Aktuálny čas je Ned 20. Sep 2026 9:17:33
 Quicksys RegCleaner 2009 v2.1.0.209
 Predmet príspevku: Quicksys RegCleaner 2009 v2.1.0.209
PoslaťNapísal: Pia 20. Feb 2009 15:32:33
oosts PC and makes your computer run like new.
It's quite amazing how different Quicksys RegCleaner 2009 is. The software was designed for multithreading! Try it.
Quicksys RegCleaner 2009 scans the Windows® registry and finds incorrect information. You can safely clean, repair and optimize the Windows® registry by fixing this errors. Your system will run faster, will be more stable.
* Boosts PC and makes your computer run like new.
* Optimize, speed up and cleanup your PC
* Increase the stability of the overall system
* Load windows faster and reduce windows startup time
* Prevent application crashes
What is Windows® Registry?
The Windows® registry is a central hierarchical database in Windows® used to store information necessary to configure the system for one or more users, applications, and hardware devices. The registry contains information that is constantly referenced during operation, such as profiles for each user, the applications installed on the computer; and the types of documents each can create, property sheet settings for folders and application icons, what hardware exists on the system; and which ports are being used.
Quicksys RegCleaner 2009 achieve maximum performance for your computer!
The software will quickly, easily and safely detect and remove invalid references in Windows® registry. Lot of invalid entries that cause system complications and slow down your computer significantly.
Quicksys RegCleaner 2009 was designed for multithreading!
On single-processor machines, multithreading can help applications where some tasks take much longer to execute than others, some tasks need a better deterministic outcome than others, and user interface activity may run concurrently with hardware communications. On multiprocessor systems, multithreading an application takes advantage of the additional hardware and can result in greatly improved overall performance.
To je docela úžasný jak jiný Quicksys RegCleaner 2009 je. Software byl určený pro multithreading! Zkuste to.
Quicksys RegCleaner 2009 skenuje Windows® registr a nalézá nesprávnou informaci. Vy můžete bezpečně čistit, opravit a optimalizovat Windows® registr fixací těchto chyb. Váš systém bude běžet rychlejší, být víc stabilní.
* podporuje PC a dělá váš počítač běžet jako nový.
* optimalizuje, rychlost nahoru a vyčištění vašeho PC
* zvýší stabilita z celkového systému
* nákladová okna rychleji a redukují okna startovní čas
* předejít aplikačním haváriím
Co je Windows® Registry?
Windows® registr je střední hierarchický databáze ve Windows® užívaný pro informace uložená v paměti nezbytný ke konfigurovat systém pro jeden nebo víc uživatelů, aplikací, a strojových zařízení. Registr obsahuje informaci která je stále zmíněná během operace, jako profily pro každého uživatele, aplikace nainstalovaný na počítači; a druhy dokumentů každých může vytvořit, majetková tabulová nastavení pro složky a aplikační ikony, co hardware existuje na systému; a které přístavy jsou jsou použité.
Quicksys RegCleaner 2009 dosáhne maximálního výkonu pro váš počítač!
Software bude rychle, snadno a bezpečně zjistit a odstranit neplatné odkazy ve Windows® registru. Hodně neplatných zápisů které způsobuje systémové komplikace a zpomalit váš počítač významně.
Quicksys RegCleaner 2009 byl určené pro multithreading!
Na jednotlivých- strojích procesoru, multithreading může pomáhat aplikacím kde nějaké úkoly moc trvají déle, než vykonat než jiní, nějaký úkoly potřebují lepší deterministický výsledek než jiní, a uživatelský aktivita rozhraní může běžet souběžně s hardwarem komunikacemi. Na systémech počítače s více procesory, multithreading aplikace využívá dodatečný hardware a může mít za následek velmi zlepšený celkový výkon.
 Predmet príspevku: Re: Quicksys RegCleaner 2009 v2.1.0.209
PoslaťNapísal: Str 04. Nov 2009 15:29:58
