Aktuálny čas je Str 28. Okt 2026 3:28:58
 IE Inspector HTTP Analyzer v4.0.1.133
 Predmet príspevku: IE Inspector HTTP Analyzer v4.0.1.133
PoslaťNapísal: Pon 30. Mar 2009 19:29:22
IEInspector HTTP Analyzer is such a handy tool that allows you to monitor, trace, debug and analyze HTTP/HTTPS traffic in real-time. It is used by industry-leading companies including Microsoft, Cisco, AOL and Google.
HTTP Analyzer includes two Editions---Stand-alone Edition and IE Add-on Edition.
Stand-alone Edition : Window stand-alone EXE application. It allows you to capture and view HTTP/HTTPS traffic from a specific process or user/session/system wide. Support IE, Safari, Chrome, Firefox and other win32 web application.
IE Add-on Edition( IE HTTP Analyzer) : An IE add-on HTTP Viewer that integrates into the lower part of your IE browser window and can be opened/closed from the IE toolbar. It can only capture and view HTTP/HTTPS traffic of current IE process.
Main Features
* See wide range data, including Header, Request ,Network Timing, Content, Cookies, Caching, Query Strings, Post data, Request and Response Stream, redirection URLs, DOMReadyTime, PageLoadTime (New in V4) and more.
* Real-time Page and Request Level Time Chart, The colored time chart is used to express the relative time between a single network level timing (i.e. , DNS lookup, TCP connects) and other timing segments in the same request.
* Native support for Flash Remoting , HTTP Analyzer is especially useful for Adobe Flash developers as you can view the request and response of LoadVariables, LoadMovie and XML loads. It can also deserialize and display all Flash Remoting or AMF (AMF0 and AMF3) traffic in a easy-to-use AMF object tree. New in V4
* JSON , SOAP and .NET ViewState Viewer , HTTP Analyzer can deserialize SOAP and JSON traffic into the easy-to-use object tree. It can also read and decode the hidden ViewState on an ASP.NET Page. New in V4
* Request builder, Users can handcraft an HTTP request by using the HTTP Request Builder, or use a drag-and-drop operation to move an existing request from the session grid to the Request Builder to execute it again.
* Automation interface, The HTTP Analyzer automation library is packaged as COM components. both Stand-alone and Add-on can be fully controlled by using OLE Automation. It can be used by most programming languages (e.g. C#, VC, Delphi & JavaScript).
* Support HTTPS, show you unencrypted data sent over HTTPS / SSL connections as the same level of detail as HTTP.
Odpoved s citáciou Editovat príspevok Ohlásit tento príspevok Vymazat príspevok
IEINSPECTOR HTTP Analyzer je takový vhodný nástroj který dovoluje vám monitorovat, stopu, vychytat mouchy a analyzovat HTTP/HTTPS provoz v reálném čase. To je užívaný průmyslovými-vedoucími společnostmi včetně Microsoft, Cisco, AOL a Google.
HTTP Analyzer zahrnuje dva Editions - - - Stand - alone Edition a IE připojené vydání.
Samostatné vydání : Okenní samostatná EXE aplikace. To dovoluje vám zachytit a dívá se na HTTP/HTTPS cestovat ze specifického procesu či uživatele/sezení/systému širokého. Podporujte IE, safari, chrom, Firefox a jinou win32 webovou aplikaci.
IE připojený vydání( IE HTTP analyzátor) : IE Připojený HTTP Viewer který včlení do nižší části vaší IE okna prohlížeče a může být otevřený/zavřený z IE lišty s nástroji. To může jen zachytit a dívá se na HTTP/HTTPS dopravu aktuálního IE procesu.
Hlavní rysy
* sídlo široká rozsahová data, včetně Header, žádosti ,síťové časové nastavení, obsah, koláčky, Caching, dotazovací řetězce, po datech, žádosti a Response Stream, přesměřování URLS, DOMREADYTIME, PageLoadTime (nový ve V4) a více.
* real - time stránka a Request Level časový diagram, barevný časový diagram je užívaný pro vyjádřit relativní čas mezi jednotlivým síťovým úrovní časovým nastavením (i.e. , DNS vyhledávání, TCP spojuje) a jiné časové úseky v stejné žádosti.
* přirozená podpora pro Flash Remoting , HTTP Analyzer je zvláště užitečný pro Adobe Flash vývojáře jak vy se můžete dívat na žádost a odpověď LoadVariables, LoadMovie a XML nákladů. To může také sériově paralelní převodník a zobrazit všechno Flash Remoting či AMF (AMF0 a AMF3) provoz v snadno použitelném AMF namítá strom. Nový ve V4
* JSON , SOAP a .NET ViewState Viewer , HTTP Analyzer může sériově paralelní převodník SOAP a JSON doprava do snadno použitelného objektového stromu. To může také číst a dekódovat skrytý ViewState na ASP.NET stránka. Nový ve V4
* žádací stavitel, uživatelé mohou umělecké řemeslo HTTP žádost použitím HTTP Request Buildera, či užívat táhni a pusť operace k tomu, aby pohybovala existující žádostí ze zasedací mřížky k Request Builderovi vykonat to znovu.
* automatizační rozhraní, HTTP Analyzer automatizační knihovna je balená jak COM součásti. oba Stand - alone a Add - on může být plně řízený použitím OLE Automation. To může být použito největšími programovacími jazyky (e.g. C#, VC, Delfy & JavaScript).
* podpůrný HTTPS, ukažte vám nezašifrovaná data poslaná přes HTTPS / SSL spojení tak stejný stupeň zaostřený jak HTTP.
