Aktuálny čas je Sob 10. Okt 2026 18:07:40
 Prevent Recovery
 Predmet príspevku: Prevent Recovery
PoslaťNapísal: Str 11. Nov 2009 8:03:10
Just by emptying Recycle Bin the files and folders are not gone forever. Anyone can use special recovery software to restore any deleted items. Yes, this is true and its the way Windows works. Any deleted file still exists on the hard disk until overwritten with some other content, for example with some other file. Someone can recover your secret files when you're away or if you sold your PC, that's why you should use Prevent Recovery.
Mission
The main purpose of the Prevent Recovery program is to make deleted files and folders unrecoverable. The program made as Wizard program and will be friendly for any computer user, even newbie. Prevent Recovery will overwrite all free space on your hard disk(s) that contain fragments of deleted files with the random data to avoid any possibility of recovery. It uses several security algorithms (DoD 5220.22, Gutmann you can replace deleted data with random characters, digits, spaces e.t.c.). While writing Prevent Recovery fills out information to the end of each cluster, leaving no chance to restore even just one word!
Is there any chance to recover data that was overwritten?
Here is an answer from world knowledge base WikiPedia: "Since 1996 ...there's no practical evidence that overwritten data can be recovered. Moreover, there are good reasons to think that it cannot." Prevent Recovery makes unrecoverable temporary files, cached files, logs e.t.c. which were also previously deleted.
Why this program should overwrite all free disk space?
While working Prevent Recovery takes all free disk space, but when finished free space will be returned to previous condition. Don't worry about that. Its made to make sure that all possible free space was overwritten. The main reason why it should be done this way is that Windows write files to any place on the hard disk - to the end of free space, to the beginning, in the middle... And the result is that deleted files located everywhere! That's why its important to fill out all free disk space.
Will it work with removable storage?
Yes, Prevent Recovery can wipe deleted files on any disk like usb flash disk, memory stick or any other sort of removable disk (media storage). However you cannot use it on CD (CDR, DVD) - such disks should be physically burn to avoid any possibility of recovery.
Clears Windows paging file (virtual memory cache)
Some programs can store unencrypted (as text) passwords or other sensitive information in computer's memory. Because of the Windows virtual memory structure, this information can be located in the paging file. Prevent Recovery will wipe contents of this system file to protect your privacy.
Maximum speed
Because your hard disk free space can be over hundred Gigs, complete anti-recovery process can take a while. For example, up to one hour or even more on a large disk free space. Its normal. You can leave Prevent Recovery working and it will turn off computer when done. There is also built-in option to prevent computer from StandBy mode to make sure all operations will be fully complete.
Jen tím, vyprazdňování koše soubory a složky, které nejsou navždy pryč. Někdo může použít speciální software pro obnovu obnovit všechny smazané položky. Ano, to je pravda a jak funguje systém Windows. Jakékoli smazaný soubor stále existuje na pevný disk až přepsat některé další obsah, například s některými jinými souboru. Někdo může obnovit vaše tajné soubory, když jste pryč, nebo pokud jste prodali váš počítač, to je důvod, proč byste měli používat prevenci zotavení.
Poslání
Hlavním účelem Zabránit program obnovy je, aby se smazané soubory a složky obnovit. Program se jako průvodce programem a bude přátelské pro každý uživatel počítače, i nováček. Zabránit obnovení přepíše všechny volné místo na pevném disku (y), které obsahují zbytky odstraněných souborů s náhodnými daty, aby se zabránilo jakékoliv možnosti využití. Používá několik bezpečnostních algoritmů (DoD 5220.22, Gutmann můžete nahradit smazaná data s náhodnými znaky, číslice, mezery atd.). Při psaní Zabránit obnovy vyplní údaje na konci každého clusteru, takže žádná šance obnovit i jen jedno slovo!
Je tu nějaká šance obnovit data, která byla přepsána?
Zde je odpověď od základu znalostí světových Wikipedie: "Od roku 1996 ... neexistuje žádný konkrétní důkaz, že přepsání data mohou být vymáhány. Kromě toho existují dobré důvody domnívat se, že tomu tak není." Zabránit obnovení dělá nepoužitelný dočasné soubory, soubory v mezipaměti, logy atd. který byl také v minulosti zrušena.
Proč tento program by měl přepsat veškeré volné místo na disku?
Při práci Zabránit zotavení bere veškeré volné místo na disku, ale po dokončení volného místa, bude vrácena na předchozí stav. Nebojte se o tom. Jeho se, aby se ujistil, že všechny možné volné místo byl přepsán. Hlavním důvodem, proč by mělo být provedeno tak, že systém Windows zapisovat soubory na jakékoliv místo na pevném disku - na konci volného místa, na začátku, uprostřed ... A výsledkem je, že smazané soubory umístěny všude! To je důvod, proč své důležité vyplnit všechna volného místa na disku.
Bude to pracovat s vyměnitelné úložiště?
Ano, Zabránit zotavení mohou vymazat smazané soubory na každém disku jako USB flash disk, Memory Stick nebo jakýkoli jiný druh vyměnitelný disk (media storage). Však nelze použít na CD (CDR, DVD) - takové disky by měly být fyzicky hořet, aby se zabránilo jakékoliv možnosti využití.
Vyčistí systém Windows stránkovací soubor (virtuální paměť cache)
Některé programy mohou ukládat nešifrované (jako text), hesla nebo jiných citlivých informací v paměti počítače. Protože virtuální paměti systému Windows strukturu, mohou být tyto informace umístěny do stránkovacího souboru. Zabránit obnovení smaže obsah tohoto systému souborů na ochranu vašeho soukromí.
Maximální rychlost
Proto, že na pevném disku volné místo, může být více než sto koncertů, proti-kompletní obnovy proces může chvíli trvat. Například, až na jednu hodinu nebo dokonce více na velkém volného místa na disku. Normální. Můžete zanechat Předejít Obnova pracovních a vypne počítač, kdy udělal. Tam je také postaven-v možnosti, aby se zabránilo počítače z pohotovostního režimu, aby se ujistil všechny operace, které bude plně dokončena.
