Aktuálny čas je Str 28. Okt 2026 15:37:12
 NeoTrace v3.25 Professional Edition
 Predmet príspevku: NeoTrace v3.25 Professional Edition
PoslaťNapísal: Štv 11. Jún 2009 17:24:40
V prípade ak by Vás niekto napadol s týmto nástrojom ho dokážete detaljne identifikovat.....
NeoTrace is a diagnostic and investigative tool. It traces the network path across the Internet from the host system to a target system anywhere on the Internet. Automatic retrieval of data includes registration details for the owner of each computer on the route (address, phone, email address) and the network each node IP is registered to. Easy to read views of the data include a world map showing the locations of nodes along the route, a graph showing the relative response time of each node along the path, and a configurable list of node data.
NeoTrace is popular with home enthusiasts for diagnosing connection problems. Many Internet Service Providers recommend NeoTrace to their customers and also use it themselves. By providing their users with NeoTrace many organizations have found they are able to decrease the number of help desk calls they handle related to connection problems. It is also used by law enforcement professionals worldwide, including US Customs and NATO, and is taught in courses at the FBI Academy and in Internet Investigator training for officers in the state of California. It has been shown on national TV in conjunction with stories on law enforcement efforts to track down pedophiles and other criminals.
NeoTrace is the quickest way to get an overview of a connection and through its combination of ease of use and powerful and automatic data retrieval it is a favored tool of both novices and seasoned professionals.
REQUIREMENTS
Your computer must meet all of the following requirements in order for you to be able to install and use NeoTrace:
* A computer running a 32-bit version of Windows. This includes all versions of Windows 95, 98, 98SE, NT4, 2000, ME and XP. Windows 3.11 with Win32s cannot support NeoTrace. Windows 95 users need to have installed the Winsock 2 update. If you receive an error message when trying to run NeoTrace please search our online FAQ system for 'winsock 2'. In general we recommend that you have the latest updates and patches installed for whatever version of Windows you are using.
* A non-proxy connection to the Internet. This can be through a dial-up connection, cable or DSL connection or an office LAN. If your connection to the Internet is only through a proxy server you will not be able to use NeoTrace. If you are behind a firewall and it is not configured to allow traceroute and ping you will not be able to use NeoTrace. Firewalls can be reconfigured to allow NeoTrace to operate. Proxies can be replaced by or supplemented by a true NAT (network address translator). Talk to your network administrator for more information, direct them to this document and our online FAQ system.
* Internet Explorer 4.01 or greater. NeoTrace makes use of several updates to the Windows operating system. Some of these updates are available separately but the simplest way to ensure you have all the updates is to install IE 4.01 or greater. IE does not need to be your default or main browser, it simply needs to be installed.
* NeoTrace performs a great deal of data correlation in order to create the trace map as accurately as possible, in order to do this it must communicate with special application servers at NeoWorx headquarters. Any circumstance on your computer or local network, such as a firewall with too restrictive a configuration, may limit the ability of NeoTrace to perform all functions.
Note: If your only connection to the Internet is through a proxy server you will not be able to use NeoTrace.
NeoTrace je diagnostické a vyšetřovací nástroj. Je stopy síťovou cestu přes Internet z hostitelského systému do cílového systému kdekoli na Internetu. Automatické načítání dat zahrnuje registrační údaje pro majitele každý počítač na trase (adresa, telefon, e-mailovou adresu) a každý uzel sítě IP je registrovaná na. Snadno čitelné zobrazení údajů patří svět, mapa zobrazující umístění uzlin podél trati, graf ukazující relativní doba odezvy každého uzlu podél cesty, a konfigurovatelný seznam uzlu údajů.
NeoTrace je populární s domácí nadšence pro diagnostiku problémů připojení. Mnoho Internet Service Providers NeoTrace doporučit svým zákazníkům a také používat sami. Poskytnutím svých uživatelů s mnoha organizacemi NeoTrace zjistili, že jsou schopny snížit počet help desk hovorů zpracovávají v souvislosti s problémy s připojením. Používá se také v trestním řízení profesionály na celém světě, včetně USA pro cla a NATO, a vyučuje v kurzech v FBI akademii a Internet Řešitel školení pro úředníky ve státě Kalifornie. Bylo prokázáno, o státní televizi v souvislosti s příběhy o donucovací úsilí sledovat pedophiles a dalších zločinců.
NeoTrace je nejrychlejší způsob, jak získat přehled o spojení, a díky své kombinaci snadnost použití a silný a automatické načítání dat je upřednostňována nástroje jak nováčci a ostřílených profesionálů.
POŽADAVKY
Počítač musí splňovat všechny tyto požadavky, aby vám mohli nainstalovat a používat NeoTrace:
* A počítač běží 32-bitové verze Windows. To zahrnuje všechny verze Windows 95, 98, 98SE, NT4, 2000, ME a XP. Windows 3.11 s Win32s nemůže podpořit NeoTrace. Uživatelé Windows 95, musíte mít nainstalovaný Winsock 2 update. Pokud se zobrazí chybová zpráva při pokusu o spuštění NeoTrace naleznete v našem on-line FAQ systému 'winsock 2'. Obecně doporučujeme, že máte nejnovější aktualizace a opravy instalována bez ohledu na verzi systému Windows, který používáte.
* A non-proxy připojení k internetu. To je možné prostřednictvím dial-up připojení, DSL nebo kabelové připojení nebo kancelářské sítě. Pokud vaše připojení k internetu pouze přes proxy server, nebudete moci používat NeoTrace. Pokud jste za firewallem a není nakonfigurováno, aby naši klienti a ping nebudete moci používat NeoTrace. Firewally mohou být přebudována, aby NeoTrace pracovat. Proxy může být nahrazeny nebo doplněny skutečnou NAT (Network Address překladatele). Promluvte si se svým správcem sítě pro bližší informace, přímé jim k tomuto dokumentu a našeho on-line FAQ systému.
* Internet Explorer 4.01 nebo vyšší. NeoTrace využívá několik aktualizací pro operační systém Windows. Některé z těchto změnách jsou k dispozici samostatně, ale nejjednodušší způsob, jak zajistit, máte všechny aktualizace je instalace IE 4.01 nebo vyšší. IE nemusí být nastaven jako výchozí, nebo hlavní prohlížeč, to prostě musí být nainstalován.
* NeoTrace vykonává velkou srovnávací údaje s cílem vytvořit mapu dohledat co nejpřesněji, aby se jim to podařilo, musí komunikovat s speciální aplikační servery na NeoWorx velitelství. Žádných okolností na vašem počítači nebo v lokální síti, jako je například firewall s příliš restriktivní konfiguraci, mohou omezit schopnost NeoTrace plnit všechny funkce.
Poznámka: Pokud váš pouze připojení k internetu přes proxy server, nebudete moci používat NeoTrace.
