Aktuálny čas je Uto 29. Sep 2026 20:08:51
 Procaster 1.0.53 - Hráči pozorne čítajte, lebo je to pre Vás
 Predmet príspevku: Procaster 1.0.53 - Hráči pozorne čítajte, lebo je to pre Vás
PoslaťNapísal: Str 26. Aug 2009 16:13:04
How to share screen work or play games with your current friends? Using webcam back then transmitted via the Internet certainly is not the solution or and effective. If you are looking for a utility to support their work this ProCaster choice is appropriate.
First download these programs, then click the SIGN UP button on the right corner of the homepage to create an account.
After installation and account creation is successful, you open up ProCaster, enter your username and password and click LOGIN button to sign up and start using the program.
To share a computer screen with everyone, click GO LIVE. If you're surfing the web, listening to music or watching movies, then select the type of screen display; if you're playing the game mode selection screen is a game back. Get invited to link people to channel MY CHANNELS, you click the player, then press the Copy button next frame CHANNEL PAGE LINK. Then, send this link to friends via email or chat.
When you start recording and screen the window will PROCASTER from frame to frame BROADCAST CHAT. Below left corner will display the screen working as your thumbnail, next to the clock display time back screen, frame, and Internet connection speed at that time. STOP button to stop recording your screen, right corner is a tool used to shrink, enlarge or reduce the screen size is returned.
Next, you visit http://www.livestream.com/procaster/ sign with your account. Then, click the Watch button to start preview your screen is back. If there are other people involved CHANNELS My channels and are talking to you, then you can give them your screen.
If you do not want to share the screen or do not want to talk to, you click the STOP button to stop playing.
Jak sdílet práce s počítačem, nebo hrát hry s aktuálním přáteli? Pomocí webkamery zpět pak přenášeny přes internet rozhodně není řešením a ani efektivní. Jestliže hledáte nástroj pro podporu jejich práce ProCaster této volby je vhodné.
První stáhnout tyto programy, klepněte na tlačítko REGISTRACE na pravém rohu stránky k vytvoření účtu.
Po instalaci a vytvoření účtu je úspěšný, můžete otevřít ProCaster, zadejte své uživatelské jméno a heslo a klikněte na tlačítko PŘIHLÁSIT se zaregistrujete a začnete používat program.
Chcete-li sdílet obrazovku s každým, klepněte na tlačítko GO LIVE. Jestliže jste surfování na webu, poslech hudby nebo sledování filmů, pak zvolte typ obrazovka, pokud hrajete hru volba režimu obrazovky je hra dozadu. Vyzváni, aby si lidé na odkaz MOJE KANÁLY kanál, kliknete na hráče, pak stiskněte tlačítko Kopírovat vedle rámu stránky kanálu LINK. Potom poslat odkaz přátelům e-mailem nebo chat.
Když spustíte nahrávání a obrazovce okno PROCASTER od rámu k rámu BROADCAST CHAT. Níže levém rohu objeví obrazovka pracuje jako svůj náhled, vedle zobrazení času zpět zástěna, rám, a rychlost připojení k internetu v té době. STOP tlačítko pro zastavení nahrávání obrazovky, pravý roh je nástroj používaný pro zmenšit, zvětšit nebo zmenšit velikost obrazovky se vrací.
Další, navštívíte http://www.livestream.com/procaster/ přihlásit ke svému účtu. Poté klikněte na tlačítko Sledovat začít náhled obrazovky je zpět. Pokud existují další zainteresované osoby KANÁLY Moje kanály a mluví k vám, pak si můžete dát obrazovce.
Pokud se nechcete sdílet obrazovku nebo nechtějí mluvit, kliknete na tlačítko STOP pro zastavení přehrávání.
