Aktuálny čas je Ned 29. Nov 2026 10:37:32
 Transmute Pro Version 1.17
 Predmet príspevku: Transmute Pro Version 1.17
PoslaťNapísal: Uto 19. Jan 2010 10:53:44
Convert your bookmarks between different formats quickly and easily! Use it to try out different web browsers, or even to make the switch to a new web browser. Or maybe you need to synchronize your bookmarks between different systems? The Transmute application can be used for all of this and more.
Transmute is the first and only bookmark converter to support the latest formats:
Google Chrome:
Transmute supports the new Chrome browser, including dev channel releases.
Mozilla Firefox:
Firefox 1 & 2 are supported as well as Firefox 3, with its new database model.
Microsoft Internet Explorer:
Internet Explorer favorites can be imported and exported with ease.
Opera:
Opera hotlists are also well supported for easy importing and exporting.
Here are some key features of "Transmute":
Modern:
· Transmute can import and export bookmarks between the latest formats, including both Google Chrome and Mozilla Firefox 3!
Easy to use:
· Convert your entire bookmark collection in as little as one click! A streamlined interface and automatic bookmark collection location make Transmute very accessible.
Flexible:
· Transmute provides the option to merge existing collections together, rather than overwriting your old file.
Safety first:
· There is an option to backup your existing bookmark collection before any changes are made.
· .NET 2.0
What's New in This Release: [ read full changelog ]
· Added Flock bookmark support
· Added limited SeaMonkey bookmark support
· Added support for importing and exporting bookmarklets in Firefox, Internet Explorer and Opera
· Changed the language menu to display each item in the cultures native language
· Fixed East Asian characters being converted to hex when importing from Chrome
· Fixed Firefox 1-2 importer failing on non-XML-compliant anchor tag contents
· Fixed some text elements are not immediately updated when the active language is changed
· Fixed toggle glyph not showing next to Options on systems not using Visual Styles
pass : D.DECODER
Konvertovat své záložky mezi různými formáty snadno a rychle! Použijte jej vyzkoušet různé webové prohlížeče, nebo dokonce, aby přechod na nový webový prohlížeč. Nebo možná budete muset provést synchronizaci záložek mezi různými systémy? Transmute aplikace lze použít pro všechny tyto a další.
Přeměnit je první a jediný záložku konvertor pro podporu nejnovějších formátů:
Google Chrome:
Transmutaci podporuje nový prohlížeč Chrome, včetně dev kanál zpráv.
Mozilla Firefox:
Firefox 1 a 2 jsou podporovány, stejně jako Firefox 3, s jeho novou databázi model.
Internet Explorer oblíbené položky mohou být dováženy a vyváženy s lehkostí.
Opera:
Opera hotlists jsou také podporovány i pro snadný import a export.
Zde jsou některé klíčové rysy "Transmute":
Moderní:
· Transmute může importovat a exportovat záložky mezi nejnovější formáty, včetně Google Chrome a Mozilla Firefox 3!
Snadné používání:
· Převést celou sbírku záložek v jak malý jako jedno kliknutí! Zjednodušené rozhraní a automatický sběr záložku Transmute poloha činí velmi přístupný.
Flexibilní:
· Transmute poskytuje možnost sloučit stávající sbírky spolu, spíše než přepsání starého souboru.
Bezpečnost především:
· Existuje možnost zálohovat existující záložku sbírky před jakýmkoli změnám.
Net. 2.0
Co je nového v této verzi: [celý seznam změn]
· Added Flock záložku podpora
· Added SeaMonkey omezenou podporu záložek
· Byla přidána podpora pro import a export bookmarklety v prohlížeči Firefox, Internet Explorer a Opera
· Změněno jazyk menu zobrazit všechny položky v kulturách rodném jazyce
· Pevné východoasijské znaky převáděny na hexadecimální při dovozu ze Chrome
· Pevné Firefox 1.2 dovozce, není-li na non-XML-kompatibilní obsah kotva tag
· Fixed some text prvky nejsou okamžitě aktualizovat při změně aktivní jazyk
· Pevné přepnutí symbol neudává, vedle Volby v systémech, které nepoužívají Visual Styles
