Aktuálny čas je Ned 25. Okt 2026 5:50:20
 TinyPicUploaderv202-Ulahčite si posielanie fotiek
 Predmet príspevku: TinyPicUploaderv202-Ulahčite si posielanie fotiek
PoslaťNapísal: Štv 30. Júl 2009 13:26:37
With this little tool you can very easily upload pictures to www.tinypic.com, www.imageshack.us and www.messyshare.com without having to go through their website. You can enable shell link integration and simply Right-click the file and select “Send to TinyPic/Imageshack/MessyShare“ or drag the file to the app. window and it will automatically start uploading.
* Send multiple files in a queue
* Crop an area of the screen
* Send existing files via context-menu (32-bit only), selecting them from a dialog, or dragging them to the application window
* Capture the active window when you press F11
* Select a window from currently running applications via Aero live thumbs (Vista and W7 only)
* Send your clipboard contents (image)
* Send to either Tinypic, Imageshack or Messyshare, and get the direct link copied to your clipboard automatically
* Auto-resize pictures and/or lower quality automatically if file exceeds a given size, to speed-up uploads on slow connections (like non-Japanese)
* Store captures from cropping or paste etc
* Supports multiple monitors in any configurations (spanned horz/vertically etc)
* Works in Linux via wine libraries
* .net framework is NOT required
* Supports specific Windows 7 features (taskbar progress)
* Store a log with comments and its link about every upload
Czech..........!!!
S tímto nástrojem můžete Něco velmi snadno nahrát fotky do www.tinypic.com, www.imageshack.us a www.messyshare.com aniž by museli jít přes jejich webové stránky. Můžete povolit shell odkaz integrace a jednoduše pravým-klikněte na obrázek a zvolte "Odeslat k TinyPic / Imageshack / MessyShare" nebo přetažením souboru do app. okna a začne automaticky nahrávat.
Vlastnosti:
* Poslat několik souborů do fronty
* Crop prostoru na obrazovce
* Poslat stávajících souborů přes kontext-menu (32-bit pouze), výběrem z dialogu, nebo přetažením do okna aplikace
* Zachytávání aktivního okna, když stisknete F11
* Vyberte z okna právě běží aplikace přes Aero žít palce (Vista a W7 pouze)
* Odešlete obsah schránky (obrázek)
* Poslat na obou Tinypic, Imageshack nebo Messyshare a získat přímý odkaz zkopíruje do vaší schránky automaticky
* Auto-velikost obrázků a / nebo nižší kvality automaticky, pokud soubor přesáhne určitou velikost, aby rychlost-nahoru obrázky pro pomalé připojení (jako non-japonský)
* Skladujte zachytí z ořezu nebo vložte etc
* Podpora více monitorů v každém konfigurace (kalibrují horz / vertikálně atd.)
* Funguje v Linuxu přes víno knihovny
*. NET Framework není vyžadováno
* Podporuje Windows 7 specifické rysy (panelu pokrok)
* Skladujte záznam s připomínkami a jeho souvislost asi každý upload
HAPPYCOOL TOTO SI URČITE STIAHNI ............... !!!
