Aktuálny čas je Str 09. Sep 2026 15:14:00
 Font Creator Tools All in One
 Predmet príspevku: Font Creator Tools All in One
PoslaťNapísal: Uto 20. Okt 2009 13:00:40
Registrovaný: Pon 19. Okt 2009 20:47:09
Hotovosť: 90.00
POPIS.:
FontLab 4.6
FontLab is the professional font editor for Mac OS and for Windows. It is the comprehensive solution for font foundries, professional type designers, typographers and graphic design studios, allowing them to design type, create and modify fonts. FontLab supports all major outline font formats, including Type 1, TrueType, Multiple Master and OpenType.
AsiaFont Studio
AsiaFont Studio is the only commercially available two-byte font editor. You can create large Japanese, Chinese, Korean or Vietnamese fonts as well as any other multilingual Unicode-based OpenType fonts. AsiaFont Studio can handle fonts with up to 65,536 glyphs!
Note: OpenType Layout tables required for complex scripts such as Arabic, Devanagari or Thai can be added with the free Microsoft VOLT application.
TransType SE 2.5.1 & Pro 3.0.2
Our universal font converter allows you to convert practically any font into any other format on Mac and PC.
TransType converts fonts between major font formats: PostScript Type 1, TrueType, Multiple Master. The Pro edition also supports OpenType. TransType is available in two editions: Pro (Professional) and SE (Standard Edition), and runs on Mac and Windows.
ScanFont
you can turn graphics into fonts. Any bitmap image or outline illustration* can be quickly converted into a fully-workable font.
ScanFont 3 for Windows is a stand-alone application that supports bitmap graphics. ScanFont 4 for Mac supports bitmap and outline graphics and works as a plugin for FontLab 4.6 or TypeTool.
TypeTool
TypeTool is our basic font editor for Mac OS and for Windows. For students, hobby typographers and creative professionals who occasionally need to create or customize fonts.
Font Creator
With this award winning software, you can create and edit TrueType fonts. Use Font Creator's advanced import feature to make your own handwriting font or add signatures, logos or any other symbol to an existing font.
Design Fonts with Font Creator - Glyph Edit window
List of Key Features:
* View and edit TrueType and OpenType fonts
* Create new characters (glyphs) or create new fonts
* Modify individual glyph contours
* Add or correct composite glyphs
* Add kerning of glyph pairs
* Edit and correct font names and mappings
* Correct fonts that display incorrectly
* Transform individual glyphs or an entire font (e.g. to make a bold version)
* Preview fonts before installing
* Install fonts in Windows
* Unlimited undo, redo and repeat options
