Aktuálny čas je Str 22. Apr 2026 14:08:56
 Namo Webeditor 8.0.0.40
 Predmet príspevku: Namo Webeditor 8.0.0.40
PoslaťNapísal: Uto 24. Feb 2009 14:10:32
Namo WebEditor 8 is one of the most complete Web authoring applications ever created and quite possibly the only software you will need to create, edit, publish and manage your websites. An integrated development environment empowers Web professionals to create cutting-edge sites. Easy-to-use functions enable beginners to grow into highly-skilled Web designers.
Namo WebEditor 8 is an HTML-based WYSIWYG (What You See Is What You Get) multimedia web authoring tool. It maximizes user convenience with a ?®ribbon?? menu user interface, provides ICT tools for online learning and has standard web features for creating content quickly and easily.
New User Interface
Namo WebEditor 8 provides a ribbon menu so that often-used commands can be accessed easily. On the ribbon menu, commands are grouped according to task so that needed commands can be found quickly, reducing the time it takes to complete tasks.
Effective Presentation Features
Presentations can be made into HTML documents and displayed using your web browser??s full screen feature. Existing presentation files (*.ppt) can be converted into HTML form or image form. In presentation mode, you can use a remote control or the automatic slide show feature to easily move from one slide to another.
Teaching Plan Wizard Feature
A wizard feature is provided for making basic teaching plans easily. Users with a knowledge of XML can use WebEditor??s XML editing features to create their own lesson plan forms.
A Variety of Quiz Features
Namo WebEditor 8 uses JavaScript to create simple quizzes. A variety of different questions can be added to the quizzes including multiple choice, true/false, short answer and essay questions. If a quiz is published on a web site, students can take it and teachers can check the results from anywhere that has an internet connection. The results can also be sent to a specified email address.
Easy Statistics Learning Features
Even without using Excel, you can use WebEditor??s statistics functions to easily calculate sums, averages, etc. from data that has been inserted into a table. Also, you can use the chart features to easily create graphs from which you can see trends and patterns in the data at a glance.
DIV Tag Features
Areas in a web page can be selected and grouped with DIV tags. Before, DIV tags could be inserted in the HTML source editing window, but now they can be inserted directly from the visual editing window.
Rich Design Resources
Namo WebEditor 8 provides variety of new clip art and themes designed by professional designers. Using the design resources provided by WebEditor, you can create a professional-looking site with just a few clicks or update the look of an existing site.
Connect to a blog
Documents edited in Namo WebEditor 8 can be posted directly onto a blog. In addition, existing blog posts can be imported into WebEditor, edited as needed and then posted back on the blog again
Namo WebEditor 8 je jedním z nejvíce kompletních Webu vývojových aplikací vůbec kdy vytvořený a docela možná jediný software, který vy budete potřebovat vytvořit, editovat, uveřejnit a řídit vaše websajty. Integrované vývojové prostředí zplnomocní webové profesionály k tomu, aby vytvořili ostrá místa. Snadno použitelné funkce umožní začátečníky vyrůst ve vysoce-zkušených webových návrhářích.
Namo WebEditor 8 je HTML-BASED WYSIWYG (co vidí, dostaneš) multimediální pavučinu autorský nástroj. To maximalizuje uživatelskou výhodu s ?®ribbon?? nabídkové uživatelské rozhraní, poskytuje ICT nástroje pro online učení a má standardní pavučinu rysy pro vytvoření obsahu rychle a snadno.
Nové uživatelské rozhraní
Namo WebEditor 8 poskytuje páskové menu tak, že časté-užívané příkazy mohou být zpřístupněný snadno. Na páskovém menu, příkazy jsou seskupené podle úkolu tak, že potřebných příkazů mohou být nalezený rychle, redukující čas to bere dokončit úkoly.
Efektivní prezentace uvádí
Prezentace mohou být udělaný do HTML dokumentů a zobrazeného používání vašeho internetového prohlížeče??s plný obrazovkový rys. Existující prezentační soubory (*.ppt) může být převedený do HTML formy či obrazové formy. V prezentačním módu, vy můžete použít dálkovou ovládání či automatickou prezentaci s diapozitivy rys k snadno pohybovat z jednoho poklesu dalšího.
Vyučující kouzelného rysu plánu
Kouzelný rys je poskytnutý pro dělání základních vyučujících plánů snadno. Uživatelé se znalostí XML může užívat WebEditor??s XML editující rysů k tomu, aby vytvořily jejich vlastní plán lekce forem.
Různorodost kvizových rysů
Namo WebEditor 8 použití JavaScript vytvořit jednoduché kvízy. Různorodost jiných otázek může být přidaný ke kvízy včetně vícenásobné volby, pravdy/nepravdy, krátké odpověď a esej otázky. Jestli kvíz je zveřejněný na webové stránce, studenti mohou vzít to a učitele mohou kontrolovat výsledky odkudkoli to má internetové spojení. Výsledky mohou také byly poslaný k specifikované emailové adrese.
Snadné statistiky učení uvádí
Dokonce bez použití Excel, vy můžete použít WebEditor??se statistiky funguje snadno vypočítá částky, průměry, a tak dále z dat která byla vložená do st olu. Také, vy můžete použít graf rysy k snadno vytvořit grafy z které vy můžete vidět trendy a vzory v datech na první pohled.
DIV přívěsek uvádí
Oblasti ve webové stránce mohou být vybraný a seskupený s DIV přívěsky. Předtím, DIV přívěsky by mohl být vložený v HTML zdroji editačním okně, ale nyní mohou být vložený přímo z vizuálního editačního okna.
Bohaté zdroje designu
Namo WebEditor 8 poskytuje různorodost nových klipu umění a témat navržených povoláním návrhářů. Používání zdrojů designu poskytnutého od WebEditor, vy můžete vytvořit profesionální-dívající se místo - jen několik kliknutí či aktualizovat vzhled existujícího místa.
Připojte k bloku
Dokumenty editovaný v Namo WebEditor 8 může být poslaný přímo na blok. Navíc, existující sloupy bloku mohou být importovaný do WebEditor, editovaný jak potřebný a potom poslaná zpět na bloku znovu
