Aktuálny čas je Pon 14. Sep 2026 8:57:57
 PCThrust 1.3.23.2009 Cracked
 Predmet príspevku: PCThrust 1.3.23.2009 Cracked
PoslaťNapísal: Uto 24. Mar 2009 12:53:36
A program which allows you to run applications much faster then the original programmer intended
PcThrust is a useful application that allows you to modify the computer settings in order to increase performance and speed.
With little to no effort you can easily make programs & games run faster on your computer without having to purchase a new PC.
Many programs and games often use a minimal amount of CPU power which often leads to the CPU being idle and really not much use at all. PCThrust takes advantage of this by allocating more CPU power to the currently active program/game.
All of this is done automatically without having you to lift one finger. PCThrust is a great affordable alternative to purchasing a new computer and can in no way harm or destroy a computer, while providing equivalent power that a faster processor would.
PCThrust is quite easy to use and understand. With a few button pushes and setting changes the application is ready to work. PCThrust starts up automatically when Windows does and manages the CPU/Processor according to the user's specifications.
Here are some key features of "PCThrust":
· Built-in block list of applications which are not compatible, to prevent problems with the software such as slow downs or computer crashes.
· Easy and intuitive user interface which performs CPU tuning in real-time.
· Microsoft Internet Explorer 4 or higher
· Intel Pentium 90 MHz or higher (P 166 MHz recommended)
· 8 Mb RAM (32 Mb recommended)
· 5 Mb hard disk space
· VGA or higher resolution monitor
· Mouse or other pointing device
Program který dovoluje vám běžet aplikace moc rychlejšího pak originálního programátora zamýšlel
PcThrust je užitečný aplikace která dovoluje vám modifikovat počítačová nastavení k tomu, aby zvýšila výkon a rychlost.
S málo k žádnému úsilí vy můžete snadno udělat programy & hry běžet rychlejší na vašem počítači bez toho, muset koupit nový PC.
Mnoho programů a her často užívá minimální množství CPU síly která často vede k CPU být nečinnému a opravdu nemnoho užívá vůbec. PCTHRUST využívá toto rozvrhnutím více CPU síly k aktuálně aktivní programu/hře.
Všechno toto je udělaný automaticky bez toho, mít vás zvednout jeden prst. PCTHRUST je ohromná dostupná alternativa nákupu novému počítači a může nikterak ublížit či zničit počítač, při poskytující ekvivalentnímu síle která rychlejšímu procesoru .
PCTHRUST je docela snadno použitelný a rozumět. S několika knoflíku tlačí a nastavení mění aplikaci je připravený pracovat. PCTHRUST vystartuje automaticky kdy Windows dělají a řídí CPU/procesor podle uživatelských specifikací.
Zde jsou nějaké klíčové rysy "PCTHRUST":
· zabudovaný blokový seznam aplikací které nejsou kompatibilní, předejít problémům se softvérem jako pomalý duny či počítač havarují.
· snadné a intuitivní uživatelské rozhraní které vykonává CPU laděný v reálném čase.
· Microsoft Internet Explorer 4 či vyšší
· Intel Pentium 90 MHZ či vyšší (P 166 MHZ doporučil)
· 8 Mb RAM (32 Mb doporučil)
· 5 Mb místo na disku
· VGA či vyšší rozlišovací monitor
· myš či jiný směřující k zařízení
