with an explorer-like interface, folders and drag-and-drop support.
• Shortcuts from phonebook records to the desktops listed in those phonebook records.
• Scan to find running Radmin Servers.
• Multilanguage user interface and built-in help.
• Telnet connection mode.
• Shutdown Connection Mode.
• Radmin Server runs only as a service.
• Compatibility with Radmin Server 2.x.
• Five incorrect passwords sequence security delay.
• DNS name and user name info added to the log file.
Changes in version 3.4:
* Support for Windows 7 (32-bit and 64-bit).
* Support for Windows Server 2008 R2 (32-bit and 64-bit).
Radmin (Remote Administrator) je světově známý, oceněný bezpečný software pro dálkové ovládání a software pro vzdálený přístup, který umožňuje pracovat na vzdáleném počítači v reálném čase, jako kdybyste byli na základě svého vlastního klávesnici a myš. Radmin je rychlý a bezpečný dálkové ovládání a software pro vzdálený přístup, který vám umožní pracovat na vzdáleném počítači, jako kdybyste seděli přímo před ním a přístupu z více míst. Radmin obsahuje plnou podporu pro Windows Vista (32-bit a 64-bit), přenos souborů, multi-uživatelské text a hlasové chaty, zabezpečení systému Windows, pomocí protokolu Kerberos, 256-bit AES šifrování všech datových toků, telnet přístup, podpora více monitorů a unikátní DirectScreenTransfer ™. Radmin využívá stále-současnost TCP / IP protokolu - nejrozšířenější protokol používaný v sítích LAN, WAN i internet. To znamená, že můžete přistupovat ke svému vzdálenému počítači z libovolného místa na světě. Radmin je nasazen na tisíce firemních počítačů po celém světě.
Mezi našimi klienty jsou společnosti, kde Radmin je standardní aplikace pro správu sítě.
Bezpečnost je naprosto nezbytné, aby každý software pro vzdálený přístup. My, jsou na Famatech, že bude poskytovat vám nejvyšší možné úrovně zabezpečení. Naše kryptografie technici jsou velmi hrdí na prosazování technologie a vedení Radmin nejvíce bezpečný vzdálený přístup software není k dispozici.
Bezpečnost hlavní výhody patří:
• Pokročilá 256-bit AES silné šifrování všech datových toků.
• Možnost použít buď zabezpečení systému Windows, nebo Radmin Security.
• zabezpečení systému Windows podporuje několik různých oprávnění pro konkrétní uživatele nebo skupiny z primární domény, Důvěryhodné domény a Active Directory. Podporuje automatické užívání přihlášeného-v pověření uživatele a Kerberos.
• Radmin zabezpečení podporuje různé oprávnění pro uživatele z přidané přístup k Radmin serveru seznamu. Radmin používá nový Diffie-Hellman klíč na výměnu s 2048-bitový klíč pro bezpečné ověřování uživatelů.
• IP filtr umožňuje přístup k Radmin serveru pouze z určitých IP adres a sítí.
• DNS jméno a uživatelské jméno info přidán do souboru protokolu.
• Inteligentní ochrana proti heslo hádat.
Funkce:
• Nejvyšší rychlost práce
• Nejvyšší úroveň zabezpečení
• Hardware dálkový ovladač s podporou Intel ® AMT Nové!
• Plná kompatibilita s Windows 7 Nová!
• Multi-user Text a hlasové konverzace
• podpora více monitorů
• Bezpečné "Drag and Drop" Přenos souborů s "Delta Copy" feature
• Nízká Systémové požadavky
• Vícenásobná připojení Podpora
• Bezplatná technická podpora
Další vlastnosti:
• Kompatibilita s Windows Vista a Windows XP více uživatelských relací.
• Radmin Viewer je kompatibilní s vínem (dálkové ovládání od stroje, Linux).
• Plně podporuje zobrazení animované a alpha-blended vzdáleném počítači kurzory.
• podporu kolečka myši.
• Speciální úhoz manipulaci a volitelné Úplné ovládání pomocí klávesnice.
• Podporuje režimy s vysokým rozlišením (není žádné omezení na maximální rozlišení displeje).
• Vzdálená obrazovky může být zobrazen uvnitř okna nebo celé obrazovky s hladkými škálování a původního poměru stran.
• podpora více monitorů.
• Two-way schránky převod s podporou Unicode.
• Neomezený telefonní seznam pro připojení k Radmin s badatel-jako rozhraní, složky a drag-and-drop.
• Zástupci z telefonního seznamu záznamů, které jsou uvedeny v těchto počítačů telefonním seznamu záznamů.
• Skenování najít spuštění Radmin servery.
• vícejazyčné uživatelské rozhraní a stavěný z-do pomoc.
• Telnet režim připojení.
• Odstavení Connection Mode.
• Radmin serveru běží pouze jako služba.
• Kompatibilita s Radmin Server 2.x.
• Pět nesprávné heslo sekvenci bezpečnostních zpoždění.
• DNS jméno a uživatelské jméno info přidán do log souboru.
Změny ve verzi 3.4:
* Podpora pro Windows 7 (32-bit a 64-bit).
* Podpora pro Windows Server 2008 R2 (32-bit a 64-bit).
 Predmet príspevku: Re: Radmin 3.4 full version
PoslaťNapísal: Uto 23. Feb 2010 13:30:39
Registrovaný: Pon 22. Feb 2010 11:04:38
Hotovosť: 51.00
a jaké je heslo?
