Aktuálny čas je Štv 29. Okt 2026 15:10:12
 Registry Purify 4.58
 Predmet príspevku: Registry Purify 4.58
PoslaťNapísal: Pia 25. Sep 2009 20:42:56
Registry Purify analyze and clean invalid entries in Windows registry, backup and restore entire registry in system file level, compact registry to gain efficiency.
Main Features:
• New Scan Engine
Registry Purify improves analyzing speed over 50% than normal algorithm by using new "SharpANA Engine". Meanwhile, "SharpANA Engine" reduces reading of hard disk evidently, which protects your hard disk effectively. The proper use of multithread technology, reduces consumption of system resources.
• Automatic Undo File Creation And Easy Recover
For your convenience and for insuring maximum protection, Registry Purify automatically create undo file for any repairs made so that you can easily recover any changes again if required.
• Build-in Microsoft Registry Editor Support
By double click any entry found in Registry Purify list, Microsoft Regedit will run focusing on the entry you just clicked. It is convenient for you to examine each entry detailedly and then make your decision.
• Microsoft Regedit compatible Undo File
Registry Purify's registry undo file is compatible with Microsoft Windows Registry Editor Version 5.00. The registry file is fully opened to end users, meaning that you can edit directly or just import manually by double click on it.
• User Friendly GUI Interface
Registry Purify is powerful and simple to use. Its Interface has all the functionality and performance required in today's computing environments.
• Simple But Powerful and Safe
Registry Purify safely scans inside your Windows registry for errors, using robust analyzing algorithm , and repairs them with just a few mouse clicks.
• Registry Compact To Gain Read/Write Efficiency
When cleaned many invalid registry entries, registry compact is necessary to your registry. Registry Purify rebuilds the registry removing blanks in the entries to compact your registry.
• Reliable Registry Backup
Registry Purify supports registry backup of different time and creation any number of backup depending on your free hard disk space. For your convenience, registry backup file name takes format of "Year/Month/Day/Hour:Minute:Second".
• Efficient Registry Restore
In one simple dialog interface, registry restore and backup deletion can be finished easily and explicitly. Although number of? backup is not limited, Registry Purify will remind you to delete some backup when the number of registry backup is over 3, for backup files can be big.
• Two-Aspect Analyze
While analyzing registry entries, Registry Purify take action in two aspect: one is registry-based analyzing method, another is file-based analyzing method. By using the two-aspect analyze, Windows registry will be analyzed thoroughly to check out more invalid entries than ever.
Registry Očistěte analyzovat a čisté neplatné záznamy v registru Windows, zálohování a obnovu celého registru, na úrovni systému souborů, registru, kompaktní získat účinnosti.
Hlavní vlastnosti:
• Nová Scan Engine
Očistěte registru zvyšuje rychlost analýzy více než 50%, než je obvyklé algoritmus s využitím nových "SharpANA Engine". Zatím, "SharpANA Motor" snižuje čtení z pevného disku evidentně, která chrání pevný disk efektivně. Správného používání vícevláknové technologii, snižuje spotřebu systémových prostředků.
• Automatické Zpět vytvoření souboru And Easy Obnovit
Pro vaše pohodlí a pojištění pro maximální ochranu, Registry Purify automaticky vytvoří soubor vrátit zpět všechny opravy provedeny tak, že můžete snadno obnovit veškeré změny, bude-li zapotřebí.
• Zabudované-in Microsoft Editor registru Podpora
Dvojklikem všechny položky nalezené v kanceláři seznamu Purify, bude společnost Microsoft Regedit spusťte se zaměřením na vstupu jste právě klikli. Je pro vás zkoumat každou položku detailedly a pak vaše rozhodnutí.
• Microsoft Regedit kompatibilní Zpět souboru
Očistěte registru registru vrátit soubor je kompatibilní s Microsoft Windows Registry Editor Version 5.00. Soubor registru je plně otevřen pro koncové uživatele, což znamená, že můžete upravovat přímo, nebo jen importovat ručně dvojitě klikněte na ni.
• User Interface Friendly GUI
Registry Očistěte je mocný a jednoduše se používá. Jeho rozhraní má všechny potřebné funkce a výkon v dnešních výpočetních prostředích.
• Jednoduchý, ale výkonný a bezpečné
Registry Očistěte bezpečně prohledá uvnitř vašeho registru systému Windows pro chyby, pomocí robustní analýzy algoritmu a opravy nimi jen pár kliknutí myší.
• Kompaktní registru Chcete-li získat čtení / zápis Účinnost
Když vyčistit mnoho neplatných položek registru, kompaktní registru je nutné registr. Registry Očistěte přestaví registru odstraní prázdná místa v blogu na kompaktní registru.
• Spolehlivé registru Zálohování
Registry Očistěte podporuje zálohy registru z různých časových a vytvoření libovolný počet zálohy v závislosti na volného místa na pevném disku. Pro vaše pohodlí zálohu registru název souboru má formát "Rok / měsíc / den / hodina: minuta: sekunda".
• Efektivní Obnovení registru
V jedné jednoduché dialogové rozhraní, zálohování a obnovení registru vymazání lze absolvovat snadno a explicitně. Ačkoli počet? zálohování není omezena, bude kanceláři Purify vám připomenout některá odstranit zálohu, pokud počet zálohy registru, je vyšší než 3, pro záložní soubory mohou být velké.
Zatímco analýza položek registru, registru Purify kroky ve dvou aspektů: jeden je registru-založené metody analýzy, další je soubor-založené metody analýzy. Pomocí dvou-aspekt analyzovat, bude systém Windows registru analyzovat důkladně vyzkoušet více neplatných položek, než kdy jindy.
:ahoj:
 Predmet príspevku: Re: Registry Purify 4.58
PoslaťNapísal: Str 30. Sep 2009 14:21:28
To poznam programy tomuto podobne dokazu rozdrbat OStak ze uz ho das nanormal len zo zalohy. :)
