Aktuálny čas je Ned 01. Nov 2026 12:23:29
 PCHand Software PCHand Screen Recorder 1.0.0
 Predmet príspevku: PCHand Software PCHand Screen Recorder 1.0.0
PoslaťNapísal: Štv 12. Nov 2009 19:52:45
PCHand Screen Recorder is powerful yet easy-to-use screen record software to create video demonstration. You could not only record anything on screen, but also record the audio from PC or microphone. With PCHand Screen Recorder, a vivid video tutorial could be generated without difficulties, and in seconds!
* Record any screen activities with audio to create video instruction.
* Record soundtrack from Microphone and keep synchronous with video.
* Record any region of screen as you wish.
Key Features of PCHand Screen Recorder:
Easily record screen with audio
Recording screen can’t be easier than this. Just select an area, press “Start” and PCHand Screen Recorder will do the rest! According to your needs, it is available to choose full screen, a selected window or a selected area. In this specific area, any desktop activities could be record clearly, such as, cursor movement, left click, right click, etc. To make a live video, you could record audio from PC or voice from microphone at the same time. Don’t worry. PCHand Screen Recorder will keep it synchronous. Of course, soundless recording is supported
PCHand Screen Recorder creates industry standard AVI videos. It is small, lossless and popular to share on YouTube. How about the video or audio quality? From 1 to 100, that’s totally up to you! Want a special video? PCHand Screen Recorder comes with powerful setting to create your own style demonstration video. You are able to add cursor movement effects, mouse click effects to make the point highlight.
Standard AVI Video
Powerful setting
Support hotkey settings to set hotkeys for start, pause and stop screen recording.
Support setting video and audio quality.
Support saving the video automatically when finish recording screen.
Support minimizing the program when recording screen.
PCHand Screen Recorder je výkonný, ale bezstarostný-až k-cvičení obrazovce záznamu software pro vytvoření videa demonstraci. Dalo by se nejen zaznamenávat nic na obrazovce, ale také zaznamenávat zvuk z PC nebo mikrofonu. S PCHand Screen rekordér, živé video tutorial by mohly nastat bez potíží, a během několika sekund!
* Záznam na jakýkoli displej činnosti s audio vytvořit video návod.
* Záznam soundtrack z mikrofonu a udržovat synchronní s videem.
* Záznam všech regionech obrazovky, jak si přejete.
Snadno zaznamenávat obrazovka s audio
Nahrávání obrazovky nemůže být jednodušší, než tohle. Stačí si vybrat oblast, stiskněte tlačítko "Start" a PCHand Screen rekordér udělá zbytek! Podle svých potřeb, je k dispozici na výběr celou obrazovku, vybrané okno nebo vybranou oblast. V této specifické oblasti, může být na každém pracovním stole činnosti záznam jasně, jako je pohyb kurzoru, klikněte levým tlačítkem, klepněte pravým tlačítkem myši, atd. Chcete-li živé video, můžete zaznamenat zvuk z PC nebo hlas z mikrofonu současně. Nebojte se. PCHand Screen Rekordér udrží to synchronní. Samozřejmě, nehlučně nahrávání je podporován
PCHand Screen rekordér vytváří průmyslový standard AVI video. Je malý, bezeztrátové a populární sdílet na YouTube. Co takhle video nebo audio kvalitu? Od 1 do 100, to je zcela na vás! Chceš speciální video? PCHand Screen Rekordér přichází s výkonnými nastavení vytvořit svůj vlastní styl demonstrační video. Jste schopni přidat efekty pohybu kurzoru, efekty myši, aby se místo zvýraznit.
Standard AVI video
Mocné nastavení
Podpora nastavení hotkey pro nastavení klávesových zkratek pro spuštění, pauza a zastavení nahrávání obrazovky.
Podpora nastavení video a audio kvalitu.
Podpora ukládání videa automaticky po dokončení nahrávání obrazovky.
Podpora minimalizace programu při nahrávání obrazovky.
Na Vaše vedomie :
Takéto malinké a jednoduché softíky sú najlepšie ako tento, lebo netreba v nom nič extra nastavovať iba spustit a už to aj jede. Práve hlavne tento softík práve preto používajú aj cybersvetový crackeri ako aj hackery na prezentáciu svojích diel, ktoré uploadujú aj na youtube. Aj náš tým ho preto používa ako aj iné slovensko-české podobné tými - viem teraz možno naší ustavičný poniektorí kritici hlavne na warezforach, ktorím sa nepáčí ako si ích to dráždí ked uvádzám o našom týme a možno aj teraz znova v sebe pripravujú nejakú myšlienku, ktorú možno znova budú aplikovat v podobe príspevkov ponižovania a osočovania. Neviem fakt prečo to môže poniektorích userov až tak dráždene znervôznovat aspon si teda myslím, že s dôvodu, že oni nikde do žiadných týmov nepatria s rôzných dôvodov, ktoré ale nemienim ani, len náhodov rozoberat i ked si ích aj viem priam živo predstavit prečo nepatria nikde do žiadných týmov.
