Aktuálny čas je Uto 15. Sep 2026 3:24:35
 Digital Postman Pro 2.14
 Predmet príspevku: Digital Postman Pro 2.14
PoslaťNapísal: Sob 21. Feb 2009 14:03:48
Send any document as e-mail attachment! It's so easy. Start Digital Postman. Put your document in the scanner and Digital Postman will do the rest. He will generate a new message in your e-mail program and attach the document. He will then ask you for the recipient's address and a subject and to press Send. It's easier than sending a fax!
Program details:
* Digital Postman supports the use of Automatic Document Feeders (ADF) , so sending a multi-page document is just as easy.
* Images can be attached in EXE-format and also as JPEG, GIF, PNG, PDF and multi-page TIFF format. Using PDF or TIFF format all images are put into only one attachment file, which makes handling and storing by the recipient much more convenient.
* You can also send images that are already on your disk somewhere. Just press the Load button. Digital Postman Pro reads TIFF, PCX, GIF, TGA, BMP, JPEG and PNG files.
* You can get a preview of the scanned image. From the preview window you can manipulate (rotate, invert, mirror) the scanned image.
* Auto crop function, to remove superfluous parts of the scanned image.
* You can select the imaging device to use. Convenient when you have both a scanner and a video camera attached to your system.
* Thumbnail views of scanned and loaded images. Right click on a thumbnail view to manipulate (rotate, invert, mirror) the image, print the image or save it to disk in any of the formats Digital Postman Pro supports.
Digitální listonoš pro 2.14
Pošlete nějaký /každý /žádný dokument jak e - mailové připojení! To je tak snadný. Začněte digitálního listonoše. Dejte váš dokument v snímacím zařízení a Digital Postmanovi udělá zbytek. On zgeneruje novou zprávu ve vašem e - mailovém programu a připojit dokument. On bude pak žádat vás o adresu příjemce a předmětu a tisknout Send. To je snadnější než posílání faxu!
Programové detaily:
* digitální listonoš podporuje použití Automatic podavačů dokumentů (ADF) , tak posílání multi -- stránkového dokumentu je jen tak snadný.
* obrazy mohou být připojený v EXE-FORMAT a také jak JPEG, GIF, PNG, PDF a multi -- stránkový TIFF formát. Používání PDF či TIFF formátu všechny obrazů jsou dané do jen jednoho souboru připojení, které dělá zacházení a uskladněním příjemcem mnohem víc vhodné.
* vy můžete také poslat obrazům které jsou již na vašem disku kdesi. Jen stiskněte Load klávesu. Digitální Postman Pro čte TIFF, PCX, GIF, TGA, BMP, JPEG a PNG soubory.
* vy můžete dostat náhled snímaného obrazu. Z kontrolního okna vy můžete manipulovat (točte, převraťte, zrcadlo) snímaný obraz.
* auto funkce úrody, odstranit přebytečné části snímaného obrazu.
* vy můžete vybrat zobrazovací zařízení použít. Vhodný kdy vy máte oba snímací zařízení a videokameru napojenou na váš systém.
* pohledy na miniaturní zmenšeniny obrázků snímané a naložené obrazy. Pravé kliknutí na miniaturním zmenšeninách obrázků ohledu na manipulovat (točí, převrátit, zrcadlo) obraz, tisknout obraz či zákrok to disku v každý z formátů Digital Postmana Pro podpory.
 Predmet príspevku: Re: Digital Postman Pro 2.14
PoslaťNapísal: Str 04. Nov 2009 15:28:45
