Aktuálny čas je Uto 22. Sep 2026 12:29:31
 Absol.New - CDMenuPro Business Edition 6.32.00
 Predmet príspevku: Absol.New - CDMenuPro Business Edition 6.32.00
PoslaťNapísal: Pon 23. Nov 2009 7:52:03
CDMenuPro is an easy-to-use CD Menu Creator for making Autorun CD Menu applications. The program comes complete with a large number of ready-to-use templates and project assistants, which make getting fast professional results child's play. CDMenuPro has been designed to create all the files necessary for autorun, to support a large number of trailers such as AVI, Intro, Sound, Splash Screen and to start your programs or documents reliably from your CD. Menu access control You can now make accessing the menu dependent on a password and/or licensing agreement. ArchiveSafe Restricting access to the menu, however, only makes sense when the data on the CD is also protected.
And it is set against this background that we have developed a new program add-on: "ArchiveSafe". New viewer as an add-on program The CDMenuPro software package now comes with two new Viewers: A RichText Viewer for presenting formatted text A Html Viewer for presenting Html files Improved Image Viewer. Embedded Viewer CDMenuPro comes with two new embedded viewers: A RichText Viewer for presenting formatted text A Image Viewer Copyright and file information. It is now possible to define the file information that is displayed in XP Windows Explorer's Tooltip window (producer, copyright, date, version) PowerPoint Starter The PowerPoint Starter has been completely re-developed. A separate PowerPoint viewer can be specified for each Windows Version as an option Pdf Starter The Pdf Starter has been completely re-developed. A separate Pdf Reader can be specified for each Windows Version as an option Easier to use Menu objects can be positioned using the cursor keys. The size of menu objects can be altered using the cursor keys. Improved cursor position display. Multiple improvements An incredibly large number of small improvements have been integrated into this version, particularly with regard to making the program easier to use.
Here are some key features of "CDMenuPro Business Edition":
· Creates all the files necessary for the CD Autostart feature.
· Using graphics to create a background and buttons makes it possible to design the menu to suit your needs.
· Rectangular, oval or round menu windows with or without title bars.
· Buttons available in the following styles: Windows, Bitmap, Office, Outlook, Hyperlink, Image.
· Up to 25 sub-menu pages for each menu page and 4 hierarchical levels are possible.
· You can integrate your own intros
· Automatic start of an AVI Video Trailer
· Splash Screen
· Optional: Menu access control (Password, License Agreement)
· Optional: The ability to protect data on the CD against unauthorized access
· Open a document in the user's viewer.
· Start a application, with the option of passing a command line argument.
· Windows Explorer can be started in any folder.
· Start programs & files using: action buttons, list boxes, pop-up menus, context menus
· Open and display local internet pages and intranet pages
· Open a pre-addressed email application.
· External Viewer (Royality Free)
· Text Viewer
· RichText Viewer
· Html Viewer
· Image Viewer
· Embedded Viewer
· Text Viewer
· RichText Viewer
· Image Viewer
· Integrated AVI player
· Integrated sound player
· Background sound and/or button sound
· Speaker control
· Tooltips
· Project wizards
· Drag & Drop - interface
· Resource browser and templates
· Add-on software
· The viewers and the PowerPoint and Pdf Starters can be added to the CD (Royalty Free)
· Icon Converter (Bmp -> Icon)
· Resource Compiler (adds the resource files belonging to your menu into the menu application file)
· Insert your copyright and file information into the menu application
· No programming knowledge required.
· Detailed documentation
· Full install and uninstall make getting started quick and easy.
· Support free of charge
· Complementary programs:
· Bitmap Icon Konverter.
· Button Creator.
· Text Viewer.
· Rich Text Viewer.
· Html Viewer.
· Image Viewer.
· ArchiveSafe (file protection)
· Only in the Business Edition:
· PowerPoint Starter
· Pdf Starter
· Resource Compiler
Operating system:
Win 95 / 98 / ME / NT / 2000 / 2003 / XP / Vista / Windows7
CDMenuPro.v6.32.00.Business.Edition.rar (10,1 MB)
CDMenuPro je bezstarostný-až k-cvičení Menu CD Creator pro vytváření Autorun CD menu aplikace. Program přichází spolu s velkým počtem ready-k-použití šablon a projektů asistentů, které stále rychle profesionálních výsledků dětskou hrou. CDMenuPro byl navržen tak, aby vytvořili všechny soubory potřebné pro autorun, podpora velkého množství přívěsů, jako je AVI, Intro, zvuku, splash a spustit programy nebo dokumenty spolehlivě z vašeho CD. Menu kontrola přístupu Nyní můžete udělat pro přístup k menu závisí na heslo a / nebo licenční smlouvu. ArchiveSafe Omezení přístupu do menu, ale má smysl pouze, když jsou data na CD také chráněny.
A je nastavena na tomto pozadí jsme vyvinuli nový program add-on: "ArchiveSafe". New prohlížeč jako add-on program CDMenuPro balíček softwaru, nyní přichází se dvěma novými Diváci: RichText Viewer pro prezentace Text ve formátu HTML prohlížeč pro předkládání Html souborů Vylepšené Image Viewer. Embedded Viewer CDMenuPro přichází s dvěma novými vložených diváků: RichText Viewer pro předkládání formátovaný text Image Viewer Autorská práva a informacemi o souborech. Nyní je možné definovat soubor informací, které se zobrazí v okně programu Průzkumník Windows XP je Tooltip (producent, copyright, datum, verze) PowerPoint PowerPoint Starter Starter byl kompletně re-rozvinutý. Samostatný PowerPoint Viewer může být stanoveny pro jednotlivé verze Windows jako možnost Pdf Pdf Starter Starter byl kompletně re-rozvinutý. Samostatné PDF Reader lze zadat pro každou verzi systému Windows jako možnost snadnější použití menu objekty mohou být umístěny pomocí kurzorových kláves. Velikost menu objektů lze měnit pomocí kurzorových kláves. Zlepšil pozici kurzoru displej. Více zlepšení neuvěřitelně velké množství drobných vylepšení, byly začleněny do této verze, a to zejména s ohledem na vytváření programu jednodušší.
Zde jsou některé klíčové rysy "CDMenuPro Business Edition":
· Vytvoří všechny soubory potřebné pro funkci CD Autostart.
· Použití grafiky vytvořit pozadí a tlačítka umožňuje navrhnout menu pro vaše potřeby.
· Pravoúhlé, oválné nebo kruhové menu s okny nebo bez titulkové pruhy.
· Tlačítka jsou k dispozici v těchto stylech: Windows, Bitmap, Office, Outlook, Hyperlink, Image.
· Až 25 sub-menu stránky pro každou stránku a menu 4 hierarchické úrovně jsou možné.
· Můžete integrovat svůj vlastní intra
Automatický start AVI Video Trailer
· Splash
· Volitelné: Menu řízení přístupu (hesla, License Agreement)
· Volitelné: schopnost chránit data na CD před neoprávněným přístupem
· Otevřete dokument v prohlížeči uživatele.
· Start aplikace, s možností přenosu z příkazové řádky argument.
· Průzkumník Windows je možné spustit v libovolné složky.
· Start Programy & soubory pomocí: akčních tlačítek, seznamů, pop-up menu, kontextová menu
· Open a zobrazení místních internetových stránek a intranetových stránek
· Open pre-určené e-mailové aplikace.
· Vnější Viewer (Royality zdarma)
· Text Viewer
· RichText Viewer
· HTML prohlížeč
· Image Viewer
· Embedded Viewer
· Text Viewer
· RichText Viewer
· Image Viewer
· Integrovaný AVI přehrávač
· Integrovaný hudební přehrávač
Pozadí zvuku a / nebo tlačítko zvuku
· Speaker ovládání
· Tooltips
• Project průvodců
· Drag & Drop - rozhraní
· Zdrojů prohlížeč a šablony
· Add-on software
· Diváky a PowerPoint a PDF Předkrmy mohou být přidány do CD (Royalty Free)
· Icon Converter (BMP -> Icon)
· Zdrojů překladačů (přidá zdrojové soubory, které patří do nabídky v menu soubor aplikace)
· Vložte vaše autorská práva a informace o souboru do menu aplikace
Ne potřebné znalosti programování.
· Podrobná dokumentace
· Kompletní instalaci a odinstalaci provést jak začít rychle a snadno.
· Support zdarma
· Doplňkové programy:
· Button Creator.
· Text Viewer.
· Rich Text Viewer.
· HTML prohlížeč.
· Image Viewer.
· ArchiveSafe (soubor ochrana)
· Pouze v Business Edition:
• PowerPoint Starter
· Pdf Starter
· Zdrojů překladačů
Operační systém:
