Aktuálny čas je Str 30. Sep 2026 14:49:37
 Wireshark 1.1.2
 Predmet príspevku: Wireshark 1.1.2
PoslaťNapísal: Sob 21. Feb 2009 14:17:00
Wireshark is the world's foremost network protocol analyzer, and is the de facto (and often de jure) standard across many industries and educational institutions.
Wireshark development thrives thanks to the contributions of networking experts across the globe. It is the continuation of a project that started in 1998.
Wireshark has a rich feature set which includes the following:
• Deep inspection of hundreds of protocols, with more being added all the time
• Live capture and offline analysis
• Standard three-pane packet browser
• Multi-platform: Runs on Windows, Linux, OS X, Solaris, FreeBSD, NetBSD, and many others
• Captured network data can be browsed via a GUI, or via the TTY-mode TShark utility
• The most powerful display filters in the industry
• Rich VoIP analysis
• Read/write many different capture file formats: tcpdump (libpcap), Catapult DCT2000, Cisco Secure IDS iplog, Microsoft Network Monitor, Network General Sniffer® (compressed and uncompressed), Sniffer® Pro, and NetXray®, Network Instruments Observer, Novell LANalyzer, RADCOM WAN/LAN Analyzer, Shomiti/Finisar Surveyor, Tektronix K12xx, Visual Networks Visual UpTime, WildPackets EtherPeek/TokenPeek/AiroPeek, and many others
• Capture files compressed with gzip can be decompressed on the fly
• Live data can be read from Ethernet, IEEE 802.11, PPP/HDLC, ATM, Bluetooth, USB, Token Ring, Frame Relay, FDDI, and others (depending on your platfrom)
• Decryption support for many protocols, including IPsec, ISAKMP, Kerberos, SNMPv3, SSL/TLS, WEP, and WPA/WPA2
• Coloring rules can be applied to the packet list for quick, intuitive analysis
• Output can be exported to XML, PostScript®, CSV, or plain text
Wireshark je světový především síťový protokol analyzátor, a je ve skutečnosti (a často de iure) standard napříč mnoha průmyslových odvětví a školských institucí.
Wireshark vývoj daří se díky příspěvkům expertů připojení do sítě napříč zeměkoulí. To je pokračování projektu který začal v roce 1998.
Wireshark CETN:23 R34607 hlavní sada která zahrnuje následující:
• Hluboká inspekce ze stovek protokolů, s více být přidanou po celou dobu
• Živá chycení a offline analýza
• Standardní tři-okenní tabule prohlížeč balíčku
• Multi --platforma: Běžet dáli Windows, Linux, OS X, Solaris, FreeBSD, NetBSD, a mnoho jiných
• Chycená síťová data mohou být brouzdal přes GUI, či přes TTY-MODE TSHARK utilitu
• Nejmocnější displej filtruje v průmyslu
• Bohatá VoIP analýza
• Četba/píše mnoho jiných zachytávacích formátů souboru: tcpdump (libpcap), prak DCT2000, Cisco Secure IDS iplog, Microsoft Network Monitor, síť generál Sniffer® (stlačený a dekomprimovaný), Sniffer® Pro, a NetXray®, síťový nástroje pozorovatel, Novell LANALYZER, RADCOM WAN/LAN Analyzer, Shomiti/Finisar Surveyor, Tektronix K12xx, vizuální síťová vizuální doba pohotovosti provozuschopnosti, WildPackets EtherPeek/TokenPeek/AiroPeek, a mnoho jiných
• Soubory s obsahem obrazovky stlačený s gzip mohou být rozbalit za letu
• Skutečná data může být čtený z Ethernetu, IEEE 802.11, PPP/HDLC, ATM, Bluetooth, USB, prsten znaku, družice rámu, FDDI, a jiní (v závislosti na váš platfrom)
• podpora rozluštění pro mnoho protokolů, včetně IPSEC, ISAKMP, Kerberos, SNMPV3, SSL/TLS, WEP, a WPA/WPA2
• Barvicí pravidla mohou být aplikovaný na balíček seznam pro rychlou, intuitivní analýzu
• Výstup může být exportuje do XML, PostScript®, CSV, či čistý text
 Predmet príspevku: Re: Wireshark 1.1.2
PoslaťNapísal: Str 04. Nov 2009 15:26:13
