Aktuálny čas je Ned 11. Okt 2026 0:44:34
 4WomenOnly 7 - Výlučne pre naše milé Warezáčky
 Predmet príspevku: 4WomenOnly 7 - Výlučne pre naše milé Warezáčky
PoslaťNapísal: Štv 05. Nov 2009 15:24:02
Táto téma je síce o naších roztomilých ženských stvoreniach, ale nakolko sa jedná o ích bezpečnosť zdravia s toho titulu som to považoval za správné to pridať do sekcie BEZPEČNOSŤI - nech sa cítia naše milé kočky v absolutnom 100%-nom bezpečí....!!!
4WomenOnly is among the most powerful and easy to use systems for monitoring women's health.
There is a calendar for half a year, statistics for particular periods, features for exporting and printing data and much more. 4WomenOnly is a guardian angel for your female health, download it and see it for yourself! For setting-up it is possible to use Wizard. During working hide in quick launch bar. In the critical period quick launch icon is reflected by pink color.
According to you opinion the start of the program is made together with Windows. 4WomenOnly is a guardian angel for your female health. Download it and see for yourself!
A special wizard makes creating your own personal calendar easier. Do you have one or more female friends? Great! Create calendars for them as well to be able to choose optimal days for visiting parties or important occasions.
ere are some key features of "4WomenOnly":
· Calculates the number of your ovulation day (your luteal phase) in several ways
· Uses the calendar to mark the last day before ovulation, menstruation days, ovulation days with the probability of conception in percent for each day, days with the very low probability of conception, days on which intercourse occurred and also the prediction of the child's sex using the calendar method
· Displays a calendar for half a year with scrolling
· The appearance of the calendar is customizable, there is a list of predefined themes and you can create your own themes
· Displays a chart showing the probability of conception for a particular day in the menstrual cycle
· Supports several calendars (for example, your female friends' calendars)
· Predicts the sex of a child by the Chinese Lunar Calendar
· Displays detailed information about the future child's birth date in case the conception took place on a certain day (sex, lunar phase, horoscope, celebrities born on this day, etc.)
· Displays the number of days till the next menstruation and ovulation
· Supports irregular cycles storing the duration of all previous cycles and menstruations
· Calculates and displays on the calendar future cycles based on the parameters of the last cycle
· Allows you to edit the parameters of the current and each previous cycle
· Allows you to record the state of your health every day
· Displays detailed statistics for the period you specify
· Sexual activity statistics
· Comparing calendars
· Displays a table with summary data for the period you specify
· Allows you to set reminders for upcoming menstruation and ovulation
· The Wizard is used to specify the parameters of each calendar
· Minimized into a tray icon with color indication for the current day (menstruation, ovulation, etc.)
· Displays a small calendar when you move the mouse pointer over the tray icon of the program
· Has a Date/Time Calculator
· Exports data in the HTML, XML and text formats
· Has an extended print output
· Allows you to configure it to be started automatically together with Windows and you can disable it
· Allows you to protect viewing program data with a password
· Future child extrapolation
· Original, modern and classic interface
· Export and import calendar data
· Simple and extended mode
· Alternative gender prediction
· Body weight calculator
· Body mass index
· Body fat calculator
· Waist to hip ratio calculator
· Basal metabolic rate
Naše milé warezáčky to je o čistote trhliny, lebo nemám záujem Vás nakaziť žiadným vírom, lebo ja ženský rod zbožnujem nadovšetko, lebo bez Vás by som sa už určite dávno zbláznil...!!!
http://www.virustotal.com/analisis/28e24b2f269dc7c41ae964b5a2b4fa65806df2d28ea89242d893650aeda5378c-1257426848
4WomenOnly patří mezi nejvýkonnější a snadno použitelný systém pro monitorování zdraví žen.
Tam je kalendář na půl roku, statistika pro konkrétní období, funkce pro export a tisk dat a mnoho dalšího. 4WomenOnly je strážný anděl pro ženské zdraví, stahovat a podívat se sami! Pro nastavení-up je možné použít průvodce. Během pracovní skrýt v panelu rychlého spuštění. V kritickém období rychlého spuštění ikony se projevuje růžovou barvou.
Podle názoru si spuštění programu se provádí společně s Windows. 4WomenOnly je strážný anděl pro ženy zdraví. Stáhněte si ji a přesvědčte se sami!
Speciálního průvodce při vytváření své vlastní osobní kalendář jednodušší. Máte jednu nebo více kamarádky? Velký! Vytvořit kalendáře pro ně také bylo možno vybrat optimální dnů za návštěvu stran či důležitých příležitostech.
ere jsou některé klíčové rysy "4WomenOnly":
· Vypočítá počet vašich den ovulace (vaše luteální fáze) několika způsoby
· Používá kalendář označit poslední den před ovulací, menstruace, dny, ovulace dnů pravděpodobnost početí procent za každý den, dny s velmi nízkou pravděpodobnost početí, den, kdy došlo stykem a také předpověď pohlaví dítěte kalendáře pomocí metody
· Zobrazí kalendář na půl roku s scrolling
· Podoba kalendáře je možné přizpůsobit, tam je seznam předdefinovaných témat a můžete vytvořit svá vlastní témata
· Zobrazí graf ukazující pravděpodobnost početí na konkrétní den v menstruačního cyklu
· Podporuje několik kalendářů (např. kalendář vaše kamarádky ')
· Předpovídá pohlaví dítěte ze strany čínských Lunární kalendář
· Zobrazí detailní informace o budoucnosti dítěte, datum narození v případě, že koncepce se konala v určitý den (sex, měsíční fáze, horoskop, celebrity narodil v tento den, atd.)
· Zobrazuje počet dnů až do příští menstruace a ovulace
· Nepravidelné cykly, podporuje ukládání trvání všech předchozích cyklů a menstruací
· Vypočítá a zobrazí na cyklech kalendáři budoucnost založenou na parametry posledního cyklu
· Umožňuje upravit parametry stávající a každý předchozím cyklu
· Umožňuje zaznamenávat stav Vašeho zdraví každý den
· Zobrazí podrobné statistiky pro období určíte
• Sexuální aktivita statistiky
· Srovnání kalendáře
· Zobrazí tabulku souhrnné údaje za období určíte
· Umožňuje nastavit připomenutí na blížící se menstruace a ovulace
· Wizard slouží k zadání parametrů každého kalendářního
· Minimalizované na ikonu s barevným označením pro aktuální den (menstruace, ovulace, atd.)
· Zobrazí malý kalendář při pohybu kurzoru myši na ikonu programu
· Má Datum a čas Kalkulačka
· Export dat do HTML, XML a textových formátech
· Byla rozšířena tiskových výstupů
· Umožňuje nastavit, aby se automaticky spustí spolu s Windows a můžete zakázat
· Umožňuje prohlížení programu na ochranu dat heslem
· Budoucí dítě extrapolace
· Originální, moderní a klasické rozhraní
· Export a import dat kalendáře
· Jednoduchý a rozšířený režim
· Alternative pohlaví predikce
· Tělesná hmotnost kalkulačka
· Body mass index
· Tělesný tuk kalkulačka
· Poměr pasu k bokům kalkulačka
· Bazální metabolismus
Zbožnujem ženské stvorenie, ale predovšetkým blondýnky, ktoré pokladám za královné ženského rodu...
