Aktuálny čas je Uto 15. Sep 2026 1:03:56
 Systweak.CacheBoost.Professional.Edition.v5.0.Incl.KeyMaker
 Predmet príspevku: Systweak.CacheBoost.Professional.Edition.v5.0.Incl.KeyMaker
PoslaťNapísal: Pia 27. Mar 2009 16:44:52
CacheBoost optimizes the Windows cache management and the performance of your system under Windows Vista/XP/2000 and Windows Server. The result is that your programs run faster and become more stable than ever before! It monitors and controls over the processes that take place in the memory and reclaims wasted memory on your computer.
CacheBoost’s integrated suite of programs can recover memory leaks from your system and prevent Windows crashes. The built-in Memory Zipper engine and Data Safe Technology enhances the available system memory and ensures complete reliability and safety of data. It not only includes the usual fare of option to export customized settings and to apply the same on another machine but has numerous of options to fine tune your system.
CacheBoost is available in two editions. Professional Edition and Server Edition. Professional Edition is best suited for Desktops and Day to day use. Server Edition comes with “Server Tune" Feature and is ideal for servers.
Make Your PC More Responsive
CacheBoost runs in the background to free up more memory on your computer. This means that you get more power and response from your system when you need it the most. Your computer becomnes more responsive and it starts to function faster.
Optimize your Gaming Experience
When you need more power from your system, your computer becomes more responsive with CacheBoost. This is specially useful when you are playing games and you want the computer to respond faster and become more responsive.
Optimize System Memory
This is the manual optimization process. You can simply press the button and your memory will be de-fragmented, memory leaks repaired and the unused system modules will be unloaded from the memory.
Empty System Cache
With regular use of the computer, the System Cache starts to fill up with unwanted traces and remnants of software. When large amount of data is moved, system cache starts to fill and take up space. It is suggested that you empty the system cache so that your operations are optimized and you get a fast computer.
Memory Resource Allocation
CacheBoost runs in the background as a service, with an indicator in the sytem tray to show you the current status of the resources. You can also optimize the resources manually by de-fragment and repairing the memory leaks, and emptying the system cache.
Utilize Existing Hardware Efficiently
CacheBoost improves the speed and reliability of your computer without adding any new hardware to your computer. This is made possible because CacheBoost utilizes the existing hardware resources to the fullest. It manages the allocation of memory for execution of various programs, and therefore it optimizes the resources available for your needs.This means that the programs and applications in the background are given adequate resources, with a focus on the applications and process in the foreground, on which you are actively working. This ensures that you can perform multiple functions at one time and you have enough resources available whenever you need them.
Optimize the Cache Management
CacheBoost comes with preset for most of the settings. If you are a regular computer user, you should not have any need to change the settings in the Application. In case you are a power user, you might want to change and customize the settings of the software according to your requirement. In that case, you can change the settings from the settings console.
How can Data Safe increase performance and safety of your system
Windows uses System Cache to improve the access speed of data on your computer. It is important that while using the computer, the data gets read very soon and therefore instead of writing every file on the hard disk, Windows writes these files to a faster location called the System Cache. Though these files make the data access process faster, it also reduces the safety of the data as it is written on the system cache, before being written to the more permanent hard drive. CacheBoost ensures that these chunks of data are written to their right place on the hard drive and the risk of losing data due to crash or failure are minimized.
Data-Safe Technology
Data Safe is a unique feature of CacheBoost. CacheBoost searches for individual chunks of data in the memory, which have not been saved. These chunks of data are then saved to the hard disk to ensure that even in case of power failure or a crash, your data is safe and you can rest assured.
Need for Data Safe
Windows writes all data to the System Cache, before copying it to the Hard Disk. This is because smaller chunks of data are not written to the Hard Disk but to the System Cache. Windows considers that the data may be required again and therefore stores it in the buffer for sometime. However, if there is a power failure, Application error or a system crash, this entire data may be lost at once. http://www.luxter2.ru CacheBoost writes this data to the Hard Disk and protects your data.
Make your Windows Faster
CacheBoost has tuning and tweaking options which can make your system faster by improving the core system performance, optimizing the system cache and clearing the swap files. The tuning options make your windows faster by utilizing it to the fullest.
Large System Cache
CacheBoost allows you to create a Large System Cache. This means that there is more room for cache in memory. It helps in keeping the Operating System Kernel in the memory and therefore the Operating System performance may improve considerably. It should increase the speed considerably, at a small cost of memory consumption. It is recommended that this option is checked.
Keep Core Kernel Executive in Memory
Core Kernel Executive of the Operating System is the set of most essential files of the Operating System. When Windows keeps these files in the RAM, the performance of your computer may increase manifold as the operating system is very responsive.
More Critical Threads
Threads are sequences of operation in the Operating System. When Windows is performing critical tasks, the process of creation of a system thread may take some more time than usual. By creating more critical threads, Windows creates additional threads in advance so that the system speed is positively improved.
Force Windows not to Update Time Stamps
When Windows accesses any file/directory on the Network File System (NTFS) volume, it updates the latest time stamp on it. Whenever Windows will access a large number of files and folders, the updation of the time-stamp will take a long time and the computer may become very slow. It is recommended that you disable the process of time-stamp updation by selecting this option in CacheBoost.
Disable Creating Short File Names
Operating Systems used to understand only 8.3 legacy names in the past. It meant 8 characters of the name and 3 characters of extension. With Windows and the latest Operating Systems, there is no need for such small names as the operating system can understand larger names as well. It is recommended that the creation of short file names be disabled to increase the speed, specially recommended for servers.
CacheBoost optimalizuje windowsovský cache management a výkon vašeho systému pod Windows Vistami/XP/2000 a windowsovský Server. Výsledek je že vaše programy provozovaný rychlejší a stávají se víc stabilní než kdy předtím! To monitoruje a kontroly nad procesy které konat se v paměti a znovu získají zbytečnou paměť na vašem počítači.
CacheBoost- ovo integrovaná souprava programů může obnovit paměťové netěsnosti z vašeho systému a zabránit windowsovským haváriím. Zabudovaný Memory Zipper motor a Data Safe Technology zvyšuje dostupnou systémovou paměť a zajišťuje kompletní spolehlivost a bezpečí dat. To nejen zahrnuje obvyklý jízdné volby k tomu, aby exportovala zákaznicky přizpůsobená nastavení a použít stejný na dalším stroji ale má četný voleb k tomu, aby jemně ladily váš systém.
CacheBoost je k dispozici ve dvou vydáních. Profesionální vydání a serverové vydání. Profesionální Edition je nejlépe vhodný pro Desktops a každodenní použití. Serverový Edition jde s "serverovým nápěvem" Uvádějte a jste ideální pro servery.
Udělejte váš PC víc vnímavý
CacheBoost běží v pozadí k tomu, aby uvolnilo nahoru víc paměti na vašem počítači. Toto znamená, že vy dostanete více síly a odpovědi z vašeho systému kdy vy potřebujete to většinu. Váš počítačový becomnes víc vnímavý a to začíná fungovat rychleji.
Optimalizujte vaši zkušenost hraní
Kdy vy potřebujete více síly z vašeho systému, váš počítač se stává víc vnímavý s CacheBoost. Toto je speciálně užitečný kdy vy hrajete si a chcete počítač k tomu, aby odpovídal rychleji a stávat se víc vnímavý.
Optimalizujte systémovou paměť
Toto je ruční optimalizační proces. Vy můžete jednoduše stisknout klávesu a vaši paměť bude de-fragmentovaný, paměťové netěsnosti opravené a nepoužité systémové jednotky bude složený z paměti.
Prázdný systémový cache
S pravidelným použitím počítače, System Cache začíná naplnit se nechtěnými stopami a zbytky softéru. Kdy velké množství dat je přesunuté, systémový cache začíná plnit a zdvihnout prostor. To je navrhovaný že vy vyprázdníte se systémové cache tak, že vaše operace jsou optimalizované a vy dostanete rychlý počítač.
Paměťové přidělení zdrojů
CacheBoost běží v pozadí jak služba, s indikátorem v sytem podnosu k tomu, aby ukázal vám aktuální status zdrojů. Vy můžete také optimalizovat zdroje ručně de-zlomkem a opravujícími paměťovými netěsnostmi, a vyprazdňováním systémový cache.
Zužitkujte existující hardware efektivně
CacheBoost zlepšuje rychlost a spolehlivosti vašeho počítače bez přidávání nějakého /každého /žádného nového hardwaru vašemu počítači. Toto je udělaný možný protože CacheBoost zužitkuje existující hardware zdroje k vrcholně. To řídí přiřčení paměti na výkon různých programů, a proto to optimalizuje zdroje dostupné pro vaše potřeby.Toto znamená, že programy a aplikace v pozadí dostane adekvátní zdroje, se zaměřením se na aplikace a proces v popředí, na které vy aktivně pracujete. Toto zajišťuje že můžete vykonávat vícenásobné funkce najednou a vy máte dost zdrojů dostupných kdykoli vy potřebujete je.
Optimalizujte cache management
CacheBoost jde s předvolit pro většinu nastavení. Jestli vy jsou pravidelní uživatelé počítače, vy byste neměli jakýkoliv potřebovat měnit nastavení v Application. V případě, že vy jsou pokročilý uživatel, možná, že bys mohl chtít měnit a přizpůsobit nastavení softéru podle vašeho požadavku. V tom případě, můžete změnit nastavení z konzoly nastavení.
Jak může Data Safe zvýšit výkon a bezpečí vašeho systému
Windows užívají System Cache zlepšit vybavovací rychlost dat na vašem počítači. Je důležité že při použití počítače, data dostává čtený velmi brzy a proto namísto psaní každých souborů na harddisku, Windows píší tyto soubory k rychlejšímu umístění nazvanému System Cache. Ačkoli tyto soubory udělají přístup k datům proces rychlejší, to také redukuje bezpečí z dat jak to je psaný na systémový cache, před je napsán, aby více stálý pevný disk. CacheBoost zajistí, že tyto pořádné kusy dat jsou napsaný na jejich správné místo na pevném disku a riziku ztrácení dat kvůli havárii či selhání jsou minimalizovaný.
Datová-bezpečná technologie
Datový Safe je jedinečný rys CacheBoost. CacheBoost hledá pro individuální pořádné kusy dat v paměti, která není ušetřená. Tyto pořádné kusy dat jsou pak ušetřené harddisku zajistit že dokonce v případě poruchy sítí či havárie, vaše data je bezpečná a vy můžete být ujištěn.
Potřebujte pro data sejf
Windows píší všechna data System Cache, před kopírováním to do harddisku. Toto je protože menší pořádný kus z dat není napsaný pro harddisk ale System Cache. Windows považují , že data může být požadovaný znovu a proto skladují to v buffer pro někdy. Ať tak nebo onak, jestli je tam porucha sítě, aplikační chyba či systém havárie, tato celá data mohou být ztracený najednou. www.luxter2.ru CacheBoost píše tyto data k harddisku a chrání vaše data.
Udělejte vaše Windows rychlejší
CacheBoost má ladicí a štípající volby které může udělat váš systém rychlejší zlepšováním jádra charakteristiky systému, optimalizace systému cache a vyčištění swapovací souborů. Ladicí volby udělají vaše okna rychleji využitím tím do vrcholně.
Velký systémový cache
CacheBoost dovoluje vám vytvořit Large System Cache. Toto znamená, že tam je víc místnosti pro cache v paměti. To pomáhá v souladu Operating System Kernel v paměti a proto Operating charakteristice systému může zlepšit značně. To by mělo zvýšit rychlost značně, v malé ceně paměťové spotřeby. To je doporučená, aby tato volba je kontrolovaná.
Držet jádro exekutivu jádra v paměti
Jádro Kernel Executive z operačního systému je sada nejvíce základních souborů operačního systému. Kdy Windows drží tyto soubory v RAM, výkon vašeho počítače může zvýšit kopii jak operační systém je velmi vnímavý.
Víc kritických nití
Niti jsou pořadí operací v operačním systému. Kdy Windows vykonávající kritické úkoly, proces vytvoření systémové niti může vzít nějaký další čas než obvyklý. vytvořením víc kritických nití, Windows vytvářejí dodatečné niti v postupu tak, že systémové rychlosti je pozitivně zlepšená.
Nutit Windows neaktualizovat časové údaje
Kdy Windows zpřístupňuje nějaký /každý /žádný soubor/adresář na Network Fili System (NTFS) hlasitosti, to aktualizuje poslední časový údaj na tom. Kdykoli Windows zpřístupnit velké množství souborů a složek, aktualizace času-známky bude trvat dlouho a počítač se může stát velmi pomalý. To je doporučené, abyste vyřadili proces času- aktualizace známky vybráním těchto možností v CacheBoost.
Zbavit způsobilosti vytvoření krátkých jmen souboru
Operační systémy rozuměly jen 8.3 odkaz jmenuje v minulosti.
 Predmet príspevku: Re: Systweak.CacheBoost.Professional.Edition.v5.0.Incl.KeyMaker
PoslaťNapísal: Uto 27. Okt 2009 21:56:27
neplatný link.....plz mvoze niekto reuploadnut? :(
