Aktuálny čas je Pon 05. Okt 2026 19:23:53
 NEW - Wondershare Registry Optimizer 5.3.3
 Predmet príspevku: NEW - Wondershare Registry Optimizer 5.3.3
PoslaťNapísal: Štv 14. Jan 2010 13:43:11
Wondershare Registry Optimizer safely speed up your PC and improve system performance dramatically! Keep it running like new! It runs a comprehensive registry scan and safely repairs registry errors,clean junk files and protect your privacy, defrag registry to a streamlined structure and further optimize system.Have all the above done in a few mouse clicks. Protect your computer from crashes, slowdown or error messages.
- Scan and repair registry errors, make PC more stable
- Spare you the hassle of computer freezes and crashes
- Optimize your computer for peak performance
- Speed up PC boot and responsiveness of programs and games
- Safeguard your privacy by erasing traces left on computer
Wondershare Registry Optimizer Consists of three main function modules: clean center, optimize center and system tools. With the intuitive and logically-organized interface, you can access any part in single one click. Even novice users can complete all cleaning and optimizing work in a few minutes, and for computer enthusiasts, there are more customizable options.
• Clean Center
Scan and clean Windows registry to keep PC running error free! Most PC errors and crashes due to errors in registry. Regular cleaning can improve system stability and performance!
Safeguard your privacy by erasing traces left on your computer. Worry about browser cookies? You can keep them as you want!
Cleaning up invalid shortcuts helps free up disk space, and remove clutter in desktop and hard drives.
We guarantee safety of your PC! Each registry repair is backed up automatically, and you can select a restore point and undo previous change if required.
• Optimize Center
Optimize your computer performance and running speed in 1 click. Not sure what is going on? Just click the question mark after each item and decide whether to optimize it or not. Let you control the optimization like a professional!
Registry defragmentation: Analyze your registry and display a report of the fragmentations. Build a new streamlined registry that takes up less memory and speed up application response.
• System Tools
Repair IE: Fix IE errors and restore over 70 common settings of IE to original state.
Uninstall manager: safely and completely uninstall unwanted applications without going to the Control Panel
Speed up PC boot: reduce PC boot time by managing applications that automatically start when you boot your computer.
Built-in System Tools: Give direct access to built-in system tools of Windows, such as Registry Editor, Disk Cleanup, Disk Defragmenter, etc
PASS : Larija
Wondershare registru pro optimalizaci bezpečně zrychlit počítač a dramaticky zvýšit výkon systému! Keep it běží jako nové! Provozuje komplexní registru scan registru a bezpečně opravy chyb, čisté nevyžádané soubory a chránit své soukromí, oklamat rejstříku na racionálnější strukturu a dále optimalizovat system.Have všechny výše uvedené provedeno několik kliknutí myší. Chraňte svůj počítač před pády, zpomalení nebo chybová hlášení.
- Kontrola a oprava chyb registru, aby PC stabilnější
- Náhradní vás nepříjemného počítač zamrzne a pády
- Optimalizace počítače pro špičkový výkon
- Urychlit startu PC a vstřícnost programů a her
- Ochranná vaše soukromí tím, že mazání stopy zanechané v počítači
Wondershare optimalizaci registru se skládá ze tří hlavních funkcí modulů: čistý center, center a optimalizaci systémových nástrojů. S intuitivní a logicky-organizované rozhraní, můžete přistupovat na libovolnou část v jednotlivých jedním kliknutím. Dokonce i začínajícím uživatelům může splnit veškeré čištění a optimalizaci práce v několika minut, a pro počítačové nadšence, existuje více možností přizpůsobit.
• Clean Center
Skenování a čištění registru systému Windows, aby PC s operačním systémem bez chyb! Většina PC chyby a pády v důsledku chyby v registru. Pravidelný úklid může zlepšit stabilitu systému a výkon!
Chránit vaše soukromí tím, mazání stopy zanechané v počítači. Bát prohlížeči cookies? Můžete je uchovávat, jak chcete!
Vyčištění neplatné zkratek pomáhá uvolnit místo na disku, a odstranit nepořádek na ploše a pevné disky.
Garantujeme bezpečnost vašeho počítače! Každý rejstřík je oprava zálohovány automaticky, a můžete vybrat bod obnovení a vrátit zpět předchozí změny, pokud to vyžaduje.
• Optimalizace Center
Optimalizovat výkon počítače a rychlost jízdy v 1 tlačítko. Nejste si jisti, co se děje? Stačí kliknout na otazník po každé položky a rozhodnout se, zda optimalizovat, nebo ne. Umožňují kontrolu optimalizace jako profesionál!
Defragmentace registru: Analýza registru a zobrazí zprávu o fragmentations. Vybudovat nové zjednodušené registr, který zabírá méně paměti a urychlení odezvy aplikací.
• Nástroje pro správu systémů
Oprava IE: IE Fix chyby a obnovit více než 70 společných nastavení IE do původního stavu.
Uninstall manager: bezpečně a úplně odinstalovat nechtěné aplikace, aniž by na Ovládací panely
Zrychlit spuštění PC: snížit PC startu řízením aplikací, které se automaticky spouštějí po startu počítače.
Built-in Systémové nástroje: Dejte přímý přístup k stavěný z-do systémové nástroje systému Windows, jako jsou Editor registru, Vyčištění disku, Defragmentace disku, atd.
GOOGLE PREKLADAL...!!!
