Aktuálny čas je Str 21. Okt 2026 11:35:41
 New - Internet Cyclone v1.99
 Predmet príspevku: New - Internet Cyclone v1.99
PoslaťNapísal: Pia 23. Okt 2009 11:59:55
Internet Cyclone - is a powerful, easy-to-use, Internet Optimizer for Windows 95, 98, ME, NT, 2000 and XP designed to automatically optimize your Windows settings which will boost your Internet connection speed up to 200%. Internet Cyclone is compatible with all modems and high speed LAN, ISDN, CABLE, DSL, T1 or other connections. This software will still be useful to you after upgrading your Internet connection. Using this software you will gain guaranteed faster Internet speed for the time you're online. Surfing, downloading files, emailing, playing online games, and anything else you do online will be faster. This is excellent software for slow dial-up modems as well as high speed access connections. This software will be extremely valuable to you as you continue to upgrade your computer and connections. It will work with all connections and all browsers so it will still be extremely useful to you in the future. You should use Internet Cyclone as a REAL alternative to expensive upgrades.
What can Internet Cyclone offers to you?
* Internet Cyclone optimizes your Windows settings automatically or you can customize them.
* You can speed internet connection without changing your Hardware.
* Works with all Browsers.
* It is compatible with all Dial-Up modems and high speed LAN, CABLE, DSL, DSL (PPPoE), T1 or other connections.
* nternet Cyclone will speed up web surfing, online gaming, e-mailing, chat and video conference and it will even speed up downloads.
How does this work?
While the actual maximum transfer speed of your Internet connection cannot be changed except by upgrading your hardware, Internet Cyclone can increase the performance of your existing modem/network hardware by optimizing Windows modem/network settings to maximize the efficiency of your current hardware. By default, your Windows PC does not manage Internet connections as optimally as possible.
Internet Cyclone is designed to automatically change many registry settings in Windows such as: Maximum Transmission Unit (MTU), Maximum Segment Size (MSS), Time To Live (TTL), TCP Receive Window (Rwin), Cache Size (NDI), PMTU Black Hole Detect, PMTU Auto Discovery (PAD), Session Keep Alive (SKA) and some Windows Extra settings like: Selective Acknowledgement (SACK), Maximum Duplicate Acknowledge (Max DupAcks), Large Window Scaling, Ports COM, VCache value, Combuffer value, Internet Explorer settings, Maximum connection per server.
If these settings are not correctly optimized then you will not get the best performance of your Internet Connection. Internet Cyclone is a proof method to change these settings easily and quickly. If you are an experienced user, then with this Internet optimizer you can set these values manually and speed up Internet connection at maximum.
OS: Windows NT, 2000, 2003, XP, Me, 98, 95
Internet Cyclone - je výkonný, bezstarostný-až k-cvičení, Internet Optimizer pro Windows 95, 98, ME, NT, 2000 a XP navrženy tak, aby automaticky optimalizovat nastavení systému Windows, která posílí vašeho připojení k internetu rychlostí až 200%. Internet Cyclone je kompatibilní se všemi modemy a vysokorychlostních LAN, ISDN, CABLE, DSL, T1 nebo jiné spojení. Tento software bude ještě být užitečné pro vás po upgradu připojení k Internetu. Použitím tohoto softwaru získáte zaručena vyšší rychlost internetu po dobu jste online. Surfování, stahování souborů, posílání e-mailů, hraní on-line hry, a vše ostatní, co dělat on-line budou rychlejší. To je vynikající software pro pomalý dial-up modemy, jakož i vysokorychlostní připojení k přístupu. Tento software bude velmi cenné pro vás, jak budete pokračovat v upgradu počítače a připojení. Bude pracovat se všemi spoji a prohlížeče, takže to bude ještě být velmi užitečné pro vás v budoucnu. Měli byste používat internet Cyclone jako skutečnou alternativu k drahé upgrady.
Co může Internet Cyclone Vám nabízí?
* Internet Cyclone optimalizuje nastavení systému Windows automaticky, nebo si můžete přizpůsobit jim.
* Můžete rychlosti připojení k internetu bez nutnosti měnit váš hardware.
* Funguje se všemi prohlížeči.
* Je kompatibilní se všemi Dial-Up vysokorychlostní modemy a LAN, CABLE, DSL, DSL (PPPoE), T1 nebo jiné spojení.
* NTERNET Cyclone urychlí webové surfování, hraní on-line, e-mail, chat a video konference a bude ještě urychlit stahování.
Jak to funguje?
Zatímco skutečná maximální přenosovou rychlost vašeho internetového připojení není možné změnit kromě upgradu hardwaru, mohou internet Cyclone zvýšit výkon vaší stávající modem / síťová zařízení pomocí optimalizace Windows modem / síťová nastavení, aby maximalizoval efektivitu svého současného hardwaru. Ve výchozím nastavení Windows PC nedaří připojení k internetu, jak nejlépe je to možné.
Internet Cyclone je navržen tak, aby automaticky mnoho změnit nastavení registru v systému Windows, jako jsou: Maximum Transmission Unit (MTU), maximální velikost segmentu (MSS), Time To Live (TTL), TCP Receive Window (Rwin), Cache Size (NDI), PMTU Black Hole Rozpoznat, PMTU Auto Discovery (PAD), Session Keep Alive (SKA) a některá nastavení, jako je Windows Extra: Výběrové potvrzování (SACK), Maximum Duplicate Potvrzovací (Max DupAcks), Velké Window Scaling, porty COM, VCache hodnotu, Combuffer hodnota , nastavení aplikace Internet Explorer, Maximum připojení na server.
Je-li tato nastavení nejsou správně optimalizována nebudete ten nejlepší výkon vašeho připojení k Internetu. Internet Cyclone je osvědčenou metodu pro změnu těchto nastavení snadno a rychle. Pokud jste zkušený uživatel, pak se s tímto Internet Optimizer můžete nastavit tyto hodnoty ručně a zrychlení připojení na internet na maximum.
