Aktuálny čas je Str 04. Nov 2026 4:50:42
 HTML Email Creator 2.1.659
 Predmet príspevku: HTML Email Creator 2.1.659
PoslaťNapísal: Sob 21. Feb 2009 14:11:53
HTML Email Creator creates HTML email by a HTML file, and sends the HTML email. HTML email is popular in newsletter, product promotion, and online survey. As it presents information that's laid out like a web page, in a way that's more visually appealing, and much easier to scan and navigate, than plain text email. And, publishers can track rates for email opens, forwards, and clicks, and thereby can measure reader interest in products and topics.
Benefits of HTML Email Creator:
1. Easy to create HTML newsletter or survey email
HTML email presents information that's laid out like a web page and allows publisher to track email opens and clicks. HTML Email Creator offers 3 easy steps to create a HTML email: create a HTML file by your favorite web page editor, and then choose the HTML file in the software, then click button "Create Email."
2. Send HTML email
If you need to send the HTML email directly, just click button "Send Email" on the software, then the HTML email is sent to mail boxes in From and Cc.
3. Supports Javascript, CSS, and any HTML tags
The software supports both external and inline Javascript and CSS. If it's an external file, the software encodes the file to HTML email.
4. Encode image files to HTML email
If there're images on your HTML file, the software encodes the image files to HTML email
5. Compatible with popular email clients and web-based email
We've tested HTML email outputted and sent by HTML Email Creator is compatible with popular email clients and web-based email such as Outlook, Thunderbird, Eudora, Gmail, Hotmail, and Yahoo! Mail.
6. Easy to use
HTML Email Creator is very easy to use. And we offer step by step instructions to use the software.
HTML Email Stvořitel vytváří HTML email HTML souborem, a posílá HTML email. HTML email je populární v informačním bulletinu, propagaci produktu, a online průzkumu. Jak to představuje informaci kterou je naservírovanou jako webovou stránku, způsobem, který je víc vizuálně apelování, a moc snadnější k tomu, aby skenovala a navigovat, než email čistého textu. A, vydavatelé mohou sledovat sazby pro email otvírá, vpředu, a cvaká, a tím může měřit čtenářský zájem o produkty a témata.
Výhody pro HTML emailovou Stvořitele:
1. Snadný k tomu, aby vytvořil HTML informační bulletin či provést průzkum emailu
HTML email představuje informaci která je naservírovaná jako webová stránka a dovoluje vydavatele sledovat email otvírá a cvakne. HTML Email Stvořitel nabízí 3 snadné krokům k vytvořit HTML email: vytvořit HTML soubor vaším oblíbeným webovým stránkovým editorem, a potom si vybrat HTML soubor v softéru, pak cvakněte knoflík "Vytvořte email."
2. Vysílací HTML email
Pokud potřebujete poslat HTML email přímo, jen klikne knoflík "Pošlete email" na sof téru, pak HTML email je poslaný do obrnit obkličuje From a Cc.
3. Podporuje Javascript, CSS, a nějaký /každý /žádný HTML značkuje
Software podporuje obojí externí a v řadě za sebou Javascript a CSS. Jestli to je vnější soubor, software zakódovává soubor k HTML emailu.
4. Zakódujte obrazové soubory k HTML emailu
Jestli jsou obrazy na vašem HTML souboru, software zakódovává obrazové soubory k HTML emailu
5. Slučitelný s populárním emailovým klienty a internetovým emailem
My jsme testovali HTML email výstup a poslaný HTML Emailem Stvořitelem je slučitelný s populárním emailovým klienty a internetovým emailem jako Outlook, bouřlivák, Eudora, Gmail, Hotmail, a Yahoo! Pošta. 6. Snadno použitelný
HTML emailový Stvořitel je velmi snadno použitelný. A my nabízíme krok za krokem instrukce použít software.
 Predmet príspevku: Re: HTML Email Creator 2.1.659
PoslaťNapísal: Str 04. Nov 2009 15:27:46
