Aktuálny čas je Pia 26. Jún 2026 3:34:10
 PowerISO 4.6 Final
 Predmet príspevku: PowerISO 4.6 Final
PoslaťNapísal: Pon 09. Nov 2009 22:12:11
Create, edit, extract, convert, compress, encrypt, mount CD image file!!! PowerISO is a powerful image processing and file compression tool, which allows you to create, extract, compress, edit and convert ISO/BIN image files, and mount these files with internal virtual drive. And most of all, the compressed files can be used directly without decompressing.
• Support ISO, BIN, NRG, IMG, DAA, ...
• Open, Create, Edit, Extract ISO File...
• Compress, Encrypt, Split ISO File...
• Integrated with internal Virtual Drive...
Main Features:
• Support almost all CD,DVD-ROM image file formats (ISO, BIN, NRG, IMG, DAA and so on).
Note: DAA (Direct-Access-Archive) is an advanced format for image file, which supports some advanced features, such as compression, password protection, and splitting to multiple volumes. It can be handled directly just like other formats, such as ISO, BIN, ...
• Supports on-the-fly burning.
• Supports UDF image file.
• Create image file from hard disk files or CD,DVD-ROM.
• Edit an existing image file.
• Can edit and burn Audio CD image file.
• Extract files and folders from image file.
• Convert image files between ISO,BIN and other formats.
• Make bootable image file, get boot information from bootable image file.
• Make floppy disk image file.
• Optimize files to save disk space while saving image files.
• Mount image file with internal virtual drive. Even if the image file is saved as DAA format, the virtual drive can handle that format directly.
• Support shell integration, such as context menu, Drag and Drop, clipboard...
• Supports command-line parameters.
• Can open XBOX image file.
• Supports multiple languages
Supported operating systems:
• 32-bit Windows: Windows 98, Windows Me, Windows 2000, Windows XP, Windows 2003, Windows Vista, Windows 2008, Windows 7
• 64-bit Windows: Windows XP, Windows 2003, Windows Vista, Windows 2008, Windows 7
Supported languages: English, Arabic, Bulgarian, Chinese Simplified, Chinese Traditional, Croatian, Czech, Danish, Dutch, Farsi, French, German, Greek, Hungarian, Italian, Japanese, Korean, Lithuanian, Norsk, Polish, Portuguese, Russian, Slovenian, Spanish, Swedish, Thai, Turkish, Ukrainian
Vytvářet, upravovat, extrahovat, převádět, komprimovat, šifrovat, připojení CD soubor s obrázkem! PowerISO je mocný zpracování obrazu a kompresi souborů, nástroj, který umožňuje vytvářet, extrakt, komprimovat, editovat a konvertovat ISO / BIN image soubory, a připojit tyto soubory s vnitřní virtuální disk. A ze všeho nejvíc, je možné použít přímo komprimované soubory bez dekomprese.
• Podpora ISO, BIN, NRG, IMG, DAA, ...
• Otevřít, vytvářet, upravovat, Extract ISO souboru ...
• Komprese, šifrování, Split ISO souboru ...
• Integrace s vnitřním Virtual Drive ...
Hlavní vlastnosti:
• Podpora téměř všechny CD, DVD-ROM, obrazové formáty (ISO, BIN, NRG, IMG, DAA a tak dále).
Poznámka: DAA (Direct-Access-Archive) je moderní formát pro soubor s obrázkem, který podporuje několik pokročilých funkcí, jako je komprese, ochrana heslem, a rozdělení na více svazků. To lze řešit přímo, stejně jako jiné formáty, jako jsou ISO, BIN, ...
• Podpora on-letu-pálení.
• Podporuje UDF soubor s obrázkem.
• Vytvořte soubor s obrázkem z pevného disku soubory nebo CD, DVD-ROM.
• Upravit existující soubor s obrázkem.
• Může upravovat a vypalovat Audio CD soubor s obrázkem.
• výpis souborů a složek ze souboru s obrázkem.
• Konverze obrazových souborů mezi ISO, BIN a dalších formátů.
• Zkontrolujte, bootovací soubor s obrázkem, získat informace od startu zaváděcího souboru s obrázkem.
• Zkontrolujte disketu soubor s obrázkem.
• Optimalizovat soubory ušetřit místo na disku při ukládání obrazových souborů.
• Mount image soubor s vnitřní virtuální disk. Iv případě, že obraz je soubor uložen jako formát DAA, virtuální disk, že to zvládneš formát přímo.
• Podpora lastura integrace, jako je kontextové menu, Drag and Drop, schránky ...
• Podporuje-příkazové řádce.
• Může XBOX otevřít soubor s obrázkem.
• Podpora více jazyků
Podporované operační systémy:
• 32-bit Windows: Windows 98, Windows ME, Windows 2000, Windows XP, Windows 2003, Windows Vista, Windows 2008, Windows 7
Podporované jazyky: angličtina, arabština, bulharština, zjednodušená čínština, tradiční čínština, chorvatština, čeština, dánština, holandština, Perština, francouzština, němčina, řečtina, maďarština, italština, japonština, korejština, litevština, Norsk, polština, portugalština, ruština, slovinština , španělština, švédština, thajština, turečtina, ukrajinština
 Predmet príspevku: Re: PowerISO 4.6 Final
PoslaťNapísal: Pon 28. Dec 2009 8:24:11
Registrovaný: Pon 14. Dec 2009 18:16:18
Hotovosť: 63.00
Ďakujem !!! :one:
