Aktuálny čas je Str 16. Sep 2026 12:49:49
 Najnovšia verzia - Ashampoo Internet Accelerator 3.10+serial
 Predmet príspevku: Najnovšia verzia - Ashampoo Internet Accelerator 3.10+serial
PoslaťNapísal: Uto 14. Júl 2009 15:04:36
Síce aj tento soft je vlastne v celosti v súhrne zameraný ako to aj s názvu vyplíva na ACCELERACIU INTERNETU, ale musím skonštatovat, že i napriek jeho novšej verzii sa nevyrovná ACCELERATORU - "Registry.Kit.v2.0" ktorý som taktiež dnes pridal....samozrejme až po vyskúšaní pochopíte moje tvrdenie ..............čaute s pozdravom "pista"...
:mafia: :mafia: :mafia: :mafia: :mafia: :mafia: :mafia: :mafia: :mafia: :mafia: :mafia: :mafia: :mafia: :mafia: :mafia:
We all take the Internet for granted nowadays but what your computer has to do to allow you to surf is actually amazingly complicated. Windows has a long list of settings for tuning the performance of your Internet connection.
That’s fine if you’re a computer expert, the rest of us will generally make things worse rather than better – if we can find all the well-hidden settings in the first place.
Ashampoo Internet Accelerator analyzes your computer and optimizes all the relevant settings with a single click. You don’t need to know anything, just select the automatic optimizer and you’re done. The new version also includes an Internet connection speed test tool so you can test your performance directly.
In addition to automatic optimization advanced users can still access all the individual settings and adjust them manually.
Easier to use, plus new tools and settings:
We’ve redesigned the layout, making the program even easier to use. Everything is explained directly, you’ll probably never have to refer to the help. In addition to this we’ve also added a set of new tools and features for managing your Internet connection.
Boost and configure Internet Explorer and Firefox
Internet Explorer and Firefox are the two most popular browsers and you can now configure them and boost their performance right from internet Accelerator. In addition to performance-enhancing settings you also get direct access to a large number of useful browser settings, all in one place.
Internet Cleaner tool
Your browser saves a record of everything you do and every page you visit. The new Internet Cleaner tool lets you quickly delete your complete surfing trail, with separate settings for Internet Explorer, Firefox and Opera.
Hosts File Checker
Your computer’s “Hosts” file lists the location of known Internet sites and is always checked first for the address when you access a site. Spyware and other malicious programs can use it to redirect you to fake and dangerous sites – the new Hosts File Checker makes sure this isn’t happening.
Interactive checking for key parameters
In addition to optimizing your access speed Internet Accelerator can also interactively check some advanced parameters on your live connection to work out the best settings. You don’t have to use this feature, but it’s there if you want it.
New features:
Intuitive new layout – everything explains itself
Internet Cleaner – quickly erase your surfing trail
Hosts File Checker – stop spyware redirecting you
Interactive auto-check for key Internet access settings
Všichni jsme si vzít na internetu se dnes za samozřejmé, ale co váš počítač má udělat, aby vám umožní surfování je ve skutečnosti překvapivě složité. Windows má dlouhý seznam nastavení pro ladění výkonu vašeho internetového připojení.
To je pokuta, pokud máte v počítači odborníka, zbytek z nás bude obecně dělat věci horší, než lepší - jestli můžeme najít všechny skryté i-nastavení na prvním místě.
As hampoo Internet Accelerator analyzuje váš počítač a optimalizuje všechny relevantní nastavení pomocí jediného kliknutí. Nemusíte vědět nic, stačí zvolit automatickou optimalizaci a máte hotovo. V nové verzi je také připojení k internetu rychlostí zkoušce nástroje, takže si můžete vyzkoušet své výkonnosti přímo.
Kromě automatické optimalizace zkušení uživatelé stále mohou získat přístup ke všem individuální nastavení a nastavit ručně.
Snadnější použití, plus nové nástroje a nastavení:
Zjistili jsme přepracovali uspořádání, čímž se program ještě snadnější použití. Vše je vysvětleno přímo, budete pravděpodobně nikdy nebude muset odkázat na pomoc. Kromě toho jsme také přidali nový soubor nástrojů a funkcí pro správu vašeho internetového připojení.
Boost a konfiguraci aplikace Internet Explorer a Firefox
Internet Explorer a Firefox jsou dva nejpopulárnější prohlížeče a nyní můžete konfigurovat a zvýšit jejich výkonnost přímo z internetu Accelerator. Kromě výkonu-zvýšení nastavení také získat přímý přístup k velké množství užitečných nastavení prohlížeče, vše na jednom místě.
Internet Cleaner nástroje
Váš prohlížeč ukládá záznam o vše, co dělat, a každé stránky, které navštěvujete. Nový Internet Cleaner nástroj vám umožní rychle smazat svůj kompletní surfování stezka s odděleným nastavením pro Internet Explorer, Firefox a Opera.
Soubor Hosts Checker
Počítače "Hosts" file seznamy umístění známých internetových stránek a je vždy zkontrolovat první na adresu při přístupu k webu. Spyware a jiné škodlivé programy mohou používat k přesměrování vám falešná a nebezpečných míst - nového souboru Hosts Checker zajišťuje to není pravda.
Interaktivní kontrola klíčových parametrů
Navíc váš přístup k optimalizaci rychlosti Internet Accelerator můžete rovněž interaktivně kontrolovat některých pokročilých parametrů na vaše aktivní připojení k práci to nejlepší nastavení. Nemusíte používat tuto funkci, ale je to tam, pokud si budete přát.
Nové funkce:
Intuitivní nový layout - vše vysvětluje sám
Internet Cleaner - rychlé vymazání vašeho surfování stezka
Soubor Hosts Checker - stop spyware přesměrování vás
Interaktivní auto-check pro klíčové nastavení přístupu k internetu
