Aktuálny čas je Pon 14. Sep 2026 18:21:53
 Wireless WEP HACK - Špeciál Technic univers-soft
 Predmet príspevku: Wireless WEP HACK - Špeciál Technic univers-soft
PoslaťNapísal: Uto 20. Okt 2009 13:22:49
1) Unzip and install Commview, then paste the included “cv.exe” to the directory you installed it to (c:\program files\commviewwifi)
Usenet Binaries anonym mit DSL Speed downloaden inkl. gratis Software
2) Open commview and install the commview drivers to a card. It should prompt you about your card and than automatically install the driver. It is important that you have 1 card that works with commview or else the rest of the tutorial will not work
3)now go to the “rules” tab and check “enable advanced rules”
4)type in the box labled formula “tods=1 and dmac=FF:FF:FF:FF:FF:FF” then type a name for your formula in the box labled name and than click add/edit.
5)it should now appear in the upper box. if it is not checked, check it.
6)now click settings>options>memory usage and turn maximum packets in buffer to 20000 (max). If it prompts you to restart it, do so. There are three funnel looking things on the main menu bar of commview. uncheck all but the first one (one labled “capture data packets”)
7) now click the play button and scan for the network you want to crack.
8)once you have found it, drag the channel menu down to the desired channel and click capture.
9) now using your other adapter thats not capturing, connect to the password protected network. when it asks you for key, type in something random, i used 1234567890.
10) it should now say connected with limited connectivity. (same as being associated!!)
11)go back to your commview menu and click on the packets tab. you should see a couple of packets.
12) looking at the protocol column, you should see a couple labled IP/UDP, ARP REQ, and a couple of others. Right click on any packet labled “ARP REQ” and than click send packet, and selected. A mini menu should now appear.
13) on the mini menu, change packets per second to 2000, and rather than 1 time(s), click continuously, and Then click send.
14) now go back to the main commview window and go to the rules tab, and uncheck the rule you made.
15) You are now injecting and you should see the number of packets rising really fast.
16)to save the packets, you have to save every 20000 packets, click file, save and than in the save dialogue, remember where you saved it, and instead of saving it as an ncf file, save it as a “dump” .cap file.
17) Extract the Aircrack-NG folder.
18)open aircrack-ng-GUI that can be found in the map “bin” and select the files you saved, and than click launch.
19)Look at the list of IV’s you have, and select the network you want to crack , there should be a list of alot of them, chose the one with the most ivs.
1) Rozbalte a nainstalujte CommView, vložte včetně "cv.exe" do adresáře, který jste nainstalovali, aby (c: \ Program Files \ commviewwifi)
Usenet Soubory anonym mit DSL Speed downloaden inkl. Software zdarma
2) Open CommView CommView a nainstalovat ovladače na kartu. Mělo by se vás zeptá o kartu a pak se automaticky nainstaluje ovladač. Je důležité, aby jste si 1 kartu, která pracuje s CommView, jinak zbytek cvičení nebude fungovat
3) Nyní jděte na "pravidla" kartu a zda "povolit rozšířené pravidla"
4) zadejte do pole označené vzorec "tods = 1 a dmac = FF: FF: FF: FF: FF: FF" zadejte název vašeho vzorce do pole označené jménem a pak klepněte na tlačítko Přidat / upravit.
5) to by se nyní měla objevit v horním okně. není-li zkontrolovat, zda to.
6) Nyní klepněte na tlačítko Nastavení> Možnosti> využití paměti a naopak maximální paketech ve vyrovnávací paměti na 20000 (max). Jestliže se zobrazí výzva k restartování, udělejte to. Existují tři cesty hledají, co se na hlavní liště menu CommView. odznačit vše, ale ten první (jedna označena jako "zachytit datové pakety")
7) Nyní klikněte na tlačítko přehrávání a skenování na síť, kterou chcete bezva.
8), jakmile jste našli to, přetáhněte kanál dolů v nabídce na požadovaný kanál a klikněte na tlačítko snímání.
9) Nyní pomocí jiného adaptéru thats not snímání, připojte se k síti chráněné heslem. když se zeptá na klíč, napište něco náhodně, i použité 1234567890.
10) by měl nyní říct, spojené s omezeným připojením. (stejné jako přidružené!)
11) Vrať se do CommView menu a klikněte na záložku pakety. měli byste vidět pár paketů.
12) při pohledu na protokol sloupci, měli byste vidět pár označené IP / UDP, ARP REQ, a pár dalších. Klikněte pravým tlačítkem myši na libovolné označeny paket "ARP REQ" a pak klepněte na tlačítko odeslat paket a vybrané. Mini menu by se nyní měla objevit.
13) na mini menu, změna paketů za sekundu do roku 2000, a spíše než 1 time (s), klepněte na tlačítko nepřetržitě, a klepněte na tlačítko Odeslat.
14) Nyní jděte zpět na hlavní CommView okna a přejděte na kartu pravidel, a zrušte pravidlo jste udělali.
15) Nyní jste injekci a měli byste vidět počet paketů roste opravdu rychle.
16) pro uložení pakety, musíte zachránit všechny pakety 20000, klepněte na soubor, uložit a pak uložit do dialogu, vzpomenout, kam jste uložili, a místo uložení jako NCF soubor, uložte jej jako "dump". čepice souboru.
17) Výpis aircrack-ng složku.
18) otevřít aircrack-ng-GUI, které lze najít v mapě "bin" a vyberte soubory, které jste uložili, a pak klepněte na tlačítko start.
19) Podívejte se na seznam IV máte, a vyberte síť, kterou chcete bezva, měla by existovat seznam hodně z nich si vybral ten s nejvíce IV.
V rar - balíku samozrejme je priložený aj nápomocný manuál v podobe PDF, ktorý Vám verím, že taktiež poslúži pri priebežnom učení ako aké si vodítko postupnosti krokov k dosiahnutiu vytíčeného ciela..!!!
