Aktuálny čas je Ned 20. Sep 2026 0:44:54
 Portable Trojan Remover 6.6.9 build 2525
 Predmet príspevku: Trojan remover
PoslaťNapísal: Uto 03. Feb 2009 1:13:01
Registrovaný: Sob 24. Jan 2009 22:15:02
Trojan Remover 6.6.9 Build 2525
Antivirový nástroj k detekci a následnému odstranění trojských koní a červů ze systému. Viry jsou odstraňovány ze systémových souborů i registrů. Program má v databázi téměř 16 000 různých variant červů a trojských koní.
Program Update 6.6.9 - [Build 2525]
* Added new rootkit detection routines.
* Added new checks for malicious entries in the HOSTS file.
* Added new checks for "Fake Alert" desktop wallpapers.
* Modified the scan of Active Setup registry keys to correctly scan called DLL files.
* Improved detection routine for the Backdoor.Rustock family of malware drivers.
Trojan Remover 6.6.9 Build 2525 (+CRACK)
 Predmet príspevku: Portable Trojan Remover 6.6.9 build 2525
PoslaťNapísal: Štv 26. Feb 2009 22:14:01
Trojan Remover aids in the removal of Malware - Trojan Horses, Worms, Adware, Spyware - when standard anti-virus software either fails to detect them or fails to effectively eliminate them. Standard antivirus programs are good at detecting this Malware, but not always so good at effectively removing it.
Trojan Remover is designed specifically to disable/remove Malware without the user having to manually edit system files or the Registry. The program also removes the additional system modifications some Malware carries out which are ignored by standard antivirus and trojan scanners.
Trojan Remover is designed to work on Windows 98/ME/2000/XP/Vista. The program is not, at present, compatible with any 64bit version of Windows.
