Aktuálny čas je Sob 26. Sep 2026 15:31:54
 Evidence Eliminator 6.03
 Predmet príspevku: Evidence Eliminator 6.03
PoslaťNapísal: Pia 29. Jan 2010 23:41:31
It is a proven fact... routine Forensic Analysis equipment such as EnCase and F.R.E.D. used by Private and Business Investigators, Law-Enforcement and others, can recover evidence from parts of your hard drive that you thought were empty, parts that you had cleaned. Your hard drive might appear clean... but still be full of 'sensitive material' that you did not want to download in the first place and it might very well be a Serious Criminal Offence in your country to have that data stored on your computer even if you didn't know it was still there. You could go to Jail! Pressing 'Delete' or emptying your 'Recycle Bin' - or even 'Formatting' your disk - simply will not work, the 'sensitive material' will still remain on your hard drive! Hiding your browsing history... may give you a false sense of security, just because it looks 'Hidden', doesn't mean the evidence is gone. You will be held responsible for any data which you allow to remain on your computer, even if it was only by accident. Even files and Internet Searches you have made which you thought you had never "saved to disk" can be recorded as permanent evidence on your hard drive Get Evidence Eliminator™ and Protect Yourself! Get total protection now... If you do not use Evidence Eliminator™ your PC is "a ticking Time Bomb waiting to go off!" Only with Evidence Eliminator™ can you get the protection you deserve, only then can you use your PC to explore the Internet with confidence. The distinctive style and unsurpassed quality of Evidence Eliminator™ and its rapid ongoing development and success have firmly established Evidence Eliminator™ as the world's premier computer hard drive cleansing system! Evidence Eliminator™ is a powerful and easy-to-use program, no other commercially available program can do the same job. Every day, Evidence Eliminator™ quickly and professionally deep cleans your computer of 'sensitive material', leaving you with a clean PC, a clean conscience and instant peace of mind.
PASS : BEZPEČNOSŤ
Je dokázáno, ... Forenzní analýza běžných zařízení, jako jsou obalit a FRED používané pro soukromé a podnikatelské Řešitelé, zákon-výkonu a jiné důkazy, může zotavit z částí vašeho pevného disku, který jste si myslel, byly prázdné, díly, které jste měli vyčistit. Pevný disk může zdát čistý ... ale stále je plná 'citlivé materiály', které jste nechtěli stáhnout v první řadě, a to by mohlo být docela dobře za závažný trestný čin ve vaší zemi, aby tyto údaje byly uloženy v počítači, i když jste nevěděli, že byl ještě tam. Můžeš jít do vězení! Stisknutím 'Smazat' nebo vyprázdnit 'Koš' - nebo dokonce 'Formátování' pevný disk - prostě nebude fungovat, 'citlivý materiál' stále zůstanou na pevném disku! Skrytí historie procházení ... může dát falešný pocit bezpečí, jen proto, že to vypadá, 'Skrytý', neznamená, že důkazy, jsou pryč. Budete zodpovědný za veškeré údaje, které vám umožní zůstat v počítači, i když to byl jen náhodou. Souborů a dokonce i vyhledávání na internetu, které jste udělali jste si myslel, nikdy "uložit na disk" lze zaznamenat jako trvalý doklad na vašem pevném disku si Evidence Eliminator ™ a Nestaňte! Získejte celkovou ochranu teď ... Pokud nechcete používat Evidence Eliminator ™ PC je "časovanou bombu na lince jít pryč!" Pouze s Evidence Eliminator ™ můžete získat ochranu si zaslouží pouze budete počítač používat k aplikaci Internet bez obav . Osobitý styl a bezkonkurenční kvalitu důkazů Eliminator ™ a jeho pokračující rychlý rozvoj a úspěch mají pevně stanovené Evidence Eliminator ™ a světových počítačový systém, pevný disk očisty! Evidence Eliminator ™ je výkonný a bezstarostný-až k-cvičení program, žádné jiné komerčně dostupného programu můžete dělat stejnou práci. Každý den, Evidence Eliminator ™ rychle a odborně hluboce čistí váš počítač 'citlivý materiál', takže můžete s čistým počítačem, čisté svědomí, a okamžitě klid.
