Aktuálny čas je Štv 22. Okt 2026 18:04:54
 cFosSpeed v5.00 build 1560 Final
 Predmet príspevku: cFosSpeed v5.00 build 1560 Final
PoslaťNapísal: Štv 19. Nov 2009 14:40:11
cFosSpeed is a high-performance network driver for DSL modems and routers. Highlights of this program include Traffic Shaping, For DSL modems and routers, Fully compatible with conventional PPPoE drivers, Automatic router detection, Self-calibrating, Highly responsive when used with online games and Peer-to-Peer networks like eMule or Kazaa, and Freely configurable priority classes.
cFos Traffic Shaping reduces delays during data transfer and allows you to surf the Internet up to three times faster. Finally, you can use the full bandwidth of your DSL connection!
During TCP/IP transfer, a certain amount of data needs to be confirmed upon reception before more can be sent. Stalling data confirmation results in delays and transfer-rate slowdowns, thus forcing the sender to wait. Especially for ADSL, it is possible to slow a download to a crawl by choking the upstream channel (which has the smaller bandwidth anyway) with an upload. This is because in such a scenario there is not enough upstream bandwidth left for data confirmation. The standard solution so far has been to try and compensate for this by increasing TCP window size, thereby allowing more data to be sent without immediate confirmation. The main problem here is that this also leads to high ping times (latency) and significant delays during Webpage rendering. Latency of up to 2 seconds is not uncommon for TCP windows with a size of 64k. In short, huge window sizes just won?t let you achieve full download speed. By contrast, cFos Traffic Shaping prioritizes data traffic in such a fashion that important packets zip past regular packets. This way, receipts always arrive in time, and uploads won't ever choke your broadband connection again! cFos Traffic-Shaping technology recognizes a number of important packet types and prioritizes them not only to keep Internet traffic running smoothly but also to ensure particularly low ping times. This not only accelerates surfing and download speeds significantly, but it is also a decisive advantage for online gaming. With cFos Traffic Shaping, you will notice measurable improvements and benefits like:
* Full download rate during upload
* Consistently quick response time while surfing the Web or running other applications
* Improved VoIP speech quality
* Perfect for online gamers!
* Extended Traffic Shaping for DSL modems, cable modems & routers
* Highly responsive when used with online games and filesharing (P2P) like eMule, Kazaa or Bittorrent
* Minimal ping times for streaming audio & video, Voice over IP (VoIP), Internet Radio, etc.
cFosSpeed je vysoce-výkon sítě ovladač pro DSL modemy a routery. Rysy tohoto programu patří Traffic Shaping, pro DSL modemy a routery, plně kompatibilní s běžnými PPPoE řidiče, Automatická detekce router, Self-kalibraci, vysoce citlivý při použití s on-line hry a Peer-to-Peer sítích jako eMule, nebo Kazaa a volně konfigurovatelná priorita tříd.
cFos Traffic Shaping snižuje zpoždění během přenosu dat a umožňuje surfování po internetu až třikrát rychleji. A konečně, můžete využít plnou propustnost DSL připojení!
Během TCP / IP přenosu, určité množství dat musí být potvrzeny při příjmu více, než může být odeslána. Stagnuje potvrzení údajů má za následek zpoždění a transfer-rychlost zpomalení, tak nutit odesílatele čekat. Speciálně pro ADSL, je možné stáhnout na pomalé procházení tím, udušení upstream kanálu (který má menší šířku pásma stejně) s upload. To proto, že v takové situaci, že není dostatek proudu šířku pásma odešel do potvrzení údajů. Standardní roztok doposud bylo pokusit kompenzovat tím, že zvyšuje velikost TCP okna, což umožňuje více údajů, které mají být zaslány bez okamžité potvrzení. Hlavním problémem je to, že to také vede k vysokým ping doby (latence) a ke značnému zpoždění při zobrazování webových stránek. Latence až 2 sekundy, není neobvyklé pro okna protokolu TCP o velikosti 64 kB. Stručně řečeno, obrovské velikosti okna vyhrál? T umožňují dosáhnout plné rychlosti stahování. Naproti tomu cFos Traffic Shaping upřednostňuje dat v takové podobě, že důležité pakety zip minulosti pravidelně pakety. Tímto způsobem příjmy vždy přijet včas, obrázky a nebude nikdy zadusit vaše širokopásmové připojení znovu! cFos provozu-Formování technologie rozpozná řadu důležitých typů paketů a upřednostňuje je nejen udržet internetový provoz hladký chod, ale také zajistit, zvláště nízké ping-krát. To se netýká pouze zrychluje surfování a rychlost stahování je výrazně, ale je také rozhodující výhodu pro online hraní. S cFos Traffic Shaping, všimnete si, měřitelná zlepšení a výhod, jako je:
* Full download sazby během nahrávání
* Důsledně rychlou dobou odezvy při surfování na webu nebo jiné aplikace běžící
* Improved VoIP kvalitu řeči
* Ideální pro hráče on-line!
* Rozšířené Traffic Shaping pro DSL modemy, kabelové modemy & routery
* Vysoce citlivé při použití s on-line hry a filesharing (P2P), jako eMule, Kazaa nebo Bittorrent
* Minimální doba ping pro streamované audio a video, Voice over IP (VoIP), Internet Radio, atd.
Poznámka :
Profíci to určite vedia ako na to, ale nakolko mänej skúsení useri zrejme nie tak jedine s toho dôvodu práve ím pomáham aspon v krátkosti ako na to. Tak, že program nainštalujete potom ten key-kľúč prekopírujete do adresára nainštalovaného programu potom to heslo kopírujete potom kliknete na ten key-kľúč a to heslo tam prilepíte a potom ten key-kľúč už nahodíte inštalačne a až potom ked už soft bude full-PRO tú priloženú čaštinu rozbalíte a prekopírujete obe knižnice do adresára nainštalovaného programu potom celý win reštartujete a po reštarte vedľa hodín v tray pravým kliknutím otvorite menu programu a tam už uvidíte language a vyberete si czech a automaticky sa to všetko prehodí do czech jazyka a môžete surfovať priam supersónickou ultra rýchlosťou, lebo táto najnovšia finálná verzia je fakt šp**a .. !!!
