Aktuálny čas je Pia 02. Okt 2026 22:28:25
 Look'n'Stop v2.06
 Predmet príspevku: Look'n'Stop v2.06
PoslaťNapísal: Ned 10. Máj 2009 14:23:08
Look 'n' Stop™ Firewall 2.06 is compatible with Windows Vista TM now !
Easier and even more efficient, Look 'n' Stop™ Firewall 2.06 secures your connexion !
Look 'n' Stop Firewall 2.06 offers many enhancements with still the key features below.
> Blocks spywares and keystroke loggers.
> Makes your PC invisible to hackers.
> Fast download and fast setup.
> Out of the box configuration.
> Tracks the attacks attempts through logged events.
> Includes a password protection of the configuration.
> Very efficient and highly configurable for advanced users.
> Features extension through plugins.
> Automatically updates new releases.
New features
- Support for Windows Vista
- Internet Filtering (Windows 2000/2003/XP/Vista): IP V6 support (Internet Protocol Version 6)
- Application Filtering (Windows Vista only): IP V6 support
- Internet Filtering (Windows 2000/2003/XP/Vista): a new option to handle fragmented packets.
- Application Filtering (Windows 2000/2003/XP/Vista): a new option to have the application filtering still active even if Look 'n' Stop is stopped (persistent application filtering)
- Application Filtering (Windows 2000/2003/XP/Vista): possibility to add non standard extensions for parent applications.
- New option to associate import files (.rie) to Look 'n' Stop. This allows to import files by clicking a link or double clicking on a .rie file.
- Popup position is saved.
- Direct access to a rule from the log (with a right click).
- Service mode startup is now available in the options (not supported for Vista).
- Rule edition: added "Equal/different from my @" for the MAC address.
- Rule edition: added a "Local Port" criteria for port selection (by default this criteria selects the range 1024-5000, except under Vista it is 4915...).
Changes
- Automatic selection of the network interface is anyway done on an excluded IP if no other network interface with a valid IP has been found..
- Rule and log files are no longer saved in the Look 'n' Stop installation folder but in the following folder: "Documents and Settings[user]Local SettingsApplication Datalooknstop" (Windows 2000/2003/XP/Vista only; and for a fresh install only)
- The registration is no longer done through the "Look 'n' Stop Code" but with an email address.
- "Watch thread injection" and "Watch DNS calls" are no longer available for now.
- An explicit option has been added on the command line to start several instances of Look 'n' Stop. A double-click on looknstop.exe no longer start a second instance.
- When Look 'n' Stop is started in service mode, if the user log off, Look 'n' Stop is no longer stopped (and restarted).
- Number of filtering rule is now 128 for the internet filtering.
- Number of rules/applications is now 200 for application filtering.
- Number of TCP SPI is now configurable through the registry
- New display options in the TCP connections dialog box.
- Added more information for TCP SPI alerts
- In the dialog box to associate an application to a rule the full path of the selected application has been added.
Fixes
- Several fixes and improvements in TCP SPI (in particular in timeout handling)
- Automatic selection of the network interface wasn't working in some particular circumstances.
- After the popup windows is closed now the focus is put again on the initial application that has the focus before.
- When editing a rule with a plugin, some criteria were not saved properly.
- When an application was associated to a rule, modifying an attribute (log, allow/block) of the rule was also modifying its activation without looking to the application state..
- Color display issue when started in service mode.
- Fixed some attribute update displays in Internet Filtering page when the rule is updated by a plugin.
- Internet Filtering (Windows 2000/2003/XP/Vista): crash at startup with some ethernet adapter names
- Application Filtering (Windows 2000/2003/XP/Vista): Added a fix in process identification to detect some leaktests/malicious software changing application process path in user mode.
- Problem sometimes when doing rule copy/paste in Internet Filtering.
- When the settings were locked with a password, the quit menu in the tray icon was not greyed if a translation plugin was enabled.
Known issues
- Under XP: IPV6 Applications are not detected
- When Look 'n' Stop is started as a service, the context help doesn't work (help file has to be started manually)
- Under Vista: Features requiring Look 'n' Stop to be started as Admin:
- The registration to the Windows security center
.rie file association
Plugins
- Plugins have to give their interface version now. Old plugins are considered as using interface 1.01 by default.
- Rule edition: IPV6 compatibility, and 16 fields per rule available
- Rule edition: added an AND/OR operator between two consecutive fields.
- Rule edition: added an OR criteria with 3 values to be compared with.
- Rule edition: Log attribute and Application list added to the interface.
Minimum configuration
- Windows Vista
- Windows XP
- Windows 2000
- Windows server 2003
- Windows Millenium
- Windows 98 ou 95
:one: :one: :one: :one: :one: :one: :one:
Vypadejte ' n ' Stop™ Firewall 2.06 je slučitelné s Windows Vistami TM právě teď !
Snadnější a ještě víc účinný, vypadá ' n ' Stop™ Firewall 2.06 zabezpečuje vaše spojení !
Vypadejte ' n ' zastavovací firewall 2.06 nabízí mnoho zvětšení s ještě klíčovými rysy dole.
> bloky spywares a lesní dělníci stisknutí kláves.
> dělá váš PC neviditelný hakerům.
> rychlý download a rychlé nastavení.
> ven z krabicové konfigurace.
> dráhy útoky pokusí se o skrz nahrané události.
> zahrnujte ochranu heslem konfigurace.
> velmi účinný a vysoce konfigurovatelný pro pokročilé uživatele.
> uvádí rozšíření skrz plugins.
> automatické aktualizace nová vydání.
Nové rysy
- podporujte pro Windows Visty- Internet filtrování (Windows 2000/2003/XP/Vista): IP V6 podpora (internetového Protocolu Version 6)- aplikační filtrování (Windows Vist jen): IP V6 podpora- internetového Filteringu (Windows 2000/2003/XP/Vista): nová volba k tomu, aby ovládala fragmentované balíčky.- aplikaci filtrování (Windows 2000/2003/XP/Vista): nová volba k tomu, aby měla aplikaci filtrování ještě aktivní dokonce když Look ' n ' zastavení je zastavené (trvalá aplikace filtrování)- aplikační filtrování (Windows 2000/2003/XP/Vista): možnost přidat ne - standardní rozšíření pro mateřskou aplikace.- novou volbu přidružený importuje soubory (.rie) do vypadat ' n ' zastavení. Toto dovolují importovat soubor kliknutím spojením či dvojité kliknutí na a .rie soubor.- vyskakovací pozici je ušetřený.- přímý přístup k pravidlu z kmenu (s pravým kliknutím).- režimovým startem služby nyní je k dispozici ve volbách (ne podporovaný pro Vistu).- pravidlo vydání: přidaný "Rovnejte se/odlišný od můj @" pro MAC adresu.- pravidlo vydání: přidal "Místní Port" kritéria pro výběr přístavu (standardně tato kritéria vybírá rozsahový 1024-5000, kromě pod Vistou tou je 4915...) .
Změny
- automatický výběr síťového rozhraní je v každém případě dělaný na vyjmutý IP jestli žádné jiné síťové rozhraní s platný IP byl nalezený..- pravidlo a kmen soubor není již ušetřený v Look ' n ' zastavovací instalační složce ale v následující složce: "Dokumenty a nastavení[uživatel]místní SettingsApplication Datalooknstop" (Windows 2000/2003/XP/Vista jen; a pro čerstvý instalovat jen)- registraci již není dělaný skrz "Vypadejte ' n ' instrukce zastavení" ale s emailovou adresou.- "Sledovat nit injekci" a "Hlídací DNS volání" nejsou již dostupná prozatím.- explicitní volba byla přídavná příkazová řádka k tomu, aby začala několik příkladů Look ' n ' zastavení. A dvojklik na looknstop.exe ne déle začne druhý příklad.- kdy pohled ' n' zastavení je počaté ve službě mód, jestli uživatel výpočet, vypadat ' n' zastavení již není zastavené (a restartované).- množství filtrujícího pravidla je nyní 128 pro internetové filtrování.- množství pravidel/aplikací je nyní 200 pro aplikaci filtrování.- množství TCP SPI je nyní konfigurovatelné skrz registr- nové displejové možnosti v TCP spojeních dialogovém okně.- přidaný více informací pro TCP SPI výstrahy- v dialogovém okně k tomu, aby spojovalo aplikaci k pravidlu plné cestě vybrané aplikace byla přidaná.
Upevnit
- několik oprav a zlepšení v TCP SPI (zvláště v překročení časového limitu zacházení)- automatickým výběrem síťového rozhraní nepracovalo v nějakých specifických okolnostech.- po překrývací oknech je zavřené nyní ohnisko je znovu nasadí počáteční aplikace která má ohnisko předtím.- při úpravě pravidla s plugin, nějaká kritéria nebyla ušetřená pořádně.- kdy aplikace byla spojená k pravidlu, modifikování atributu (kmenu, dovolit/blok) pravidla také modifikovalo jeho aktivaci bez dívat se do aplikační stavu / státu..- barevná displejová záležitost kdy počatý ve službě mód.- soustava nějaké atribut update displeje v internetovém Filteringu stránce kdy pravidle je aktualizované pluginým.- Internetem Filteringem (Windows 2000/2003/XP/Vista): havárie v startu s nějakým Ethernetem adaptérem jmény- aplikačním filtrováním (Windows 2000/2003/XP/Vista): Přidaná oprava v identifikaci procesů zjistit nějakou leaktests/záludnou software výměnu aplikační procesové cesty v uživatelském režimu.- problému někdy při dělání pravidle kopii/vlepí internetová Filtering.- kdy nastavení byla zamčený s heslem, odejít od menu v podnosu ikoně nebyla stínovaný jestli překladový plugin byla umožněný.
Známý vydává
- pod XP: IPV6 Applications není objevený- kdy pohled ' n ' zastavení je počaté jak služba, pomoc souvislosti nepracuje (soubor nápovědy musí být počatý ručně)- pod Vistou: Rysy požadující Look ' n ' zastavení který má být počaté jak Admin:
- registrace k windowsovskému bezpečnostnímu centru
.rie souborové spojení
Plugins
- Plugins musí dát jejich rozhraní verzi právě teď. Starý plugins jsou považovány za používání rozhraní 1.01 standardně.- pravidlo vydání: IPV6 kompatibilita, a 16 pole za pravidlo dostupné- pravidlo vydání: přidal AND/OR operátora mezi dvěma za sebou jdoucí pole.- pravidlo vydání: přidal OR kritéria s 3 hodnotami k tomu, aby srovnávala s.- pravidlem vydáním: Lodní rychloměr atribut a Application seznam přidaný k rozhraní.
Minimální konfigurace- Windows Visty- windowsovský XP
- Windows 2000- windowsovský server 2003- windowsovský Millenium- Windows 98 ou 95
