Aktuálny čas je Pon 02. Nov 2026 21:56:17
 Najnovšia verzia - Folder Lock 6.1.6
 Predmet príspevku: Najnovšia verzia - Folder Lock 6.1.6
PoslaťNapísal: Str 25. Feb 2009 7:57:20
Folder Lock is a fast file-security program that can password-protect,lock, hide and encrypt any number of files, folders, drives, picturesand documents in seconds. Protected files are hidden, undeletable,inaccessible and highly secure. It hides files from kids, friends and co-workers, safeguards them from viruses, trojans, worms and spyware, and even protects them from networked PCs, cable users and hackers. Files can also be protected on USB Flash Drives, Memory Sticks, CD-RW, floppies and notebooks. Protection works even if files are taken from one PC to another on a removable disk, without the need to install any software. It locks files in Windows, DOS and even Safe Modes. Additional Options include Stealth Mode, Hacker Attempt Monitoring, Shred files, AutoLock, Auto Shutdown PC, Lock your PC, Erase PC tracks, 256-bit Blowfish Encryption and Context Menu in Explorer. It is Windows Vista/2003/XP/2000/NT/Me/98/98S compatible and works on all kinds of disk types like FAT16, FAT32, NTFS. Folder Lock is the most downloaded file-security program in the market today.
FEATURES:
Encrypt files and folders.
Lock files, folders and drives.
Password-protect USB drive.
Secure your data in CD/DVD.
Run program in Stealth Mode.
Remove Windows History.
Shred (secure delete) files.
Auto Lock when you're away.
Hack Attempt Monitoring.
Windows Vista/XP/2000.
Changes in Version 6.1.6 (February 21, 2009):
- Folder Lock is now 64-bit Windows compatible on all flavors i.e. Windows Vista 64-bit, Windows XP 64-bit, Windows Server 2008 and also Windows 7.0.
- A new Portability feature is also added in this version, allowing you to protect data on USB drives and External drives without any hassle and without the need to install Folder Lock on the other end.
Složka Lock je rychlý souborový-bezpečnostní program který může krycí heslo-ochrana,zámek, skrýt a zakódovat nějaké /každé /žádné množství souborů, složek, pohonů, picturesand dokumentů v sekundách. Chráněné soubory jsou skryté, obnoví,nepřístupný a vysoce bezpečný. To skrývá soubory z dětí, přátel a spolu --pracovníků, zabezpečuje je z virů, trojských koní, červů a spyware, a dokonce chrání je před propojeným sítím PCS, kabeloví uživatelé a hakeři. Soubory mohou také byly chráněný na USB Flash Drives, paměťových tyčích, CD-RW, pružné discích a zápisníky. Ochrana pracuje dokonce když soubory jsou vzatí z jednoho PC další na výměnném disku, bez potřeby instalovat nějaký /každý /žádný software. To uzamyká soubory ve Windows, DOS a dokonce Safe Modes. Další volby zahrnují Stealth Mode, pokus hakera monitorování, roztrhaných souborů, AutoLock, auto přerušení práce PC, uzamkněte váš PC, vymažte PLOŠNÉ VODIČE, 256 - bitové čtverzubec šifrování a Context Mena v Explorer. To je Windows Visty/2003/XP/2000/NT/mě/98/98S kompatibilní a pracuje na všechny druzích  disku druhů jako FAT16, FAT32, NTFS. Složka Lock je nejvíce stáhnutý souborový-bezpečnostní program na trhu dnes.
RYSY:
Zakódujte soubory a složky.
Uzamkněte soubory, složky a pohony.
Heslový-chráněný USB pohon.
Zabezpečte vaše data v CD/DVD.
Spusťte program v módu tajnosti.
Odstraňte windowsovskou historii.
Kus (zabezpečí vymaže) soubory.
Automobil uzamkne kdy vy jste pryč.
Zasekněte pokus monitorování.
Windows Visty/XP/2000.
Změny ve verzi 6.1.6 (únor 21, 2009):
- zámek složky je nyní 64 - bitových windowsovský kompatibilních na všech vůních i.e. Windows Visty 64 - bitový, Windows XP 64 - bitový, windowsovský server 2008 a také Windows 7.0.
- nový Portability rys je také přidaný v této verzi, dovolující vás chránit data na USB pohonech a External pohonech bez jakéhokoliv hádky a bez potřeby instalovat Folder Locka na druhém konci.
Stručný návod ako správne aktivovat najnovšiu verziu 6.1.6
Najsamprv nainštalujeme 6.1.3 potom otvorime program a klikneme na register a do registra skopírujem a následne prilepíme požadované údaje a potvrdíme a až potom už iba stačí nainštalovať najnovšiu verziu 6.1.6 a tým pádom sa aktivuje už s rozpoznaním kodu s predošlej verzie - táto možnosť s kvalitnými prihlasovacími údajme je najoptimálnejšie nakolko vylučuje aké kolvek nežiadúce škodlivé účinky v podobo najrozličnejších crackov - užite si to naplno - !!!
 Predmet príspevku: Re: Najnovšia verzia - Folder Lock 6.1.6
PoslaťNapísal: Uto 27. Okt 2009 20:20:09
