Aktuálny čas je Štv 10. Sep 2026 9:23:32
 Everest Ultimate Edition 5.01 Build 1700 - Multilanguage
 Predmet príspevku: Everest Ultimate Edition 5.01 Build 1700 - Multilanguage
PoslaťNapísal: Uto 31. Mar 2009 13:50:50
EVEREST Ultimate Edition is a hardware diagnostics and memory benchmarking solution for home PC users, based on the award-winning EVEREST Technology. It offers the world's most accurate hardware information and diagnostics capabilities, including online features, memory benchmarks, hardware monitoring, and low-level hardware information.
Key features
Generic features:
· Low-level hardware information: 44 pages
· Software and operating system information: 44 pages
· Security related information: 6 pages
· DirectX information including Direct3D acceleration features
· Diagnostics module that simplifies troubleshooting
· Tweaking features
Benchmarking features:
· 10 benchmark modules to measure CPU, FPU and memory performance
· Benchmark reference results to compare measured performance to other systems
· Cache & Memory Benchmark Suite
· Hard disk, optical drive and flash drive benchmarking with RAID array support
Unique features:
· UpTime and DownTime statistics with critical errors counter
· Monitor Diagnostics to check the capabilities of CRT and LCD displays
· System Stability Test with thermal monitoring to stress CPU, FPU, memory and disks
· Hardware Monitoring to monitor system temperatures and voltages on the System Tray, OSD, Vista Sidebar or Logitech keyboard LCD
· Temperature, voltage and fan RPM data logging to HTML and CSV log files
· Smart Battery information
· Web links: IT portals, software and driver download
· Manufacturer links: product information, driver and BIOS download
· Hardware information database for over 52000 devices
· Overclock information
· Fully localized user interface: 35 languages
· No installation or setup procedure required
EVEREST Ultimate Edition je hardware diagnostika a paměť porovnání výkonnosti řešení pro domů PC uživatele, založený na oceněný EVEREST Technology. To nabízí světové nejpřesnější hardware informaci a diagnostiky schopnosti, včetně online rysů, paměť srovnávací test, hardwaru monitorování, a nízkoúrovňové hardwaru informace.
Klíčové rysy
Generické uvádí:
· nízkoúrovňová hardware informace: 44 stránky
· software a operační informační systém: 44 stránky
· bezpečnost spojovala informaci: 6 stránky
· DirectX informace včetně Direct3D zrychlení uvádí
· diagnostické moduly které zjednodušuje řešení problémů
· štípání uvádí
Porovnání výkonnosti uvádí:
· 10 testovací jednotky k tomu, aby měřily CPU, FPU a paměťový výkon
· testovací odkaz vyplývá srovnávat měřený výkon dalším systémům
· cache & paměťová testovací souprava
· harddisk, optický pohon a blesk pohon porovnání výkonnosti s RAID polem podporuje
Jedinečné rysy:
· doba pohotovosti provozuschopnosti a DownTime statistiky s kritickými chybami odporují
· monitorové diagnostiky k tomu, aby kontrolovaly schopnosti CRT a LCD zobrazují
· systémová zkouška stálosti s tepelným monitorováním k tomu, aby zdůraznilo CPU, FPU, paměť a disky
· hardware monitorování ke kontrolním zařízení teplotám a voltážím na System Tray, OSD, Vista Sidebar či Logitech klávesový LCD
· teplota, voltáž a fanoušek RPM záznam dat k HTML a CSV zapíše soubory
· chytrá informace baterie
· Web spojuje: IT portály, software a stahování ovladačů
· výrobce spojuje: informace o produktu, ovladač a BIOS stáhne
· hardware informační databáze víc než 52000 zařízení
· Overclock informace
· plně lokalizované uživatelské rozhraní: 35 jazyky
· žádná instalace či příprava řešení požadované
