Aktuálny čas je Štv 26. Nov 2026 8:25:28
 Cakewalk Rapture v1.2
 Predmet príspevku: Cakewalk Rapture v1.2
PoslaťNapísal: Ned 10. Máj 2009 8:46:23
Combining power, elegance, control, and unbeatable sounds, Rapture is one of the most exciting synthesizers to hit the market in years. Capable of producing rich, hypnotic, and rhythmic basses, leads, and pads, Rapture is perfect for performing and designing the modern synthesized sounds igniting today’s pop, dance, and electronic music.
Rapture's non-aliasing resampling engine technology sets a new standard for sound quality, and produces pristine, high-resolution rendering and playback. Its advanced modulation capabilities include over 40 Step Generators per patch, providing an intuitive interface for generating rhythmic sequences.
With its beautifully designed interface and extensive sound manipulation capabilities, Rapture is capable of producing the rich, hypnotic, and rhythmic basses, leads, and pads destined to put the spirit back into your music.
* Wavetable synthesizer with advanced sound manipulation capabilities, well suited for electronica-related music styles
* Non-aliasing resampling engine technology for pristine sound quality
* Over 500 professionally crafted sound programs
* Six fully-programmable stereo sound-generating Elements
* Oscillators with multi-waveform and ring modulation functions
* DSP stage of two 16-mode filters per oscillator with LoFi and Drive section
* Up to 42 EGs, LFOs & Step Generators for advanced parameter modulation
* Advanced MIDI Modulation Matrix
* Mix and modulate all Elements through global FX and dynamic Step Generator
* Ultimate sound expandability with native support for the SFZ family of sample formats
* Mac formats: AU, RTAS support for Pro Tools 7.x+, VSTi; Windows formats: DXi, DXi x64, RTAS support for Pro Tools 6.x+, VSTi
Slučovací síla, elegance, kontrola, a nepřekonatelné zvuky, vytržení je jedním z nejvzrušujících syntetizátorů k tomu, aby udeřily do trhu v letech. Schopný produkovat bohaté, hypnotické, a rytmické jezevčíky, vede, a vycpávky, vytržení dokonalý pro vykonává a projektování moderní syntetizované zvuky podněcování dnešní třesknutí, tanec, a elektrofonická hudba.
Vytržení- ovo ne-schodovitost převzorkove motorovou technologii nastavuje nový standard pro zvukovou kvalitu, a produkuje původní, s vysokou rozlišovací schopností překlad a playbacku. Jeho pokročilé schopnosti modulace obsahují přes 40 přírůstkové generátory za záplatu, poskytující intuitivní rozhraní pro tvořící rytmické sekvence.
S jeho skvěle navrženou rozhraním a rozsáhlou zvukovou manipulací schopnosti, vytržení je schopné produkuje bohaté, hypnotické, a rytmické jezevčíky, vedení, a vycpávky nasměrovaly dát ducha zpět do vaší hudby.
Rysy:
* Wavetable syntetizátor s pokročilou zvukovou manipulací schopnostmi, vhodný pro elektronické-související hudební styly
* Non - aliasing převzorkovat motorovou technologii pro původní zvukovou kvalitu
* přes 500 profesionálně zvukové programy řemesla
* šest plně-programovatelného stereo zní-vytváření Elements
* oscilátory s multi --křivkami a ringovou modulací funguje
* DSP stupeň z dvou 16-módů filtruje za oscilátor s LoFi a Drive částí
* až do 42 EGs, LFOs & přírůstkových generátorů pro pokročilou modulaci parametru
* Pokročilá MIDI matice modulace
* směs a přizpůsobí všechno Elements skrz globální FX a dynamický Step Generator
* konečná zvuková rozšiřitelnost s přirozenou podporou pro SFZ rodinu vzorových formátů
* Mac formát: AU, RTAS podpora pro Pro Tools 7.x+, VSTi; Windows formát: DXI, DXi x64, RTAS podpora pro Pro Tools 6.x+, VSTi
 Predmet príspevku: Re: Cakewalk Rapture v1.2
PoslaťNapísal: Pon 11. Máj 2009 16:41:09
Password:
FCBGabo
