Aktuálny čas je Ned 25. Okt 2026 7:15:12
 Privoxy 3.0.12
 Predmet príspevku: Privoxy 3.0.12
PoslaťNapísal: Uto 24. Mar 2009 20:21:22
Privoxy is a web proxy with advanced filtering capabilities for protecting privacy, modifying web page content, managing cookies, controlling access, and removing ads, banners, pop-ups and other obnoxious Internet junk.
Privoxy is a software that helps you control access and manage cookies.
Privoxy has a very flexible configuration and can be customized to suit individual needs and tastes. Privoxy has application for both stand-alone systems and multi-user networks.
What's New :
· The socket-timeout option now also works on platforms whose select() implementation modifies the timeout structure.
· Previously the timeout was triggered even if the connection didn't stall.
· The Connection: keep-alive code properly deals with files larger than 2GB. Previously the connection was closed too early.
· The content length for files above 2GB is logged correctly.
· The user-manual directive on the show-status page links to the documentation location specified with the directive, not to the Privoxy website.
· When running in daemon mode, Privoxy doesn't log anything to the console unless there are errors before the logfile has been opened.
· The show-status page prints warnings about invalid directives on the same line as the directives themselves.
· Fixed several justified (but harmless) compiler warnings, mostly on 64 bit platforms.
· The mingw32 version explicitly requests the default charset to prevent display problems with some fonts available on more recent Windows versions. Patch...
Privoxy je webový zastupování s pokročilými filtrujícími schopnostmi pro ochranu soukromí, modifikující webový stránkový obsah, ovládání koláčky, ovládací přístup, a odstranění reklam, bannerů, vyskakovací reklam a jiného nepřístojného internetového odpadu.
Privoxy je software který pomáhá Vám ovládat přístup a řídit koláčky.
Privoxy má velmi flexibilní konfiguraci a může být zákaznicky přizpůsobený k tomu, aby hodil se osobním potřebám a chutím. Privoxy má žádost o oba nezávislé systémy a víceuživatelské sítě.
Co je nového :
· objímka-překročení časového limitu volba nyní také pracuje na platformách jejichž vybrat() implementaci modifikuje překročení časového limitu strukturu.
· předtím překročení časového limitu bylo spouštěné dokonce když spojení nezastavilo se.
· spojení: ionizační kód pořádně jedná se soubory většími než 2GB. Předtím spojení bylo zavřené příliš brzy.
· obsahová délka pro soubory nad 2GB je přihlášená správně.
· uživatelský-ruční příkaz na přehlídce-statusu stránce připojí k umístění dokumentace specifikované s příkazem, ne - Privoxy websajtem.
· při běhu v módu démona, Privoxy nezapíše cokoli do konzoly jestliže ne tam jsou chyby před logfile byly otevřené.
· přehlídka-status stránka tiskne varování o invalidních pokynech na stejné lince jak pokyny sami.
· soustava několik ospravedlněných (ale neškodných) varování kompilátoru, většinou 64 bitových platforem.
· mingw32 verze explicitně žádá standardní znakovou sadu předejít displejovým problémům s nějakými fonty dostupnými na v novější době windowsovské verze. Záplata...
 Predmet príspevku: Re: Privoxy 3.0.12
PoslaťNapísal: Uto 03. Nov 2009 15:36:27
