Aktuálny čas je Ned 29. Nov 2026 12:13:38
 Essential NetTools 4.1
 Predmet príspevku: Essential NetTools 4.1
PoslaťNapísal: Štv 30. Apr 2009 18:30:06
Essential NetTools - a set of network tools for diagnosing networks and monitoring network connections on your computer. This is an indispensable tool for everyone who needs a set of powerful network tools for everyday use.
It includes:
* NetStat: displays the list of incoming and outgoing connections on your computer, including information on open TCP-and UDP-ports, IP-addresses and state of connections. From other NetStat utilities is able to bind applications to open ports to owning them. You can setup a system of warnings for incoming and outgoing connections.
* NBScan: Scanner NetBIOS, a powerful and rapid tool for the study of networks. NBScan can scan the network for a range of IP-addresses and a list of computers that have Service NetBIOS shared resources and a table of their names. Unlike a standard tool that ships with Windows, NBScan provides user-friendly graphical interface and easy management of files, lmhosts, and a parallel scanning, which allows the network to check the P less than one minute. NBScan can facilitate the daily tasks of system integrators, administrators and analysts.
* PortScan: TCP-port scanner with advanced capabilities to scan the network for active ports. This tool scans both in normal (polnosvyaznom) and hidden (half-open) modes.
* HostAlive: a module for monitoring network, periodically checking whether the host is active and whether its network services, such as HTTP-and FTP-server.
* EmailVerify: checks whether there is an e-mail address for contacting with soovetstvuyuschim SMTP mail server.
* Shares: monitors and maintains record of external connections to shared resources on your computer, and provides a quick and easy way to connect to remote resources.
* SysFiles: a convenient editor for the five important system files: services, protocol, networks, hosts, and lmhosts.
* NetAudit (NetBIOS Auditing Tool): allows you to carry out various security checks and / or individual computers that run service access to shared resources on the NetBIOS. This tool will help you identify potential gaps in security.
* RawSocket: gives you the possibility to establish low-level TCP connection to identify problems with the various network services. Presentation of data in different colors, as well as user-friendly interface makes it an excellent tool for daily work and the administrator, and programmer.
* TraceRoute and Ping: all the familiar tools that are equipped with multiple functions and a clear presentation of the results will enable you to explore the Internet and identify the problem compounds.
* NSLookup: allows you to convert IP addresses to host names and vice versa, obtain aliases, and perform advanced DNS-queries, such as MX or CNAME.
* IPBlackList: checks whether IP-address to the various black lists of IP-addresses: Base addresses of spammers, open proxies and rilei e-mail. This tool will give you the answer to the question why verifiable IP-address is rejected by some network resources, such as mail servers.
* ProcMon: Displays a list of active processes with full information about the location of the program, manufacturer, process ID, loaded modules. With this tool you can view statistics for the consumption of CPU time to recognize the hidden application, stop the current processes and efficiently manage the use of computer resources.
* SNMPAudit: Advanced SNMP-scanner devices. Allows you to quickly locate the SNMP-networked devices in the selected range and get a customized selection of data from each of them. For a more detailed study of the device user can use the SNMP-browser.
Other possibilities: creating a report in HTML, text and CSV-format, fast exchange of IP-addresses of different instruments, IP-geolocation data adresoov, detailed information about the system, a customizable interface, and much more.
Základní NetTools - sada síťových nástrojů pro diagnostická sítě a monitorovací síťová spojení na vašem počítači. Toto je nezbytný nástroj pro každý, kdo potřebuje sadu silných síťových nástrojů pro každodenní používání.
To zahrnuje:
* NetStat: zobrazuje seznam přicházejících a odcházejících spojení na vašem počítači, včetně informací o otevřených TCP-AND UDP-přístavech, IP-ADDRESSES a stavu spojení. Z jiných NetStat utilit může svázat aplikace k tomu, aby otevřely přístavy vlastnění je. Vy můžete nastavit systém varování pro přicházející a odcházející spojení.
* NBSCAN: Snímací zařízení NetBIOS, silný a rychlý nástroj pro studium sítí. NBSCAN může skenovat síť pro řadu IP-ADDRESSES a seznamu počítačů které měly Service NetBIOS společně používanou prostředky a tabulku jejich jmen. Na rozdíl od běžného nástroje který dodá - Windows, NBSCAN poskytuje uživatelsky přívětivý grafický rozhraní a snadný management souborů, lmhosts, a paralely skenování, které dovoluje síť kontrolovat P méně než jedna minutu. NBSCAN může usnadnit denní úkoly systémových integračních obvodů, administrátorů a analytiků.
* PortScan: TCP- snímací zařízení přístavu s pokročilými schopnostmi k tomu, aby skenovaly síť pro aktivní zóny. Tento nástroj skenuje v normální (polnosvyaznom) a skryté (poloviční-otevřené) režimy.
* HostAlive: jednotka pro monitorovací síť, pravidelně kontrolování zda hostitel je aktivní a zda jeho síťové služby, jako HTTP-AND FTP-server.
* EmailVerify: šeky zda tam je e-mailové adresa pro kontaktování se soovetstvuyuschim SMTP poštovním serverem.
* sdílí: monitoruje a udržuje záznam externích spojení se společně používanými prostředky na vašem počítači, a poskytuje rychlou a snadnou cestu do připojit k vzdáleným zdrojům.
* SysFiles: vhodný editor pro pět důležitých systémových souborů: služby, protokol, sítě, hostitelé, a lmhosts.
* NetAudit (NetBIOS Auditing nástroj): dovoluje vám provést různé bezpečnostní kontroly a / či individuální počítače které běžet přístup k službě společně používaným prostředkům na NetBIOS. Tento nástroj pomůže vám identifikovat potenciální propasti v bezpečnosti.
* RawSocket: dává vám možnost ustanovit nízkoúrovňové TCP spojení s identifikovat problémy s různými síťovými službami. Prezentace z dat v jiných barvách, stejně jako uživatelsky přívětivé rozhraní udělá to vynikající nástroj pro denního práci a administrátora, a programátora.
* TraceRoute a zazvonění: celé důvěrně známé nástroje které jsou vybavené vícenásobnou funkcemi a jasnou prezentací výsledků umožní vám prozkoumat Internet a identifikovat nejasné sloučeniny.
* NSLOOKUP: dovoluje vám přeměnit IP adresy jménům hostitele a naopak, získat druhá jména, a vykonávat pokročilé DNS-dotazy, jako MX či CNAME.
* IPBLACKLIST: šeky zda IP-ADDRESS do různých černých seznamů IP-adres: Základní adresy ze zasílatelů nevyžádaných e-mailů, otevřená zastupování a rilei mailují. Tento nástroj dá vám odpověď na otázku proč ověřitelný IP-ADDRESS je odmítnutý nějakými síťovými zdroji, jako poštovní servery.
* ProcMon: Zobrazuje seznam aktivních procesů s plnou informací o umístění programu, výrobce, procesového ID, zaveditelných modulů. S tímto nástrojem vy se můžete dívat na statistiky pro spotřebu CPU času na to poznat skrytou aplikaci, zastavte aktuální procesy a efektivně řídit použití počítačových zdrojů.
* SNMPAUDIT: Pokročilá SNMP-SCANNER zařízení. Dovoluje vám rychle lokalizovat SNMP-NETWORKED zařízení v zvoleném druhu jízdách a dostat zákaznicky přizpůsobený výběr dat z každé/ho z nich. Pro podrobnější studium přístrojového uživatele může užívat SNMP-prohlížeč.
Jiné možnosti: vytvoření zprávy v HTML, textu a CSV-formátu, rychlá výměna IP-ADDRESSES jiných nástrojů, IP-GEOLOCATION datový adresoov, detailní informace o systému, přizpůsobitelné rozhraní, a mnohem víc.
 Predmet príspevku: Re: Essential NetTools 4.1
PoslaťNapísal: Pon 11. Máj 2009 16:31:50
Password:
FCBGabo
