Aktuálny čas je Pon 19. Okt 2026 7:52:31
 Extreme RapidshareDownloader v2.26 - KONEČNE TO FACHÁ
 Predmet príspevku: Extreme RapidshareDownloader v2.26 - KONEČNE TO FACHÁ
PoslaťNapísal: Ned 01. Nov 2009 13:38:40
Extreme Rapidshare Downloader
RapidDownload is a light, powerful, Resume Supported and fast Rapidshare downloader. The program size is only 15Kb !! It needs almost no processor resources while it downloads your files from Rapidshare.
If you tried to use Rapidshare before to download files, then you know all the hassle you need to go thru, as a free user, just to download a couple of files! RapidDownload was created using the Assembly Language art of programming. It is small and fast and it will automate all the actions that a free user has to do to download from Rapidshare
The RapidDownload key features are:
* very high performance Rapidshare downloader and crawler created in assembly language
* ultra small program with only 15 KB size as all windows programs should be...
* more than 1300 lines of high performance programing code
* proxy support (it uses Internet Explorer proxy settings)
hint: you can auto change your IP easily with a command line proxy switcher executed from "IP_changer.bat", and that will permit you no wait to the next download...
* compatibile with all windows versions (from Win95 up to Windows Vista)
* no install required, no registry mess, just unzip and run!
* complex crawling engine, automatic retries, server pages recognition, user extensibile
* If you reinstall Windows, no program reinstall is ever required, it just works like before!
* very intuitive interface: copy your Rapidshare links to the file "downloads.txt" and then start RapidDownload to download them automatically.
RapidDownload je světlo, silný, Resume Podporované a rychle Rapidshare downloader. Program je pouze velikost 15Kb! Je zapotřebí téměř žádný procesor zdroje a že stahuje soubory z Rapidshare.
Pokud jste se pokusili použít u Rapidshare stahovat soubory, pak víte, všichni hádka musíte projít, jako svobodný uživatel, stačí stáhnout pár obrázků! RapidDownload byl vytvořen pomocí shromáždění jazyk umění programování. Je malý a rychlý a automatizuje všechny akce, které zdarma má uživatel udělat pro stahování z Rapidshare
RapidDownload klíčové funkce:
* Velmi vysoký výkon Rapidshare downloader a pásové vytvořených v jazyce symbolických
* Ultra malý program, pouze s 15 KB velikost jako všechna okna programy by měly být ...
* Více než 1300 položek s vysokým výkonem zdrojových kódů
* Proxy servery (používá Internet Explorer nastavení proxy)
Tip: můžete automaticky změnit IP snadno s proxy příkazového řádku přepínač proveden z "IP_changer.bat", a že vám umožní bez čekání na další download ...
* Compatibile všechny verze systému Windows (od Win95 až Windows Vista)
* Není nutné instalovat žádný registr nepořádek, jen rozbalte a spusťte!
* Komplexní plazení motoru, automatické pokusy, server stránky uznání, uživatel extensibile
* Pokud přeinstalujete systém Windows, není vůbec nutné program přeinstalovat, prostě to funguje jako dřív!
* Velmi intuitivní rozhraní: zkopírovat Rapidshare odkazy na soubor "downloads.txt" a pak začít RapidDownload stahovat automaticky.
:pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: dám si toho piva na mojé bolavé ladviny s, ktorýma som si toho vytrpel až až a stále aj trpím po horko tažkom odstránení toho skurveného ladvinového kamena, ktorý pri vyberaní cez môj penisček so svojou ostrou hranou mi totálne doničil vnútornú stenu močovodu, kôli čomu mi nasadili hadicu menom steen ako terminátorovi, ktorú mi teraz 10. idú cez fifíka pri absolutnom vedomí vytahovat s nasadením robota-sondovač - kua už sa vopred toho bojím. A preto neusále pite pivo denne cca aj 5 x celý život pokial samozrejme nešoférujete, aby ste predišli týmto kamenolomským aktivitám a o neúprosných krčovitých bolestiach už ani nehovoriac. :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo: :pivo:
 Predmet príspevku: Re: Extreme RapidshareDownloader v2.26 - KONEČNE TO FACHÁ
PoslaťNapísal: Ned 01. Nov 2009 20:55:58
Amatér
Amatér
Registrovaný: Ned 06. Sep 2009 18:47:28
Hotovosť: 68.00
Banka: 365.00
a heslo do archivu ?
PoslaťNapísal: Ned 01. Nov 2009 22:18:20
peto píše:
ved predsa pass je tam, len sa lepšie kukni a zbadáš ho...
