Aktuálny čas je Uto 28. Apr 2026 6:14:23
 GVG Info 3.8.1
 Predmet príspevku: GVG Info 3.8.1
PoslaťNapísal: Pia 20. Feb 2009 15:17:13
This program is used mainly by administrators or by people, who making computer installations as job or they do that for friends and want to have summary in one place of all installed machines. This will help to make your work effective and thanks to this program, you will not loose lot of money when discovering who have what installed. If problem occours, you will know all about installed computer by clicking few steps. All you need to know is name of your customer/friend. Of course – you must first create database of them, but this part of work will helps you in future. Generated lists you can also add to installed computer, so owner will have quick summary, what he have on his PC.
Program isn`t benchmark or detect utility – it is composed mainly for people mentioned above. For detecting or benchmarking utility look over the internet.
If you want to have your work easier, you can use additional program GVG Info Detect. You can detect most of hardware and detected data can be exported to file. Then, you can use this file in GVG Info application. Thanks to it, your work will not be so hard and you must correct only small amount of informations. Of course, this program isn`t required when you want to use GVG Info - it only helps you when filling informations. Program is available only in English language.
Installer and program are signed by digital sign. To accept Windows these signed files, it is requiered to install root certificate from certificate authority Ascertia. Installation is simple - just download this file and choose "Open". Then, click on "Install Certificate..." button and install certificate to "Trusted root certificate services". After this, all my signed programs will be trusted in Windows and also Windows Vista will not be in problem with running or installing. If you not install this certificate, Windows Vista can have problem and it is possible, that running or installing will not be allowed; to avoid this security problems, install this certificate.
Tento program je užívaný hlavně administrátory či lidmi, kdo dělání počítačových instalací jak práce či oni dělají to pro přátele a chtějí mít shrnutí na jednom místě všech nainstalovaných strojů. Toto bude pomáhat udělat vaše práci efektivní a díky tomuto programu, vy budete neupustíte hromadu peněz při objevování kdo má co instalovalo. Jestli nejasný occours, vy budete vědět všechno o nainstalovaném počítači kliknutím málo schodů. Vše co potřebuje vědět je jméno vašeho zákazníka/přítele. Samozřejmě – musíte poprvé vytvořit databázi o nich, ale tato část práce pomůže Vám v budoucnu. Vygenerované seznamy, které vy můžete také přidat k nainstalovanému počítači, tak majitel bude mít rychlé shrnutí, co on má na jeho PC.
Program není měřítko či zjistí utilitu – to skládá se hlavně pro lidi výše zmíněný. Pro odhalování či porovnání výkonností užitkového pohledu přes internet.
Jestli chcete mít vaši práci snadnější, vy můžete použít dodatečný programový GVG Info zjistí. Vy můžete zjistit většinu hardwaru a jste objevili data může být exportuje do registrovat. Pak, vy můžete použít tento soubor v GVG Info aplikaci. Díky v tom, vaše práce nebude tak tvrdý a musíte opravit jen malé množství informací. Samozřejmě, tento program není požadovaný když chcete užívat GVG Info - to jen pomáhá Vám při plnění informací. Program je k dispozici jen v anglickém jazyce.
Instalátor a program jsou podepsaný digitálním podpisem. Pro přijmout Windows tyto podepsal soubory, to je požadavek k tomu, aby instaloval kořenný certifikát z certifikátové autority Ascertia. Instalace je jednoduchá - jen stáhnout tento soubor a vybrat si "Otevřete". Pak, kliknutí na "I nstalujte certifikát..." zapnout a instalujte certifikát k "Důvěryhodný kořenný certifikát se stará o údržbu". Po tomto, veškerý moje podepsané programy bude důvěryhodný ve Windows a také Windows Vistách nebude v problému s běžící či instalaci. Jestli vy neinstalujete tento certifikát, Windows Visty může mít problém a je možné, to běžící či instalaci nebude dovolený; vyhnout se těmto bezpečnosti problémům, instalujte tento certifikát.
 Predmet príspevku: Re: GVG Info 3.8.1
PoslaťNapísal: Str 04. Nov 2009 15:33:08
